This thread is privately moderated by beenflying, who may elect to delete unwanted replies.
Old Apr 10, 2012, 09:03 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
My Fleet
Here are some pictures of my FBL fleet. I now have an X2, X5 and 500ESP SDC added, and also some heads have been lowered, since the January 2012 picture. The 550E is now running the Hobbymate HB800 (instead of the Align 3G), and the 450 Pro is using the 3GY v2. The 550E also now has a new canopy (my first with green) and yellow tail fins, to make it a bit more visible in flight. So far I really like it.
New to the fleet is a Walkera Super CP, an ALZRC Devil 450 FAST, and a 700E DFC HV. The Devil 450 is running a VCTRC 3GX (no resemblance to the Align 3GX) which flies well, and the 700DFC HV is flying a MSH iKon running at 7.4 volts. The iKon also flies well. IT has a self level feature, but as yet I'm not seeing any benefit from this, as I'm unlikely to have time to activate it before I crash. If I lost the tail it could be a benefit, as it would keep the heli level all the way to the ground.
All my ZYX's and ZYX-S' are now updated to v4 which has made the ZYX a very comparable gyro to the BeastX. Piro optimize is now actually better than the BeastX, and more like the 3GY v2 and the iKon. Great work from Tarot.
23rd October 2013:
One more FBL heli has been added to the FBL fleet (photo pending). The Gaui X3. I'm getting to like this heli more and more. It flies much bigger than a 450 and looks a lot bigger as well. Gaui have had a few hiccups, but are working through them. I'm running mine on 6S and it has good power.The tail drive is a bit noisy, but bearable, and relocating the TT bearing to close to half way made a big difference to the noise and vibration. Original OWS and TT are holding well. I used HobbyKing red thread lock, instead of the supplied green. In fact I didn't use Gaui's thread lock for anything. I used my usual Tarot 222 thread lock for the entire heli (metal to metal threads only of course).
I'm using a TGZ380 FBL controller on the X3 and it's performing very well. I'm still two minds as to whether I prefer the MB over the vbar. I like some of the extra adjustments of the vbar, but the MB always seems to fly just that little bit better, and I find myself trying to tweak the vbar to be more like the MB. I've gotten close with style at 100, and agility at 90. I'm still using flybar simulation at 20. I think this is very similar to the burst coefficient in the ZYX v4.
23rd July 2013:
Two more FBL helis have been added to the FBL fleet (photo pending). The 425 has been converted to FBL using an X4 head and a FU-Bar/VBar FBL unit. The other addition is a KDS Innova 550E also using a FU-Bar. I really like this heli, and KDS has stepped up in my standings, after hitting rock bottom with the EBar, and how they handled my faulty one. 15 flights on the Innova so far. Lost a tooth on the main gear after 3 flights, but the new one meshed harder seems to be doing fine. Time will tell if it lasts as well as the T550E.
The 3GY v2 (G31) has been shelved due to lack of development from robird, leaving the FBL unit somewhat inferior to my other FBL units, especially in the area of collective response and tail bounce. It's been replaced with a GV8000/VBar. The 500E Pro that had the GV8000, now has a FU-Bar, as the link connection position on the FU-Bar suited the 500 better.
14th February 2014:
I've decided to no longer contribute much to RCG. I posted here a lot and did mini reviews as a payback/thanks for all that I learned when I first came here.
I think the main reason is because of the RCG plus scheme and the scam that that turned out to be, as a money making venture for the RCG owner. Giving all of the top posters and top contributors free membership for one year and then expecting them to pay to retain plus, was something I can't forgive them for. For one it lead new members to believe that it was a cool thing to belong to, and secondly they expected many would not want to lose the benefits of being a plus member. From the sudden disappearance of plus members at the end of the one year, this idea failed, and I'm glad. The plus status on RCG now means nothing more than you can afford to pay for it. Even if someone is given it, it still means nothing, as no one knows that they didn't pay for it.
