| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Kokam 1500s vs TP2100s... who's winning?
I have a TP2100 pack for my mpjet 25/35 (pulling around 14 amps WOT but more like 7-9 amps during most of my flying.
The Kokam 1500s sure look appealing at $50 vs $80 for the TP packs. Am I missing some reason the 1500s wouldn't be a good choice? Thanks for any help. Wayne |
#2 |
Based on my so far very limited experience with the K1500s and not much more with the TP2100s, I'd say you've nothing to lose but some duration. You'll get as good power and at least as high a percentage of the rated capacity out of the K1500s as you get from your TP2100s used the way you describe.
#3 |
I plant balsa sticks too
Well, it depends what you want to draw. I draw 20A peaks and avg 15A during the flight. It's obviously a limit for the TP as they come quite hot. I don't think I could draw that out of the kok1500.
If you draw 5 to 6C as you say, you can try these cells (btw, tests show according to other threads the 8C are overstated for these cells). Another solution which will give you better voltage and 20g less than the TP are the CBP 850 in 3S2P pack. I manage to draw 10C avg from these cells which don't heat much. And they hold a better voltage...but you have to build your own packs. |
| Thread Tools | |
| Help! Lite film VS tissue...who's the heavyweight? | megawatt | Indoor and Micro Models | 12 | Feb 24, 2006 08:37 AM |
| Thunder Power vs Electrifly: who's the biggest loser? | Erupter | Batteries and Chargers | 39 | Sep 07, 2005 09:19 AM |
| Kokam 340 vs TP-860's? | Helicool | Batteries and Chargers | 14 | Mar 29, 2004 02:10 PM |
| 2s2p Kokam 1020's vs Kan 950's | SkyPyro | Batteries and Chargers | 2 | Aug 06, 2003 12:39 AM |
| RG14 vs RG15 who's faster | ramhornrctjd | Power Systems | 5 | Apr 25, 2001 01:14 AM |
