Old Apr 09, 2012, 02:49 PM
Joined Mar 2012
X-525 Kit, KK Controller 5.5 Won't Arm *SOLVED*
My first effort at building a quadcopter has run into a brick wall. Figuratively, not actually. Yet. ;-)
When I turn on the TX and plug the battery in to the quad, I get a single 'beep'/flash from the KK Controller board, then all 4 motors/ESC's start beeping in unison, once every 2 seconds, regardless of throttle stick position. Down and right does nothing. Motors do not spin up at all. Just a 'beep' ever 2 secs from each motor/ESC. The manual for the ESC's (Hobbywing Skywalker 20A) says that beep pattern means "Throttle signal is irregular."
If I bypass the KK controller board and plug ESC's directly into receiver's throttle channel, they work as expected, with the correct startup 'beeps' and response to throttle stick. Motors spin up smoothly.
Am I missing a KK Controller setup step, or is there something wrong with the board that's not passing throttle info correctly?
And second, what should the various settings be for the ESC programming options for use in a quad?
coh998 is offline Find More Posts by coh998
Old Apr 09, 2012, 03:00 PM
ripmax's Avatar
uk. northampton
Joined May 2009
First remove all props if u have not done already, throttle to zero, throttle trim to zero, throttle to right arms mine but depends what firmware you are running on, I had problems getting mine to arm, playing about with the pots at zero and allsorts of combinations got it to arm eventually, if u do get it to arm don't put pots at zero again, I did and it would'nt arm again!
ripmax is offline Find More Posts by ripmax
Old Apr 09, 2012, 03:10 PM
Donny boy!!
United States, MI, Traverse City
Joined Jan 2012
all of your esc's should be setup like this for quads!! Brake=off battery=NiMH cut off= soft or low, start up= normal or soft and your timing=medium... hope that helps!
Donnyv is offline Find More Posts by Donnyv
Old Apr 09, 2012, 03:41 PM
Joined Mar 2012
Thanks Donnyv, that answers one of my questions, although I don't think it has anything to do with why the board won't arm. Still, one thing at a time, and the next thing I know... ;-)
Old Apr 09, 2012, 04:23 PM
Joined Mar 2012
Success! All I needed to do was calibrate the ESC's thru the Controller. A guy named Mattcro in another thread says, "... you can calibrate the ESCs together via the KK board. Just set the YAW gain to zero, turn on TX, set throttle stick to full, turn on KK board and the ESCs will do their powerup beeps, followed by a double beep. Set throttle stick to low, and the ESCs should beep again. Power down, and set the yaw gain back to whatever you need (start at 50%)."
That was all it took. The board now arms and the motors spin up smoothly! Yeah! Thanks, Mattcro!
Old Apr 09, 2012, 05:46 PM
Donny boy!!
Joined Jan 2012
Good for you bud!!! I went through that whole situation not too long ago! I know its a big pain in the butt! but once you play around with all of that stuff you will become a pro at it!! now get out there and fly it!!!! lol
Old Apr 10, 2012, 03:16 PM
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Sorry, I double-posted
mattcro is offline Find More Posts by mattcro
Old Apr 10, 2012, 03:19 PM
KK Tri Flyer
mattcro's Avatar
Joined Feb 2012
Glad to help. I had the same trouble when I was setting up my tri, but it's an essential part of the setup process. If the throttle calibration is even a little bit off, you'll have all sorts of stability problems.
I just followed http://rcexplorer.se/Educational/kkg...guide/tri.html
Old Sep 30, 2012, 09:02 PM
SpeedFreak at heart....
molo_30's Avatar
Joined Aug 2006
Hi Guys, sorry to dog up an old thread but I have the same issue as cohh998, I did the calibration as above which works fine. When I power down and reset yaw pot to 50% and power back up again the board won't arm itself. I have tried all the endpoints ect to no avail.
Any ideas?
molo_30 is offline Find More Posts by molo_30
Old Nov 10, 2012, 01:33 PM
LV3|5#6|FP2|929|911|S800G
Stigern's Avatar
Bodø, Norway
Joined Mar 2007
Any ideas?
I did just flash my board with latest kk firmware 4.7. And after that I can arm it and disarm without any problems.
Just an idea.
Stigern is offline Find More Posts by Stigern
Help! KK Multicopter controller board X-Copter Matt Halton Multirotor Talk 20 Apr 12, 2013 03:30 AM
Found WTB KK Controller V5.5 Board for HexCopter, V2.5 finover9 Aircraft - Electric - Multirotor (FS/W) 0 Apr 03, 2012 03:58 PM
Help! Kk 5.5 won't initialize Garrett1234567 Multirotor Talk 0 Mar 31, 2012 12:54 AM
Discussion Esc not arming? motor won't start. dudly Electric Plane Talk 5 Jan 15, 2012 10:47 AM
Discussion ESC Won't Arm - CC BEC Won't Work With Stock ESC??? annarelli Electric Heli Talk 6 Apr 14, 2010 02:56 PM
