Old Apr 10, 2012, 05:05 PM
jbb is offline
jbb
Find More Posts by jbb
jbb
Joined May 2006
120Sr with AS3X from the mCPx - Why can't it be done?
Searched and searched and I can't find anyone who has put the AS3X on the 120SR, so the question comes to mind, if it could be done someone would have done it by now...so why can't it be done?
Now I'm not saying it has to be CP...it can be FP and use the stock 120SR blades if that's all we can do.....or make it CP with the head from a different CP flybarless heli (maybe from the Solo Pro 180 3d?)
The point is, get rid of the flybar and add the AS3X system, Fixed Pitch is fine.
What are some potential issues? Can anyone out there give some answers to these? I really don't know much about the electronics and how a different motor or servo will burn out or not work at all etc....
1) Attaching the 3 servos to the frame in the correct place (like the mCPx has them positioned)....nah, I think that's workable...it is an issue but I think it can be solved....I even thought heck, why not cut out the center of the 120SR frame and 'plastic weld' in the mCPx frame...
2) mCPx servo aren't strong enough....I can see that, so
3) Use the 120SR servos, but just connect them to the AS3X system (will the mCPx system be able to push the 120SR servos? Or would something burn out?
31/2) The 120SR servos aren't even up to the task of going flybarless....so, what other servos out there would work?
4) Motor....maybe the 120Sr motor would burn up the AS3X from the mCPx....idk but sure that sounds reasonable....but why not just use a brushless setup, then the current isn't going through the board (?)
Again, I'm not looking for a 3D capable machine....just want to get the AS3X onboard somehow, get the flybar off, and fly around in 2D and even Fixed Pitch.....then mabey find a CP solution....and then think about 3D after all that is sorted.
I saw a Youtube out there once where someone put the mCPx AS3X system onboard a 450....but why isn't anyone doing it on the 120SR? What is the critical path that isn't working out?
Thanks in advance to anyone who listens, and knows the answers!
(not really looking for "well, I think this" and "well, probably that".....looking for "you could do this, but that would cause this to fry and that will blow up...for sure"...)
jbb is offline Find More Posts by jbb
Old Apr 12, 2012, 04:38 PM
jbb is offline
jbb
jbb
Joined May 2006
LOL, never mind!
http://www.bladehelis.com/Products/D...ProdId=BLH3780
But I still think it'd be a cool project...and gotta be cheaper than $280 to create
Old Apr 12, 2012, 07:18 PM
SeaDog-Chief is offline
Find More Posts by SeaDog-Chief
Joined Oct 2008
Maybe HH will pay you for your suggestion. My guess is that it has been in the works for a while.
SeaDog-Chief is offline Find More Posts by SeaDog-Chief
Old Apr 13, 2012, 01:59 PM
jbb is offline
jbb
jbb
Joined May 2006
This guy put the mcpx board into a HK 450
http://www.rcgroups.com/forums/showt...0#post18035917
why no one tried with a 120?
even though the 130x is out, I think the price is kind of high and worried about the tail gears.
Discussion why is the "Why is the "Can anything be done about gas prices?" thread closed? 62pilot Life, The Universe, and Politics 24 Sep 19, 2012 01:28 AM
Discussion This can be done with RC Belive me Kr1st1an Aerial Photography 5 Mar 09, 2012 10:54 AM
Discussion Can LDS be done on a DLG or is top drive as close as we can get? Fly2High Hand Launch 11 Feb 03, 2012 03:42 PM
Discussion $500 to build a T-rex from scratch, can it be done. I already have Gyro, Rx and servo wac Mini Helis 13 Jun 03, 2006 12:46 AM
Yippee! Here's what can be done with plans from TOG and EWO(thanks for the great designs) JAM Foamies (Kits) 551 Jan 16, 2005 01:02 AM
