Old Jun 03, 2012, 10:40 AM
savneo is offline
Find More Posts by savneo
savneo's Avatar
Cyprus
Joined Mar 2012
Thanks for all the advice, I will try to raise the amps slightly to prob 50amps. My ESC is only 60amp continuous .
savneo is offline Find More Posts by savneo
Old Jun 20, 2012, 03:18 PM
savneo is offline
savneo's Avatar
Cyprus
Joined Mar 2012
Happy to say that my turn left wing is holding up to the 5s (approx 800w). I just turn a little wider, it tracks on rails the faster I go.
I'm may make a carbon spar by cutting a 2mm slot along the wing and then pouring epoxy in it then imbed carbon tape in the slot leaving some to pertroude out to fold and make the spar into a T shape. I'm doing it this way because of the dihedral in the wing.
Old Jun 20, 2012, 03:46 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
I wouldn't have thought that the part of the wing that has the dihedral in it would need the reinforcing. But I could be wrong.....
But you could put a rod or some square section tube in across the main part of the wing and then do as you suggest on the 2 tips. It'd just make the job a little easier IMO.
feefo is offline Find More Posts by feefo
Old Jun 20, 2012, 04:10 PM
savneo is offline
savneo's Avatar
Cyprus
Joined Mar 2012
The wing has a bend from the middle then another further along so a straight spar will not work. That is why I may try and form the spar into the wing with epoxy and carbon.
For Sale Simprop Turn Left JPHen Aircraft - Electric - Airplanes (FS/W) 10 Sep 29, 2005 06:55 PM
Sunracer or Simprop Turn Left JPHen High Performance 3 Jan 22, 2005 06:00 AM
Simprop Turn Left - some translation needed Vic Peh High Performance 23 Oct 13, 2004 02:31 PM
Simprop Turn Left Rob AR High Performance 5 Oct 03, 2004 12:38 PM
Yippee! Turn Left Simprop, Got it today. Stefan.s High Performance 12 Sep 30, 2004 08:45 AM
