Old Apr 09, 2012, 03:14 PM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Question
Silkspan and Polyspan on fuselage
Howdy All,
Getting ready to cover my fuse, soon I hope..
Aiming to cover the planked areas with silkspan, then the open stringer areas with Polyspan for strength and puncture resistance.
What is the best technique to use, where the two different covering media merge? Hoping to have a seamless finish.
I expect you can finish and sand the silkspan down to a feathered edge but I've never used Polyspan before and I'm not sure about feathering the edges.
Please see my picture for details.
Thanks much for any advice.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Apr 09, 2012, 03:24 PM
dgliderguy is online now
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
My recommendation is to cover the whole thing with Polyspan... one piece for the left side and one piece for the right side. Polyspan can be stretched like plastic film if you lay it down with the help of a covering iron. I use nitrate dope, or sometimes polycrylic (Minwax), for sticking it down.
If you must combine the two materials, you can smooth out the overlaps with vinyl spackle prior to prime and paint.
dgliderguy is online now Find More Posts by dgliderguy
Old Apr 09, 2012, 03:40 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Don't try to sand/feather, Poly-Span, Bill. It is a polyester fiber, and will not sand. You will end up with a raised fiber, that is hard to get rid of. I have fine sanded it with VERY worn 400W/D. But very lightly.
Poly-Span seams can be hidden with a strip of feathered silk-span. And I agree with gliderguy, the texture of both mediums is very close. and equal to using a grade of med silkspan as far as weight is considered. So, just use the poly-span, and then no worries of seams.
My Stahl Apache is 100% Poly-Span. And you don't need expensive aircraft nitrate to seal poly-span or silk-span. Regular hardware store lacquer works just fine, thinned 50%, or more. I did a thread on silk-span. The sealing of poly-span is the same.
http://www.rcgroups.com/forums/showthread.php?t=1598074
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Apr 09, 2012, 03:45 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
I used the polyspan/silkspan method on my Bucker Jungmeister, and it came out great. Apply the polyspan over the open framework first, then the silkspan on the solid sections , leaving about a 1/4"-1/2" overlap. You can sand the silkspan to a feather edge and have it magically disappear, showing no seam at all. You can't sand polyspan, because it will raise frizzies that are impossible to remove with more sanding. Have a look at post #252 on this page.
I applied the polspan by ironing it on using Sig Stix-it. Then I applied 2 or 3 coats of clear nitrate dope on the polyspan and all the balsa. Then I applied the silkspan wet, doping only around the perimeter. Once it has shrunk and was dry, I applied 4 more coats of clear dope, carefully feather-edging the seam each time with 400 grit paper.
Using Polyspan over the sheeted sections does work fine, but if you want an absolute smooth, metal like surface, I would go with silkspan. I found I can't get polyspan to look as smooth on sheeted areas. When it's all done, it looks a little like this:
Wolpertinger is offline Find More Posts by Wolpertinger
Old Apr 09, 2012, 04:34 PM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
Von,
That Bucker is a nice piece of work. Good skills there, man. Well worth the obvious investment in time and patience.
Old Apr 09, 2012, 06:14 PM
Joined Jul 2011
Looks like I'll follow Von's method, Poly then the Silkspan.
His Bucker is gorgeous.
Shinny side up on the polyspan as I understand it.
Does Polyspan shrink the same in all directions?
Thanks for the info guys!!
Bill
Last edited by Bill Smudge; Apr 09, 2012 at 06:17 PM. Reason: couple of other questions
Old Apr 09, 2012, 08:55 PM
Canada, BC, Comox
Joined Nov 2003
Thanks for the comments on the Bucker, guys. Much appreciated. It's my favourite model for sure!
Shiny side up is a good basic rule for Polyspan, although sometimes it's hard to tell which side is shiny and which isn't. If the material arrives rolled up, the top surface is the outside of the roll, like plastic coverings. It shrinks pretty evenly. It has a definite grain, which you generally want to run parallel with the long edge of whatever you are covering. I shrink it with a heat gun, but you need to be careful you don't over-shrink it. What happens then is that it pulls itself apart and leaves larger gaps in the natural weave of the material, which means more dope to fill it, or even a patch of silkspan to cover any bigger holes. (Don't ask me how I know!)
Old Apr 09, 2012, 10:44 PM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
I second that motion about the shiny side-- it's easier than you think to miss this, so scrutinize your cut piece well before laying it down. I've been covering with Polyspan for many years now, and on my most recent job I completely missed this on one wing outer panel. Fuzzies!!
'Annoyed' is when you get a corner wrinkle that won't iron out. Downright 'pistoff' is when you lay the fuzzy side up and don't catch it until the coats of dope show your mistake, and you have to rip it off and do it over. Don't let it happen to you!
Discussion Polyspan on a Sig Smith Mini Plane? viva_peru Scale Kit/Scratch Built 6 Dec 04, 2011 08:31 PM
Discussion Polyspan on Tritle birds. baldguy Scale Kit/Scratch Built 2 Mar 12, 2009 06:31 PM
Discussion can you put polyspan over silkspan? jeff262 The Builders Workshop 2 Oct 31, 2006 05:41 PM
Wanted fuselag only for GWS PicoStick sameershah Aircraft - Electric - Airplanes (FS/W) 2 Jul 24, 2006 08:30 PM
Polyspan on large, sheeted aircraft? fliir Scale Kit/Scratch Built 37 Dec 02, 2005 10:27 PM
