This thread is privately moderated by DPage, who may elect to delete unwanted replies.
Old Apr 09, 2012, 04:01 PM
Joined Sep 2003
Trader Rating: 29
*Reduced* New Mounted but Unused Saito FA-180 GK Golden Knight 4 Stroke Engine
This is a new never fueled or run Saito FA--180 GK Golden Knight 4 stroke glow model airplane engine. The engine was mounted on a plane and has some scraped off black coating from sloppy tool use during the mounting process. There is also some slight corrosion on the surface of the muffler. Send me your email and I can send additional pics of these marks.
I do not have the box, but will include the instructions, and tools along with a new unused engine and muffler.
$375 plus $15 shipping.
Dan
Saito Specifications:
SAIE180GK
This is the Saito 180 Golden Knight 4-Stroke Engine. This includes the muffler, manual, and tools. This engine features the awesome color scheme you can see in the picture, and also has the great sound, power, and performance Saito engines are known for. These have the full factory warranty.
Features:
Baked on, gloss-black finish with shiny gold valve covers.
Turns a 16x8 prop at 9,600 rpm on 15% fuel.
Will fit into most 1.20 - 1.50 size airplanes.
AAC construction for lighter weight and increased longevity.
Specifications:
Type: 4-stroke
Displacement: 1.80 cu in (29.10 cc)
Bore: 1.41 in (36.00 mm)
Stroke: 1.12 in (28.60 mm)
Cylinders: Single - Chrome Plated
Engine (Only) Weight: 31 oz
Crankshaft Threads: M8x1.25mm
Benchmark Prop: 16x8 APC @ 9,300
Prop Range: 15x8 - 18x6
RPM Range: 2,000 - 10,000
Fuel: 10%-30% Synthetic
Mounting Dimensions: 138 x 69 x 135 mm
Muffler Type: Cast
HP: 2.8
Cylinder Type: AAC
Carb Type: Barrel, 2 Needle Valve
Crank Type: Ball Bearing
Saito's FA-180 engine is fast becoming the pilots choice for powering 1.20 size airplanes. The FA-180 offers a 20% displacement increase over the popular Saito FA-150. What does this mean? How about a 8% power increase over the FA-150 and an awesome 14% power increase over the FA-120. And what’s more the FA-180 fits in the 1.20 size mount. So if your old 1.20 just doesn’t have what it takes, replacing it with the Saito FA-180 is no problem. Simply put the FA-180 is the most powerful in its class.
With the 180 we could hover the 13-3/8 pound Stick at just under half throttle then, punching to full, the Stick would blast off like a rocket and accelerate to approximately 50 mph straight up in just a few short seconds! We could do multiple vertical snaps with the Cap, then pull out on the vertical up-line and accelerate straight up.
J. Adams
Horizon R&D Department
Saito’s 1.8 cu. in. four-stroke, the FA-180, is based on their popular and powerful FA-150. The new FA-180 is the largest displacement four-stroke single that will fit popular 1.20 size aircraft. The FA-180 has the same mounting dimensions and mounting hole-to-prop washer length as their 1.20 and 1.50 with only the head and valve covers being slightly raised an additional 2mm, so it will mount right in most 1.20 size airplane applications. At 31 ounces, the total weight of the 180 is just an ounce more than Saito’s 150 with mufflers.
To achieve the additional 20% displacement, Saito has increased both the stroke 1mm (to 28.6mms) and the bore 2mm (to 36mm) over the 1.50. To feed this overgrown giant, the carb bore has been increased to 12mm and the internal openings in the exhaust have been enlarged considerably for freer breathing. And, like other Saito engines, the 180 is available in the standard natural finish or as a GK (Golden Knight) version with a high gloss black case and gold valve covers.
On the bench we were anxious to test the FA-180 and compare it to the many Saito 150s that we had been flying. On 15% fuel with an APC 16x8 prop we recorded a 500 rpm increase with the 180 over the 150, with the 180 peaking out at 9,400 rpms.
For performance models, our staff has been using 30% helicopter fuel in the larger four-strokes for years, and we’ve found many pilots around the country who do the same. The engines run great on this fuel with no overheating issues, plus the power gain is significant. In flight, this fuel runs great and is easy to tune, giving a good transition. On 30% heli fuel, the Saito 180 turns the APC 16x8 prop at 9800 rpms — that’s 400 rpms more than with the 15% fuel.
The 180 is proving itself to be a reliable performer and easy starter. And, unlike many other four-strokes, it doesn’t seem to be too critical of the choice of plugs. We’ve tested Hangar 9’s four-stroke plug, K&B’s four-stroke plug and O.S. F plugs, and we couldn’t tell the difference in idle, transition or top- end performance.
DPage is offline Find More Posts by DPage
For Sale Saito FA-180 Golden Knight 03svtsnakevert Aircraft - Fuel - Engines and Accessories (FS/W) 14 Apr 02, 2012 05:36 AM
Sold New Unused Saito FA-100 0 Stroke Engine DPage Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 24, 2012 09:42 AM
Sold *Reduced* New Mounted but Unused Saito FA-180 GK Golden Knight 4 Stroke Engine DPage Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 23, 2012 05:38 PM
Sold "Saito FA .91S 4 stroke Golden Knight Series!!" dhf23 Aircraft - Fuel - Engines and Accessories (FS/W) 6 Feb 24, 2012 10:16 AM
Sold New Saito FA-91s Golden Knight 4 Stroke *** comes with Free Motor mount** Joe Pierson Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 28, 2009 09:03 PM
