Old Apr 10, 2012, 01:44 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Re inventing the internal combustion engine
Claims up to 50% reduction in fuel consumption.
This actually looks like it would work.
http://video.foxnews.com/v/3929622/r...ing-the-engine
UlteriorModem is offline Find More Posts by UlteriorModem
Old Apr 10, 2012, 01:54 PM
P-51C is offline
Find More Posts by P-51C
Reserved Parking
P-51C's Avatar
Joined Jun 2004
I am curious about the power output compared to a "conventional" engine as well as the lifespan comparison.
P-51C is offline Find More Posts by P-51C
Old Apr 10, 2012, 02:49 PM
ENGINETORQUE is offline
Find More Posts by ENGINETORQUE
ENGINETORQUE's Avatar
United Kingdom
Joined Feb 2005
Ancient - Puch (Austrian company who made a lot of bikes) had a 'split single' two-stroke eons ago!
There you go - it's all here http://en.wikipedia.org/wiki/Split-single
ENGINETORQUE is offline Find More Posts by ENGINETORQUE
Old Apr 10, 2012, 02:52 PM
P-51C is offline
Reserved Parking
P-51C's Avatar
Joined Jun 2004
The guy in the video said it was not an original idea, just that his father had made some "innovative" improvements.
Modern refinements might make it worth looking into once again, no?
Old Apr 10, 2012, 02:56 PM
United Kingdom
Joined Feb 2005
Yep I did catch that
Well if you check out some of the big beastly outboard motor two-strokes - same thing, with sofware controlling the injection and ignition Mercury have done some amazing things with the two-stroke engine.
It's interesting but internal combustion engines are at their peak development and we're still stuck on 4 stroke valved engines - even formula one!
Old Apr 10, 2012, 05:36 PM
retread2 is offline
Find More Posts by retread2
Joined Jan 2009
Who could forget the twingle?
retread2 is offline Find More Posts by retread2
Old Apr 10, 2012, 06:03 PM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
It looks like a supercharged two-stroke diesel, but one cylinder is the supercharger instead of a Roots blower.
Is it gasoline fueled?
typeRA is offline Find More Posts by typeRA
Old Apr 10, 2012, 08:04 PM
jumpinjo is offline
Find More Posts by jumpinjo
Low, slow and dirty
maine
Figures the american car companies aren't interested.
Boy if that type engine can deliver. People wouls save a great deal. Just think less fuel used and bought , less in taxes paid.and less polution. "Our gov't will have none of this"!...It will hurt our oil companies profit margins and might help us get away from those crazy people in the middleast. we cant have that now can we.
Besides, the american car companies can just ask for another Bailout when needed....
jumpinjo is offline Find More Posts by jumpinjo
Old Apr 11, 2012, 03:51 AM
United Kingdom
Joined Feb 2005
I don't think that's the bottom line - most of the Euro hatchback Diesels now turn nearly 70 MPG from 2 litres and 150 BHP, so efficiency is way up compared with the V8 petrols of a few years back!
Hybrids are making progress too - Diesel Hybrids now from France!
At the end of the day any I/C engine is simply a pump - fewer moving parts mean less friction to sap power - containing the heat means less loss thermally, the answer for I/C engine efficiency is to run the engine as hot as possible and reduce the frictional losses - I don't see this engine achieving either!
Old Apr 11, 2012, 04:40 AM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
It's still inherently a two stroke, with a possibly higher specific output than an equivalent four stroke, but with the disadvantages of lower fuel efficiency and dirtier emissions.
martin richards is online now Find More Posts by martin richards
Old Apr 11, 2012, 05:24 AM
United Kingdom
Joined Feb 2005
The emmissions thing shouldn't be worse than a four-stroke if the burn is achieved as envisaged - the only reason piston ported two strokes are so messy is that A - they are 'lubricated by accident' and B the overlap with the porting and tuned exhaust system means that effectively (efficiency wise) they are a one speed device!
A great deal of the fuel put through a two-stroke is donated to the atmosphere from the exhaust and never gets burned - in essence an engine that fires every stroke should be able to outperform one that fires every other!
Interesting stuff - I've been 'messing' with the subject for decades and still the poppet valved four-stroke remains king and that's a 'rubbish' idea mechanically!
Old Jun 18, 2015, 04:55 AM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
One of the highest HP aircraft engines produced rotated the cylinder liner instead of using poppet valves. The engine and the plane were just too late for WWII, and soon outdated by jets.
chuck75 is offline Find More Posts by chuck75
Old Jun 18, 2015, 05:33 AM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
They say efficiency posible of 35% to 50% compares well to present days typical of 20% from modern day car engines .
The rule to check efficiency is simple enough 1 liter of gasoline fuel is about 10,000 watts . Most modern larger generators 10 kilowats or more will give you the fuel cosumption at half speed and full speeds and that show typicaly about 20% efficiency
In car use with the rolling resistance the air resistance and so forth best case is typicaly 10% efficiency at 55mph on the high ways and typical for car is 5% effientcy
This new engine therfore might bring the new version engine and car efficiency up to closer to 20% or at least double the MPG of the car
Ralf
treehog is offline Find More Posts by treehog
Old Jun 18, 2015, 07:47 AM
Punkie is offline
Find More Posts by Punkie
Love & a Molotov cocktail
Punkie's Avatar
on a boat on the river cam
Joined Jan 2005
Bristol Hercules sleeve valve radial animation (1 min 1 sec)
Bristol Hercules sleeve valve radial engine (2 min 49 sec)
Punkie is offline Find More Posts by Punkie
Old Jun 18, 2015, 09:40 AM
madsci_guy is offline
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
The P&W R-4360 produced more than sleeve valve engines, as did the Wright R-3350.
According to Wiki.
PS, forgot, Napier Sabre, 3,500 hp, not bad at all for an inline engine.
Rolls Royce Eagle, 3,200 hp
Centaurus, 3,000 hp.
R-3350, 3,700 hp
R-4360, 4,300 hp
madsci_guy is offline Find More Posts by madsci_guy
Discussion Radical RC "Mini Intern Trainer" radicalrc Parkflyers 151 Jun 14, 2014 01:19 PM
Sold Combustion chamber (1400 size) $45 shipped USPS First Class xwingnut Aircraft - Fuel - Jets (FS/W) 3 Apr 12, 2012 06:33 PM
Cool Old Time Actress invented Spread Spectrum mexico Other Websites 2 Apr 03, 2012 03:31 PM
For Sale Moki 61 RE pattern engine 3DVictim Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 16, 2012 10:43 AM
For Sale Nib picco 60 re abc rear exhaust pattern engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 4 Feb 07, 2012 06:40 AM
