Old Apr 08, 2012, 12:18 PM
KM.Racing is offline
Find More Posts by KM.Racing
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Octura prop
Thread Closed ... 9/4/2012
KM.Racing is offline Find More Posts by KM.Racing
Old Apr 08, 2012, 12:20 PM
wagondriver42 is offline
Find More Posts by wagondriver42
wagondriver42's Avatar
United States, NY, Rochester
Joined Jul 2011
none...that motor is WAY to high a KV for an RC boat
wagondriver42 is offline Find More Posts by wagondriver42
Old Apr 08, 2012, 12:24 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
you think so ! but my boat needs this high Kv , I'm searching now for the right propeller !
btw the boat will not run all the time on the full speed and there's blower that will cooled the motor
Old Apr 08, 2012, 12:43 PM
Joined Jul 2011
A few things JAD. A 70cm (27 inch) hull will NOT handle a 6000KV motor. A "blower" on a motor/esc in an RC boat will almost never work, the amp draw is to high the electronics NEED to be water cooled. And lastly, boat ESC's are designed to be run at WOT, less than that will result in extreme heat and eventually failure even if the components are water cooled. An sv27 is roughly the same size a your hull and uses a motor 1/3 the size to reach speeds of around 40mph stock. You WILL have a fireball on the water if you use that motor.
Old Apr 08, 2012, 12:51 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
I'm talking about a Fiberglass boat water cooled and there are vents that allow fresh air to enter and a blower is installed for more cooling don't forget that the pure weight of the boat (empty without system) is 2kg .
btw what boat do you have and what's the motor installed ?
Old Apr 08, 2012, 01:02 PM
Joined Jul 2011
i have an SV27R with a stock system and at times i change out the motor and ESC to a AQ2030KV and a Seaking 120 ESC. I also repowered my mystic 29 with a leopard 4074 2200KV motor Seaking 180A ESC and run an m445 S&Bed prop.
Old Apr 08, 2012, 01:04 PM
Joined Jul 2011
and an SV27R stock weigh 1.59kg
Old Apr 08, 2012, 01:09 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
very nice I like it !
btw I've designed my boat and I've manufactured from fiberglass for the first time I've put dual 400 Kv motors but it was slow so I've worked on the aerodynamics and the handling , now I'm putting 6000kv brushless motor just need information about it's propeller cz I can't put the old one build for the old motors !
Old Apr 08, 2012, 01:10 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
the total weight I have after installing the system is about 3.5 Kg
Old Apr 08, 2012, 01:13 PM
Joined Jul 2011
the higher KV isnt really going to help with the weight. You need more torque not higher RPM. lower KV higher voltage. The lower KV motors will be able to push the weight much better than a high kv motor. Just my opinion.
Old Apr 08, 2012, 01:16 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
I need speed the boat is a racing boat , the torque won't help me !
what do you think about speed ?
Old Apr 08, 2012, 01:22 PM
Joined Jul 2011
if you ran a high voltage setup the torque would help you. The higher voltage allows the motors to spin faster and retain there torgue. My mystic 29 is about 2.5 kg with batts and reaches around 60mph.
Old Apr 08, 2012, 01:30 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
woww 60mph !!! the motor is 2200 kv right ? and what about the voltage ? is it 12 V ?
Old Apr 08, 2012, 01:40 PM
Joined Jul 2011
I run 2 2s packs in series to give me 4s. 14.4V. I use 2 zippy 2s 5000mah 45clipo packs. 60 if it runs on glass. average speed is mid to high 50s. yes the motor is a leopard 4074 2200kv
Old Apr 08, 2012, 01:42 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
wonderful !
Wanted Propeller for 6000kv motor KM.Racing Boats (FS/W) 5 Apr 08, 2012 12:17 PM
Help! Trying to find a 6000KV EDF motor with 20mm mount solentlife Foamy EDFs 0 Dec 31, 2011 11:39 AM
Wanted AON 6000kv or Wraith 7K motor NSLST Non R/C Items (FS/W) 1 Oct 20, 2011 11:42 PM
Sold 4 Motors for sale, 2 64mm EDF motors, 2 parkflyer propeller motors -= GYRO =- Aircraft - Electric - Power Systems (FS/W) 3 Sep 21, 2011 01:10 PM
