| Thread Tools |
| This thread is privately moderated by whatasteele, who may elect to delete unwanted replies. |
NEW - Heavy Duty Pan and Tilt Antenna Tracking Station (ATpro-1000)
BRAND NEW - Heavy Duty Pan and Tilt Antenna Tracking Station (ATpro-1000)
Professional servo controlled antenna tracking station that fits small and large patch antennas and a lot more. This is not a mount made for security cameras or something alike but a purpose built and designed Antenna Tracking Station that will allow most of the FPV ground stations gear mounted to it. It has universal mounting locations for helping balance the different kinds of loads depending on the weight and CG of the installed equipment keeping the servo power draw low. Very sturdy and rugged design with no fear of breakage. Easy to set up and can be mounted on a tripod or placed on any flat surface. Precision Light weight and manufactured from strong 6061 T6 aircraft aluminum and will handle larger Yagi/directional type antennas also (w/optional #ATPT-100YB bracket). Plenty of space and mounting holes for video receivers to be attached even large dual output models. Works with most antenna trackers interfaces that use servos for operation like EagleEyes, EzAntenna Tracker and custom designs. (Not Included). Video and pics, show servos and antennas, those are purchased separately. The AT Pro-1000 has 1:1 ratio so the servos do not lose there ratings through gear drives which can lower servos output power by half or more. Can easily rotate from 1 to more then 360 degrees and tilt up to 90 degrees plus. Panning is supported by a flat surface multi-bearing system that is rated at over a 100lbs so there's no wobble when in operation and much less strain on the panning servo.. Mounting holes for popular video receivers so no Velcro/tie straps needed. Strong enough to attach a small camera which is great for recording the aircraft when no camera person is available since the AT Pro-1000 is always pointed in the direction of the aircraft. This can also have a spot light mounted for night flights ..... The ATpro-1000 is strong enough to handle most of the ground stations gear attached to it making it a all-in-one Tracking Station.Assembly Instructions Any good large size High Torque servo can be used for panning along with any 90 degree standard size High Torque servo for tilt. (Desighed with the Hitec HS-785HB 360 degree and HS-645MG in mind; I have other servos avail for $15 ea for High Torque) and Some modifications may be needed depending on what servo you intend to use. Low Geared High Torque servos are highly recommended. Controlling the servo limits is done through the interface like EagleEyes, etc... Weight: approx 36oz with servos attached. Size 12"x12"x6". 8" Antenna mounting area. ASKING $109 Shipped CONUS Watch video for example, this is not the unit, its video of another one. This one for sale is BRAND NEW
| Thread Tools | |
| For Sale [PRICE DROPPED] High speed High torque PAN TILT system for antenna tracking or camera | wefao | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Apr 11, 2012 05:29 AM |
| Sold Servo City heavy duty Pan and Tilt | Blue Collar | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Mar 20, 2012 04:35 PM |
| Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos | imagebuff | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Mar 20, 2012 02:26 AM |
| Discussion Best COMPACT Antenna Tracking pan and tilt (for GROUND STATION Patch)? | SkyEyes | Video Piloting (FPV/RPV) | 2 | Oct 11, 2011 08:33 AM |
| Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker | thefokker | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Sep 08, 2011 07:53 AM |
