Old Apr 09, 2012, 11:05 AM
Joined Oct 2008
Scratch Build "Super Pacer" pattern aircraft
Just started on the build of this classic pattern ship. designed by Owen Kampten.
I converted the Nitro engine into an electric motor. First the wings ribs were cut out and stick the pieces together. Symmetrical wing foils are nasty so all the tools came in to help.
The other half was mirror to get identical length.
Checking for wing ribs alignment. Eyeball first. Looks good
More checks
This round I decided to use Dubro nylon pin hinges so need to cut slots in the square stock. Four for each half so a total of eight slots need to be made. These needs to be true centered otherwise you get all the binding during aileron movements.
After slotting stick on the piece to the wing rib
Attachment 4770065 Name: P1030894.jpg
Description: Name: P1030895.jpg
Description:
Making the ailerons using stock triangle but not the right gradient so more work
Description: Name: P1030866.jpg
Description: Name: P1030867.jpg
Description:
Cutting slots in the ailerons to receive the nylon hinges and make the bevel angle for smooth movement
Description: Name: P1030882.jpg
Description: Name: P1030883.jpg
Description:
According to the plans the wings have a dihedral angle so cut the Dihedral brace and test fit the brace. Everything i do must fit in tight and not too much slop, a habit from too much of helicopter building.
Attachment 4770062 Name: P1030897.jpg
Description: Name: P1030898.jpg
Description:
Next make the aileron torque tube from 3mm carbon steel and brass bearing for again smooth movement. and solder on the threaded couplers
Description: Name: P1030886.jpg
Description:
Now cut the slot in the Aileron to receive the torque tube
Description: Name: P1040306.jpg
Description: Name: P1040308.jpg
Description:
Don't forget to insert the brass bearing before you close the other end of the torque tube. Its a night mare to bend these 3mm carbon steel. But wait there is worse coming. Some pictures
Description:
Stick in the nylon hinges with extra reinforcement.
Description:
Cut the 5mm hard wood which goes to the center rib. Epoxy it to have strong bond since the wing attaches to the fuse with this hard wood, no CA for this one.
Description: Name: P1030906.jpg
Description: Name: P1040001.jpg
Description:
Some more pictures
Description: Name: P1040006.jpg
Description: Name: P1040007.jpg
Description:
toyheli is offline Find More Posts by toyheli
Old Apr 09, 2012, 06:28 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
This was an e-conversion of mine back in the cobalt/gearbox/nicad days- and even then it flew pretty well until I tried to go through a tree. Not as zippy as with the HB 25- but not bad. With the long snoot, you won't have a tail heaviness issue.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Apr 09, 2012, 07:43 PM
Joined Dec 2007
Nice work.
David
dhal22 is offline Find More Posts by dhal22
Old Apr 09, 2012, 08:31 PM
R_G
Wanna Hover? Fly a Heli!
R_G's Avatar
United States, PA, Farrell
Joined May 2010
Always thought the Super Pacer was a cool airplane. Never got around to building one though!
You have a very nice build going here!
Ralph
R_G is online now Find More Posts by R_G
Old Apr 09, 2012, 08:48 PM
Joined Dec 2007
Nitro please!
Old Apr 09, 2012, 10:07 PM
Joined Oct 2008
Originally Posted by dhal22 View Post
Nitro please!
I would love to but in my country resident are not in favour of the noise hence electric
Old Apr 10, 2012, 12:47 AM
Joined Oct 2008
Scratch Build " Super Pacer" Pattern aircraft continue...
Checking for alignment and sticking the lower spar
Description: Name: P1040021.jpg
Description:
Checking for dihedral angle
Description:
Planking the top sheet.
Description: Name: P1040025.jpg
Description:
After planking, glue in the servo bracket and get ready to cut out the servo pocket
Description: Name: P1040033.jpg
Description: Name: P1040034.jpg
Description:
Cut the landing gear support square pegs, X marks the spot for precise drilling
Description:
Sheeting the lower wing
Description: Name: P1040190.jpg
Description: Name: P1040191.jpg
Description:
The remaining servo bracket glue in place
Description:
Glue in the square pegs to support the 5mm landing gear carbon steel wire.
Description: Name: P1040037.jpg
Description: Name: P1040184.jpg
Description:
And yes bend the nightmare 5mm landing gear to the perfect right angle, pure madness and brute strength.
More pics of the lower spar and the angle joint at the center of the wing
Description: Name: P1040186.jpg
Description:
Next the elevator connect rod and its assembly
Description: Name: P1040198.jpg
Description: Name: P1040199.jpg
Description:
Cut out fuselarge and make the push rod from hard wood round peg and 3mm carbon steel
Description: Name: P1040239.jpg
Description:
Also the former for the wing attachment. A bit too short so CA comes in handy and make up for the length
Description: Name: P1040243.jpg
Description:
Old Apr 10, 2012, 05:03 AM
Joined Oct 2008
Next : Glue the former in place and the triangular stock piece.
