Old Apr 09, 2012, 11:33 AM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
Yippee!
Foxtech HoryzonHD 1080p FPV cam V3 old thread, pleae check the new thread
Hi guys ,Due to too much information in this thread ,I opened a new thread ,you can find new firmware there
and more test videos will follow up!
http://www.rcgroups.com/forums/showthread.php?t=1810451
HoryzonHD V3 is a revolutionary Full HD 1080P camcorder and FPV camera.
It has a seperated cam module connecting the mainboard module by 20cm cam wire.
It creats a lot of possibility and saves a lot of weight for HD FPV and other applications.
Many improvements are made on Horyoznhd V3 from hardware and software.
It could be the easiest to use HD FPV camera in the world.
we designed new keypad, new video/photo trigger, new video out port
and the most important of all.
You can still have a full 1080p cam onboard with just 48g extra weight.
Horyzonhd V3 is a cam that needs no DIY job.
fully shielded, specially made photo, video trigger and av out port.
this port is safer than the normal 3 pin plug on FPV cameras that doesn't break easily.
we also put in 2 heat shrinks in the box ,so if you want to remove the monitor to save weight.
that's fine.
about the software.
we reduced image noise and made the image looks more natural.
also start-up recording was added. so normally you install it on your plane.
power it up through the V-reg.
and plug in the main power battery ,then it just works as a normal FPV camera while it's recording 1080p video.
if you remotely trigger the video recording on and off.
you even don't need to press the buttons after setup.
Product link:
http://www.foxtechfpv.com/horyzonhd-...-v3-p-877.html
Parameters
Lens: 120 degree wide angle. (140 degree with Gopro lens)
Sensor: 5.0 Megapixels CMOS 1/3''
Video resolution: 1920x1080 30fps
1440x 1080 30fps
1280x720 30fps
1280x720 60fps
Photo resolution: 2592x1944
Video formate: H.264 encoding
Audo: built-in Microphone
Memory: Support Micro SD card(TF card) up to 32 GB
Power supply: 3.8- 5.5 V DC
Features of V3 plus:
Open box
The new V2 V-Reg with protection circuit to avoid over voltage and reverse polarity.
Horyzonhd 1080p FPV camera
First V3 onboard test video
glyder600+horyzonhd v3 (1 min 39 sec)
AV out test video
HoryzonHD V3 AV OUT Test (1 min 5 sec)
V3 introduction Video
HoryzonhdV3 Feature Introduction (4 min 37 sec)
the followings are demo video of V1 horyzonhd,we will add more V3 video soon
HoryzonHD 1080p cam introduction (2 min 10 sec)
720p 60fps, 1/2 playing speed.
HoryzonHD with Virtue F16 cockpit (2 min 32 sec)
1080p 30fps
HoryzonHD onbaord video (2 min 51 sec)HoryzonHD onbaord video
1080p 30fps
Beauty and a Fly (2 min 5 sec)
HORYZONHD Cam on a Doll ! (1 min 6 sec)
HoryzonHD park2 (2 min 19 sec)
Horyzonhd on Skymaster 2m Viper JET! (4 min 2 sec)
How to connect a 3 way cam switch?
for any question, please write emails to us:
stockinquiry@foxtechfpv.com (Doris)
technicalsupport@foxtechfpv.com(alex)
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Apr 09, 2012, 11:37 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
I would be happy to - but don't have NEAR 300 subscribers.
Blue Chip is offline Find More Posts by Blue Chip
Old Apr 09, 2012, 11:40 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
ok, just show us you best video here , we will consider it.
foxtech-Fu Xing
Site Sponsor
Latest blog entry: Foxtech Wishes You A Merry...
Old Apr 09, 2012, 11:43 AM
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
foxtech-Fu Xing
Here is the link to my YT channel... I cant say which is "best" but there is everything from crashes to clouds, high to low flying - and a fair amount of night flights.
I use #11 keychains, GoPro, and flight cam.
http://www.youtube.com/user/castlerockfl?feature=mhee
Caught in the Clouds BWEZ (2 min 33 sec)
Night Tandem Flown With Dragon Link (3 min 59 sec)
BWEZ Graceland Tandem Night flight - EDITED (5 min 37 sec)
Funjet in the Clouds (7 min 59 sec)
Old Apr 09, 2012, 11:47 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yea my 17 subscribers don't help either. But I have reviewed a few products. I have been able to get the 5.8ghz 200mw to 8km and showed others how I did it.
I have been using 5.8ghz behind trees and far away. I have a few different FPV style of planes. Wing, twinstar 2, tri copter.
anyway I do test things and since I am unemployed I have the time to test like mad
I have a few videos on youtube and vimeo
range on omnis 5.8ghz 200mw (4 min 23 sec)
http://www.youtube.com/watch?
v=cNKNRxsW4jY&list=UUBVwe8Lns9d3NfPQSw9NXtw&index= 8&feature=plcp
Water Flying FPV.mov (1 min 42 sec)
Low flying (3 min 16 sec)
whakahere is offline Find More Posts by whakahere
Old Apr 09, 2012, 11:53 AM
fpv raptor is offline
Find More Posts by fpv raptor
Joined Apr 2012
http://www.youtube.com/watch?v=cejUzVk1S9A
i can do a review and it will be an honest one. but you can't be too demanding from a camera that weighs only 30g
fpv raptor is offline Find More Posts by fpv raptor
Reply With Quote  (Disabled)
Old Apr 09, 2012, 12:04 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
I have a tech based youtube channel with R/C content and 2000+ subscribers.
http://www.youtube.com/user/rcbif101
I would be happy to do a review. I don't have many fpv videos yet, but it will be a major part of my channel soon, so I could offer a good FPV beginners take of the camera. My youtube channel can be found under the name rcbif101.
