Old Apr 10, 2012, 02:20 AM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Help!
LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark?
I have been using eagletree OSD for FPV and have been somewhat unhappy with their setup. I recently received an Eagleeyes kit with the readymade Antenna tracker and am considering switching systems.
I have a Skylark Tiny OSD and have read very many good things about their tracker, and its clean appearance and setup. Would it be a wise idea to switch to the Skylark Trace AAT/OSD combo and returning/selling my existing eagletree setup?
Regarding LRS and UHF. I am very fond of my Aurora 9 Hitec radio and its built in telemetry functions, but dislike its lack of RSSI. I just sold off all my Spektrum gear and am considering choosing a Transmitter system/setup for FPV for the long term.
Does anyone know anything of the XPS (extreme power systems) modules for the hitec aurora 9? Are they just as good as a UHF setup? They claim up to 5 miles http://www.xtremepowersystems.net/
If I was to go with a UHF setup I would lose my built in Aurora telemetry I assume? I have also considered a 2.4ghz booster with a patch antenna mounted to my tracker. I currently run 1.3ghz dual video receivers with diversity and a 300mw transmitter with a V antenna on the quad, I have not decided on a setup my first FPV plane. A Skysurfer/Bixler 1400mm...
http://www.bananahobby.com/1937.html
I own a police P71 crown Victoria cruiser and would like to convert it to a mobile FPV flight station. It would be amazing to use the 2 3/8 holes and the 1 3/4 hole as antenna locations. I could put the antenna tracker on the roof while parked.Do they make antennas I can use for this application?
The amount of info regarding LRS and Antenna tracking is overwhelming, but I have read about the Scherrer units plugging into the training ports on the aurora 9.
Thanks for the info and sorry for the babbling, my painkillers make me a bit skittish at night
Cheers,
D
daign is offline Find More Posts by daign
Old Apr 10, 2012, 02:41 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
i would suggest to go with the eagle tree osd together with the skylark AAT. Right now the AAT is the best tracker i have ever seen and i think it it can work together with the et osd using that data modem.
nabazul is offline Find More Posts by nabazul
Old May 17, 2012, 03:36 PM
mykwilwin is offline
Find More Posts by mykwilwin
United States, CA, Tustin
Joined May 2011
im currious about the xtremelink myself, did you try? im looking for more distance
Cheers,
D
i use a hitec qpcm and a mpx royal evo 9... just over a mile out and close to 5 mile with xps is good enough if they can do that
mykwilwin is offline Find More Posts by mykwilwin
New Product Turnstile UHF RX antenna for your LRS IBCrazy FPV Equipment 249 Jan 21, 2016 10:13 PM
Help! Aurora 9. Want to upgrade to a LRS UHF setup with RSSI at the receiver.... daign FPV Talk 0 Apr 04, 2012 11:54 PM
Discussion LRS UHF TX antenna Choices? REcommendations? whosthebaddest FPV Talk 7 Dec 01, 2011 09:40 AM
Discussion 3 steps to make Skylark Auto Antenna Tracker work with other OSD? skylarkfpv FPV Talk 0 Oct 31, 2011 09:41 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