Description: Name: P1040245.jpg
Description: Name: P1040247.jpg
Description:
Then comes the motor mount made from 10mm ply with ventilation holes and glue it in place together with the triangular stock pieces.
Description: Name: P1040251.jpg
Description: Name: P1040252.jpg
Description: Name: P1040255.jpg
Description: Name: P1040260.jpg
Description:
Seems like the push rod cannot clear the fuse formers, so off goes some material
Description: Name: P1040262.jpg
Description:
Then I made the ply wood to support the elevator and rudder servos
Description: Name: P1040279.jpg
Description:
The battery tray is next
Description:
With that done, I cut the rudder and the slots to receive the nylon hinges. Marking the rudder for taper sanding
Description: Name: P1040285.jpg
Description:
Old Apr 10, 2012, 06:43 AM
Joined Oct 2008
Sam
What kv motor and power rating? Pro size? thanks
Old Apr 10, 2012, 07:04 AM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
I had about 350 watts going into a 9 x 6 IIRC. This was probably a bit more than 100 watts/lb. I liked the 9" prop on the airplane versus the 8" I'd flown with glow, but the grass had to be short to get off.
These days, I'd probably be happier with 450-500 watts and a lighter airframe. The kit wood was very heavy- this was a sturdy airplane.
Sam
Old Apr 10, 2012, 08:38 AM
Joined Oct 2008
Hi Sam,
I will be powering with a 480W brushless motor and start with Master airscrew 9x4 prop. Think it should be enough of power. Powered with 3s 2250 mah Lipo. Still thinking how to lessen the weight of the aircraft
Old Apr 10, 2012, 08:45 AM
Joined Oct 2008
Scratch Build "uper Pacer" pattern aircraft
The rudder requires 3 hinges 2 on the rudder and one on the fuse. Special plug was made to hold the third hinge to the fuse rear.
Description: Name: P1040290.jpg
Description: Name: P1040338.jpg
Description:
Old Apr 10, 2012, 09:27 AM
Joined Oct 2008
Planking the bottom of the fuse, cross grain.
Description: Name: P1040293.jpg
Description:
Next comes the wing tip. Made from balsa block. Did not want to buy as it was expensive so sitck all the balance wood I have and made two blocks
Description:
Now glue the two blocks to the wings and mark the excess material to be removed
Description: Name: P1040322.jpg
Description: Name: P1040323.jpg
Description:
Now remove the excess material and sand to shape
Description: Name: P1040327.jpg
Description: Name: P1040328.jpg
Description: Name: P1040330.jpg
Description:
Wingtip done and servo mounted with aileron in place
Description:
Next do the wing mounting for the fuse using ply. holes are drilled at an angle so that the plastic screw sits flush and nice. The two ply are join at an angle but right angled to the fuse, tricky part, and still needs to be aligned to the wing's mounting holes.
Description: Name: P1040312.jpg
Description:
Next is to bend the 3mm carbon steel for the tail landing gear. Very hard to bend 90 degree bend and not in xy plane but xyz plane. Don't forget the brass bearing before the last bent, if not its damn........
Description: Name: P1040383.jpg
Description:
Old Apr 10, 2012, 10:02 AM
Joined Oct 2008
Cut out excess material in the rudder so that the landing gear is in line with the hinges and no binding on the brass bearing.
Description:
Now a little mod to the tail wheels. To make the plane as light, I chose the plastic wheels. But it is not smooth so I added brass bearing in the wheel so that it rotates on the steel landing gear, get the idea? Ok a pic is worth a thousand words. Look carefully, you can see the brass tube. Add a drop of oil and its ultra smooth. The wheel has almost no weight and with this mod it will last a long time and more importantly it rolls perfectly straight so that take off is true.
Description:
Old Apr 10, 2012, 03:15 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
One way to lighten this bird is to dremel out some of the center of the ribs- they're pretty fat, theres a lot of material along for the ride. But I think you're probably going down the wrong path. There are lots of purpose designed electric airplanes that will be much lighter than this one. The advantage of a glow ship is that they tend to be sturdier and withstand minor dorks and hangar rash much better. So if you've used good wood- I wouldn't sweat it. 450 watts on a 9 x 4 should be fine, but I'm concerned about the battery you've picked. At 450 watts, it's going to be drawing over 40 amps- and your flight times are going to be short. You probably want a setup in the 12-15C range to make sure that you have enough time to enjoy the flight- the airplane will carry the weight fine.
Sam
Discussion Super Pacer Build question toyheli Fuel Plane Talk 5 Dec 15, 2010 01:58 AM
Sold Ace Super Pacer (pattern). excellent kit. Proof67 Aircraft - Fuel - Airplanes (FS/W) 1 Jul 05, 2008 11:17 AM
Sold Ace Pacer, Super Pacer & Aerocommander Kits on E-Bay electric-2000 Aircraft - Electric - Airplanes (FS/W) 1 Sep 03, 2007 01:55 PM
Sold ACE Super Pacer Kit(SMALL PATTERN SHIP) pro bro steve Aircraft - Fuel - Airplanes (FS/W) 3 Oct 09, 2006 12:26 PM