24th March 2013:
4th August 2012:
21st January 2012:
All of my helicopters:
Walkera Super CP
Gaui X2 FES Tarot ZYX, Gaui 22A ESC, Gaui stock scorpion motor, Ino-lab 212HB cyclic, DS95i tail
Gaui 425/X4 FES, VBar, YEP 100A ESC, TGY 500 H3126 1600kv motor, HK28012DMG cyclic, HK47110DMG tail
Gaui X5 FES MB v3, HobbyWing 100A ESC, Gaui stock Scorpion motor, Gaui stock servos
KDS Innova 550E, VBar, YEP 100A ESC, TGY 600 H37403 1180kv motor (15T), TGY 1257TG cyclic, HK47110DMG tail
250 DFC FBL, Tarot ZYX, HK 20A blueseries ESC, BL250SP motor, DS410 cyclic, DS95i tail
450 V2 FB Pro head, TGY 2218H motor, Henge 922 cyclic, InoLab 261HB tail
450 Sport DFC FBL, CX ZYX, Align BL35X ESC, 450M motor, DS410M cyclic, KST115 tail
450 Pro FBL, VBar, SkyWalker 40A UBEC ESC, ESC, 450M motor, DS410M cyclic, HK-732MG tail
450 Devil FAST, VCTRC 3GX, Align BL35P ESC, ALZRC 3800kv motor, TGY-212DMH cyclic, DS520 tail
500EFL Pro, VBar, Align 70A ESC, 500MX motor, HK28012DMG cyclic, FS9357D tail
500ESP SDC FBL, ZYX-S, YEP 80A, 500MX motor, HK28012DMG cyclic, MKS DS8910A+ tail
550E FBL, Hobbymate HB800, Align 70A ESC (7A ext BEC), 600M motor, DS610, HK47110DMG tail
700E DFC HV, MSH iKon, Phoenix ICE 120 HV (15A ext BEC), 750MX motor, 700H cyclic, 750H tail
Radio:
Hitec Aurora 9
beenflying is offline Find More Posts by beenflying
Old Apr 11, 2012, 06:24 PM
Libtekguy is offline
Find More Posts by Libtekguy
Essayons
Libtekguy's Avatar
United States, CA, Sacramento
Joined May 2011
I've been thinking about building a Trex 250. Did yours suffer from the Tail Wag Syndrome I've been reading about?
Libtekguy is offline Find More Posts by Libtekguy
Old Apr 11, 2012, 06:38 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It's certainly a fickle heli when it comes to the tail, same as the Gaui X2. Yes I had wag when it was a flybar heli. Even with a GP780 and a DS420. I changed the DS420 to an Ino-lab D201HB and it was much better. Later, I switched to the MKS DS95i (7mm arm) and the tail has been perfect ever since. Now it's FBL and using a Tarot ZYX. It flies really well.
Old Apr 11, 2012, 07:32 PM
Essayons
Libtekguy's Avatar
Joined May 2011
I planned on going to straight to a Microheli head with the same FBL controller. I was thinking about starting off with the 250 Pro kit. Have any experience between the two 250 kits out there? Do you think the pro would be worth the extra doh?
Old Apr 11, 2012, 08:15 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The only real difference with the 250 Pro (other than a nice canopy) is that they have moved the tail servo into the back of the frame. Unfortunately this doesn't leave a lot of room for the rest of the electronics. They are really relying on you using a gyro that only needs a sat.
I'm not sure if you could fit a ZYX-S inside the frame between the tail servo and the motor. If people are fitting the AR7200BX in the 250 (I haven't checked), then I suspect it would fit, with a sat on the outside of the frame.
Old Jul 01, 2012, 02:59 AM
andione1983 is offline
Find More Posts by andione1983
andione1983's Avatar
Australia, VIC, Melbourne
Joined Nov 2011
very nice heli collection there, i love them
andione1983 is offline Find More Posts by andione1983
Old Aug 04, 2012, 01:27 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, andione1983. Sorry I missed your post until now.
Old Oct 11, 2012, 04:18 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
How's about posting your setups? I'm always interested to hear how various servos and other parts work out, especially from users who fly lots of different equipment.
2Doggs is offline Find More Posts by 2Doggs
Old Oct 12, 2012, 07:54 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Good suggestion. I'll add that to the first post when I get a chance.
Old Dec 06, 2012, 11:26 PM
korts04 is offline
Find More Posts by korts04
korts04's Avatar
Australia, VIC, Cranbourne
Joined Jun 2012
hi buddy just checking out your heli collection there and I think you've got to much money there so how about spreading some of it my way.
korts04 is offline Find More Posts by korts04
Old Dec 07, 2012, 12:21 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Sure, here ya go, print as many as you want, on me.
Old Jan 08, 2013, 09:40 AM
DavidBrender is offline
Find More Posts by DavidBrender
Germany, BY, Vilsbiburg
Joined Jan 2013
First: nice collection, would really like to have such a fleet, too
Seccond: You said this is your FBL fleet ..-what does you FB fleet look like?^^
DavidBrender is offline Find More Posts by DavidBrender
Old Jan 08, 2013, 04:21 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks. Since the above photo, my FBL fleet has increased by 3 helis (Super CP, Devil 450 FAST and a 700E DFC HV). I now only have two FB helis. A 450 SE (Pro head conversion) and a Gaui 425. I have an X4 head and an HB800 waiting to go in the Gaui 425.
Old Jan 16, 2013, 02:49 AM
korts04 is offline
korts04's Avatar
Joined Jun 2012
Do you fly any nitro or just all electric
Old Jan 16, 2013, 03:04 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
All electric, since I got back into the hobby. Before that it was all nitro planes, one nitro heli and two petrol helis.
For Sale Thinking of selling off my large fleet as a lot for LPU thannamhbfp Aircraft - Electric - Airplanes (FS/W) 2 Apr 29, 2012 10:54 AM
Discussion Additions to my fleet: Minimoa 4.8, Reihar-II, DFS Habich & DG-1000 Esprit Model Scale Sailplanes 2 Mar 24, 2012 09:01 PM