Here is a FPV setup video. I dont have any fpv flying videos yet, as I have been working on, and just finished my tricopter. It would be a good camera testing platform
Simple Portable FPV flying Groundstation (7 min 5 sec)
rcbif is offline Find More Posts by rcbif
Old Apr 09, 2012, 12:25 PM
SteveFPV is offline
Find More Posts by SteveFPV
California
Joined Aug 2010
Don't mean to rain on anyone's parade, but horizon is spelled with an I, not a Y. Not sure any of you spelling buffs noticed, but it stuck out like a sore thumb for me?
SteveFPV is offline Find More Posts by SteveFPV
Old Apr 09, 2012, 12:57 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Hi, Guys,
I have the honor to bring you a revolutionary FPV cam, HoryzonHD.
It's a 1080p video cam that take Full HD onboard video and store it in the
memory card, and transmit the PAL or NTSC video signal to the ground station
through video transmitter.
I adopted a separated sensor module design that enables many possibilities.
you can now use a tiny pan/tilt to take HD videos.
the whole unit is only 38g including the monitor and less than 30g without the monitor.
I should get free sample cause you stole my idea and now call it "a revolutionary FPV cam"
http://www.youtube.com/watch?v=rchk8JjusGg
fmkit is online now Find More Posts by fmkit
Old Apr 09, 2012, 03:00 PM
RevJVegas is offline
Find More Posts by RevJVegas
United States, TX, Houston
Joined Dec 2011
Yeah, my YT channel is pretty much in its infancy as I've just begun to start putting up videos.
I'm also just beginning in an FPV setup, so might be good to put it into the hands of a total noob so others can see it from that perspective.
Here's one video from my channel with my maiden of EA's Axon.
Flying the Axon (3 min 4 sec)
The next on repair after the crash.
Axon ... after the Crash (6 min 14 sec)
I was also going to begin doing short reviews of items I have used and my thoughts on them.
If you're willing to take a chance on me, I'll do it.
I've already got the FOXTECH CE OSD V1.5 which I just ordered about a week ago and should be arriving to my hands here in the next week and am planning on putting up a review/setup video on that item.
Thank you for your consideration.
RevJVegas is offline Find More Posts by RevJVegas
Old Apr 09, 2012, 03:18 PM
MrBen. is online now
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
not far off 100 subscribers, 49,000 video views
http://www.youtube.com/user/northrnmonkey?feature=mhee
I use a gopro and a gopro 960 with sunex lense, I would love to test one of your cameras!
I run http://fpv-forum.com too
some of my favorite vids
Quad Gopro Victoria Park Warrington (3 min 5 sec)
FPV Sheep Herding : Quadcopter / Gopro (3 min 56 sec)
http://www.youtube.com/watch?v=uAqpN0J4oMY
Super Alulah 2m on a Frosty Morning : Gopro / Sunex (5 min 24 sec)
MrBen. is online now Find More Posts by MrBen.
Old Apr 09, 2012, 03:28 PM
Lonestar78 is offline
Find More Posts by Lonestar78
Germany
Joined Dec 2010
Hi Glassfox, you have a PM.
Best
Christian
Lonestar78 is offline Find More Posts by Lonestar78
Old Apr 09, 2012, 05:41 PM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
looks really good so far. would be interesting to see how strong the jelly effect is, because that's the thing the gopro does very right (besides the marketing), and ALL the other action-cams suck at or are at least noticably worse.
send one to http://www.rcmodelreviews.com/ and one to trappy@teamblacksheep. should be very effective
PS: also make sure the lag from camera to av-out is minimised (if possible) and the brightness of the camera adjusts very quickly and maybe only to the lower 1/3 of the image or so (ground) and some wide dynamic range kind of stuff (if possible)
quix-fz is offline Find More Posts by quix-fz
Old Apr 09, 2012, 06:03 PM
hwat rc is offline
Find More Posts by hwat rc
Australia, QLD, Maleny
Joined Jul 2009
Not much on the competition but i'll put my best video in.. I would love to test one.
FPV Maleny and Roma, Queensland (Fort Minor - Remember the Name) (3 min 48 sec)
hwat rc is offline Find More Posts by hwat rc
Old Apr 09, 2012, 06:33 PM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Wow, what a great looking cam, it appears to solve all the pain in the butt issues with other cams (bricks)
I'd love to review one but have only just started out and don't have many subscribers
I do however already use Foxtech AIO goggles as well as Foxtech 5,8ghz tx/rx and a Cyclops Nova OSD
Oh and my Youtube views are 78,746 views, not counting my Vimeo and Metacafe stuff
Skysurfer 4th FPV Test (3 min 20 sec)
Tricopter FPV Practice (3 min 26 sec)
TeeJayBee is offline Find More Posts by TeeJayBee
Discussion Anyone used this cam? "gnarly HD 1080p Sports Action Camera" crashtested FPV Talk 4 Nov 05, 2011 07:37 AM
Sold GoPro HD Helmet Cam 1080P Twister773 Non R/C Items (FS/W) 5 Aug 03, 2010 07:54 PM
