Old Apr 11, 2012, 05:59 AM
Webheadfred is offline
Find More Posts by Webheadfred
Air Traffic Controller
United States, TN, Knoxville
Joined Aug 2011
Futaba FASST on 8FG. HFP current draw...
Good morning folks! The build is coming along and I wanted to throw a few questions out there.
I'm using a Futaba 8FG Super and the R6208SB reciever. Has anyone used the FASST mode with the HFP? I've also managed to get the S-BUS working with the PWM converter. Can I use these extra channels with the HFP?
Also, is 1 amp enough current for the Hoverfly Pro board and or the GPS board? I'm considering building a linear supply just for those controllers. I realized the ESC had switching supplies after seeing the torrid and reading the manual for the ESC. (imagine that!) I thought I could eliminate a little noise with a few parts laying around.
Best regards,
Fred
Webheadfred is offline Find More Posts by Webheadfred
Old Apr 11, 2012, 07:28 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTL7668
It says 7.4v battery or regulated power but does not list current. I expect that it is way lower than 1 amp.
RC Man is offline Find More Posts by RC Man
Old Apr 11, 2012, 07:53 AM
Joined Aug 2011
Thanks RC... I was more wondering about the current draw on the HFP and GPS boards. With all the components, I'm thinking it may be at least close to 1 amp.
Old Apr 11, 2012, 08:43 AM
Joined Aug 2011
Well that was about dumb since the ESC's are only used to power the reciever. I can just power the reciever and not use the ESC BEC function. DOH!
Old Apr 11, 2012, 02:47 PM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
I recommend no matter what you do that you check the rx voltage with a meter with everything connected.
I made a little video for the CopterControl forum demonstrating why you should use separate ubecs for the camera servos and why you should always check the voltage. I was going to use some small and cheap HK ubecs for the rx and control board but found that even 500mA-1A on a "3A ubec" took the voltage below 5v!
FYI...
Openpilot Multicopter voltage testing / board malfunction (4 min 42 sec)
Pete
Efliernz is offline Find More Posts by Efliernz
Sold Futaba R608FS, 2.4 GHz FASST 8 Channel Receiver, 8fg 10cg 12fg 12z 14mz 18mz paulywood Aircraft - General - Radio Equipment (FS/W) 0 Dec 12, 2011 07:52 PM
Question What's the current drain for a Futaba FASST TM-8 module? The PIPE Radios 11 Oct 28, 2011 12:55 PM
Discussion measuring current draw on BEC? marhar Power Systems 2 Oct 18, 2011 09:24 PM
Sold NEW Futaba 8FG FASST 8-Ch Heli + R6008HS RX FUTK8001 compudation Aircraft - General - Radio Equipment (FS/W) 0 Jul 23, 2010 09:26 PM
