Old Apr 10, 2012, 11:21 AM
wkm1's Avatar
Joined Apr 2010
Rokie question: Eagle N6 and wobbling tricopter
Hi all,
built my first tri and still not flying
I can handle real planes and flew perfect quadro PhoenixRC simulator.
DX6i is set as acro. Ground test are all perfect. Made all setups as required.
Tried 10" and 8" props and replaced the Eagle N6 with an Eagle N6v
motors are perfectly aligned.
first test: Eagle N6, 10" x 4.5 prop and A2216KV880 motor
http://youtu.be/U4flOgFDD1A
remark: my friend said: reminds me, like my wife, when I say I am going out with my friends...
second test: Eagle N6v2, 8" x 4.5 prop and A2216KV880 motor
http://youtu.be/TBEb9lA6aqQ
Tried this one in the green. Starts off and swoops to the side, forward, is
completely erratic.
my guess - the motors are too big ?
why is it lifting all the time on one side (either left or right) first ?
why does the Eagle control not balance this ?
any clue for help is welcome
wolfgang
wkm1 is offline Find More Posts by wkm1
Old Apr 10, 2012, 11:50 AM
Mortimer's Avatar
Joined Apr 2010
This video might help you:
Multicopter PI-tuning: How to recognize different settings. (7 min 52 sec)
Mortimer is offline Find More Posts by Mortimer
Old Apr 10, 2012, 11:55 AM
United Kingdom
Joined Nov 2008
Are you changing the gyro gain at all ?
At a guess, looks like gyro gain too high on 1st video, but way too low on 2nd !
Mike Barton is offline Find More Posts by Mike Barton
Old Apr 10, 2012, 12:38 PM
wkm1's Avatar
Joined Apr 2010
pitch, roll and yaw had been in all flights set to 50%, as the manual
recommends as an initial setting
Old Apr 10, 2012, 12:40 PM
wkm1's Avatar
Joined Apr 2010
[QUOTE=Mortimer;21289880]This video might help you:
unfortunately not. Impressive video, but my
roll, pitch and yaw gain had been set to 50%
the KK board and the EAGLE N6 has only those 3 controls.
What is P-gain and I-gain ?
Old Apr 10, 2012, 01:17 PM
Belgium
Joined Dec 2010
Do not forget the stick centering & ESC calibration ( you have to do it only once)
The manual says to start with low gain for first flight , but then it goes in any direction; try to start with gyro at +/-65% and back down until it is ok for you.
Julkabas is offline Find More Posts by Julkabas
Old Apr 10, 2012, 01:29 PM
wkm1's Avatar
Joined Apr 2010
has been done, as I said in my first post
Old Apr 10, 2012, 04:42 PM
Mortimer's Avatar
Joined Apr 2010
Originally Posted by wkm1 View Post
"This video might help you:"
unfortunately not.
This video has been made by KapteinKUK, which is the creator of the KK board.
Pots are for G, gain.
Old Apr 11, 2012, 07:31 AM
wkm1's Avatar
Joined Apr 2010
He is talking about 'I-gain' and 'P-gain' (?) in his video for a quad.
I am setting up a tricopter. My Eagle board has one (!) MEMS gyro to control 'Pitch', Roll' and 'Yaw'.
Therefore there are 3 pots on the board to set the gain for 'Pitch', Roll' and 'Yaw'.
Same on a KKmulticontroller v.5.5 "Blackboard": 3 pots, to change the gain for Pitch, Roll and Yaw.
Can someone please explain, what does he mean, if he is talking about I-gain and P-gain
Which pot do I have to turn, changing the I-gain or the P-gain ?
Old Apr 11, 2012, 07:37 AM
United Kingdom
Joined Nov 2008
<snip>
that video doesn't apply to your board - you only have normal Gyro gains (or 'P' term) for each axis.
Old Apr 11, 2012, 09:16 AM
Joined Sep 2010
Those oscillations mean the gain is set too high on your gyro. So, in the first video, the oscillations on the roll axis, means you need to turn down your roll gyro's gain.
In the second video, the drift to the left, could be stick centering, but that really is the same as trims. You will have to apply trims to get it to remain somewhat level.
Remember, with a gyro only control board, all the board does is "resist rotation." That doesn't mean it will hold the copter level to the ground. It will try to maintain whatever orientation it is in, until you give it commands from the radio to roll. It's up to you controlling the radio to tell it where to remain level with the ground so to speak.
So, if your radio isn't trimmed, and its telling it to roll to the left, it's going to roll to the left and keep rolling as long as your radio is giving a roll left command. It's very important to get your radio trimmed properly for stable/steady flight.
bladeaudio is offline Find More Posts by bladeaudio
Old Apr 11, 2012, 11:01 AM
Mortimer's Avatar
Joined Apr 2010
Read this: http://en.wikipedia.org/wiki/PID_controller
and this: http://www.rcgroups.com/forums/showthread.php?t=1375728
PID (Proportional, Integral and Derivative gains) are included into KK board firmware.
For example, in V 4.7: http://www.rcgroups.com/forums/showp...5&postcount=73
Originally Posted by kapteinkuk
Roll pot now controls P-term gain on roll/pitch axis.
Pitch pot now controls I-term gain on roll/pitch axis.
Yaw pot controls P-term on yaw axis as before. Yaw axis I-term is fixed at 0.2
Suggested initial setup:
P pot at 50%
I pot at 0% (it can be left at 0% since it does not have a secondary function.
Yaw P pot at 50%
Trim it level.
Adjust P (roll/pitch) to your liking.
Old Apr 11, 2012, 02:33 PM
wkm1's Avatar
Joined Apr 2010
@Mortimer
Thanks, this opened my eyes and my mind. If it will help my tricopter... let's see, I will try
Old Apr 11, 2012, 02:42 PM
Joined Sep 2010
Ummm, unless I missed something he has an Eagle N6 control board. Does that run KK firmware? Otherwise the information about the KK PID doesn't apply.
Old Apr 11, 2012, 03:04 PM
Mortimer's Avatar
Joined Apr 2010
wkm1 wrote "the KK board and the EAGLE N6 has only those 3 controls."
KK board informations are easily avalaible, it's not the case with Eagle N6.
However, it is highly probable that PID gains are also included in N6 firmware.
New Product EAGLE N6 Multicopter Controller bdpowers Multirotor Talk 281 Nov 19, 2012 09:26 AM
Discussion Eagle N6 v2 Power wiring ramall79 Multirotor Talk 3 Apr 06, 2012 09:48 AM
Sold KK 5.5 and Eagle N6 never used. vewdew Aircraft - Electric - Multirotor (FS/W) 2 Mar 15, 2012 11:59 PM
Discussion Building my first tricopter! Questions faheja Multirotor Talk 1 Feb 23, 2012 09:51 PM
Discussion Eagle N6 Controller board ferrocium Multirotor Talk 4 Jan 15, 2012 06:41 PM
