Old Apr 11, 2012, 12:05 AM
DNZ is offline
DNZ
Find More Posts by DNZ
DNZ
Joined Aug 2010
Tricycle Landing Gear
I am setting up a tricycle landing gear on a plane with a 27 inch long fuselage. Any ideas on how far apart the nose wheel should be from the main landing gear? Is there any general rule of thumb when installing?
DNZ is offline Find More Posts by DNZ
Old Apr 11, 2012, 12:56 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
Its the rear wheels that are most critical. They need to be just behind the centre of gravity, so that only a bit of up elevator is needed to make the plane rotate and take off. Usually the nose gear is just behind the motor, but this is not critical.
Scaledown is offline Find More Posts by Scaledown
Old Apr 11, 2012, 09:49 PM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
And it's a good idea to not have too much throw,of course..full deflection should yield about a 8 ' circle...
the aircraft should sit level,not nose down.If too much elevator is required ,it'll 'leap' off the runway into a steep climb.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Feb 23, 2014, 03:15 PM
failboat is offline
Find More Posts by failboat
yank and bank!!
Joined May 2013
Had to post my experiences on this after working out the bugs in a scratchbuilt....
It bears mentioning that the placement of the mains is ALSO to reduce the weight on the nose gear; it makes a big difference preventing damage to the nose gear and reduces the tendency for the nose gear to be squirrely. I can push the tail down on mine with a lot less force now and the plane doesn't fall on it's tail until I tip it way back.
I also believe that the further forward the nose gear is, the less impact it will receive when the nose sets down, kinda like less lever effect on the nose gear.
failboat is offline Find More Posts by failboat
Discussion A "no landing gear needed" recommendadtion, good for grass landing plane. Dr.JJ Electric Plane Talk 21 Mar 23, 2012 05:28 PM
Sold NEW Landing Gear Door Sequencer and Landing Gear Control Module Kevin Greene Aircraft - Electric - Airplanes (FS/W) 2 Dec 27, 2011 08:12 PM
Discussion Radian Glider with tricycle landing gear Desert Hawk Electric Sailplanes 46 Dec 05, 2011 12:23 PM
Question ARF Tricycle landing gear Rob1962 Fuel Plane Talk 8 Oct 19, 2011 02:34 PM
Help! Tricycle landing gear Q Monterey10 The Builders Workshop 6 Oct 11, 2011 02:54 AM
