Old May 14, 2012, 09:15 PM
helipup is offline
Find More Posts by helipup
Ban Gravity
helipup's Avatar
United States, VA, Richmond
Joined Jul 2010
Quality
I'm thinking of ordering one. How is Hobbico's quality?
helipup is offline Find More Posts by helipup
Old May 15, 2012, 03:51 AM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
really the questions is how is flyzones quality. Working at a hobby shop and seeing lots of hobbicos products & flyzone products they are good and looks like it's getting better. The real test is when people get the the new glider and report back here. I really like the finish of the foam. Dense, hard and very smooth.
Lammergier is offline Find More Posts by Lammergier
Old Jun 12, 2012, 01:02 PM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Quality
I own both the Parkzone Radian and Multiplex Easy Glider Pro and have been in modeling for about 10 years. I have flown powered gliders for about 5 years. I happen to live in Champaign and fly at the same field Hobbico is testing many of these planes. I have looked at the progressive quality of Flyzone planes that Hobbico is active in design and am impressed. The new Flyzone Calypso glider is no exception. The Hobbico team has tested this model to assure of it's performance. I handled and looked over the Calypso and found what appears to be a rock solid glider. I don't think you can go wrong here, Hobbico has a winner on their hands.
Phoenex is offline Find More Posts by Phoenex
Old Jun 13, 2012, 10:42 AM
george@dream-flight is online now
Find More Posts by george@dream-flight
Wind Powered
george@dream-flight's Avatar
United States, CA, Goleta
Thank you sir!
george@dream-flight is online now Find More Posts by george@dream-flight
Old Nov 14, 2012, 03:11 PM
ddruck is online now
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
The only thing you did not say how it flies compare to the other gliders you own. Do you have an honest opinion how it stand up to a Radian / or Radian Pro or Easyglider Pro? I own all 3 and would like to see a comparison by someone that flown them, not the usual gushing by the makers. General Chinese EPO foam by the way is not even close to strength of Elapor foam in Multiplex planes but I would say better then the mushy stuff they make Radians out of and technically they are all a type of EPO foam.
ddruck is online now Find More Posts by ddruck
Old Nov 14, 2012, 04:49 PM
Phoenex is offline
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
I have not flown the Calypso.
Old Apr 25, 2013, 09:42 AM
john97618 is offline
Find More Posts by john97618
United States, IL, Aurora
Joined Oct 2012
I need help fixing Calypso servo
I hope I can explain my need correctly. I flew and crashed my Calyso on its maiden flight. One of the aileron servos seems to have stripped. I am not sure why. Mute point. I need to replace it. I know I can order a replcement. The question is How does one replace the servo in the wing? I have disconnected it but the connector wire runs through the wing, inside, and I need to get it out of course. It is housed under what apperas to be a re-glued cutout. Do I or would you cut the cut out out of the wing to remove the connector cable? I am worried about putting it back in. Or do I just cut a slot in the wing and pull the connector cable out by lifting out of th enewly cut slice. I need suggestions.
I also don't kow if this is the correct place to inquire.
john97618 is offline Find More Posts by john97618
Old Apr 25, 2013, 10:35 AM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
sorry didn't read your question right when I first wrote this response.
I think you will have to cut into the foam to remove the servo or order a new wing (arrrggg...)
Tower Hobbies has a direct replacement.
The HiTec HS-55 is also a direct replacement
go to the towerhobbies or esprit models web sites:
ripacheco is offline Find More Posts by ripacheco
Old Apr 25, 2013, 11:57 AM
Phoenex is offline
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
i am not sure how hard it is to pull out the foam inserts, i would try that first. If they appear to be in so well that they tear, i would make a six inch or so slit cut the servo wires and soldier a new servo wires to that long extension to replace the servo.. Be carefull correctly match the wires.
Old Apr 25, 2013, 01:35 PM
Joined Oct 2012
Servo replacement for ailerons
You guys were great for responses. but I have one more question. If I buy hte hs55 servo, should I replace both of the servos for the ailerons or can I get buy with just replacing one. would I have to worry about a difference in torque for instance.
Old Apr 25, 2013, 01:50 PM
rip
ripacheco's Avatar
Joined Jan 2013
I personally would. Mainly because I dislike mismatched, patched up things and since I'm a lab-rat I measure everything. (hence me saying change the whole wing [don't do it is just my opinion]).
Make sure you have right glue (shoe goo) to glue them back in there.
Hopefully you have a very clear idea why you had the mishap to start with.
Old Apr 25, 2013, 01:51 PM
rip
ripacheco's Avatar
Joined Jan 2013
I'd see about building a "box" made out of balsa or something to replace the messed up servo "hole".
Would the structural integrity be affected? It would be just cosmetic? Questions to keep in mind.
I would buy a new wing. But I know that is an over-reaction.
Old Apr 25, 2013, 01:56 PM
Joined Oct 2012
Personally I think it was me. Wanted to fly it so bad that I think I went up in to strong of winds. Then a tree jumped out in front of me. Things happen fast when you are in trouble. Live and learn. Maybe I should stick to trainers. OH! I crash them to.
Old Apr 25, 2013, 02:12 PM
rip
ripacheco's Avatar
Joined Jan 2013
This is not your first plane and you are just learning to fly right?
I dont' consider this plane a teach-your-self kind.
If so find an instructor at your local RC club.
Old Apr 25, 2013, 02:34 PM
HARD DRYVE is offline
Find More Posts by HARD DRYVE
Puerto Rico, MayagŁez
Joined Jan 2011
I agree, it works as a trainer but not a teach-yourself trainer.... full throttle for example, will make it go straight up ballistic (even requiring some down elevator) and power off gliding and thermalling requires another set of skills... If this is your first plane avoid abrupt throttle changes and do get a instructor/buddy to help you. Cheers!
HARD DRYVE is offline Find More Posts by HARD DRYVE
Discussion Hobbico Calypso?? mpotter187 Electric Sailplanes 1 Mar 23, 2012 10:14 PM
Discussion Avimodelli Calypso Mk3 for SALE!? And Tango? And as many as you might want? mixerfix Classic Pattern Flying 0 Feb 23, 2012 10:10 PM
Found want to trade flyzon select scale for micro cub hendleyusmc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 25, 2011 12:38 AM
Wanted Calypso contest / calypso sport *Harry* Aircraft - Sailplanes (FS/W) 2 May 23, 2010 03:59 AM
Wanted Calypso contest / calypso sport *Harry* Aircraft - Sailplanes (FS/W) 1 May 20, 2010 12:12 PM
