Blackpool, Lancs
Joined Feb 2006
Is it the one at the top of this page? http://www.harbormodels.com/site08/m...undmodules.htm
with these instructions - http://www.harbormodels.com/site08/i...structions.pdf The instructions are very clear on it needing a healthy 12 volt supply which is reasonable given the power requirements. It is very possible that the control functions need a 5 volt supply either from the RX supply or through the BEC in the ESC. It doesn't say which power is being monitored by the power light. If there is control power, but no amplifier power, there will be no sound, if there is just no amplifier power, again, no sound, but the through connection should let the ESC work. If the RX and ESC work without the module in circuit, then they are evidently OK. There should be a through connection for 5V power between the motor plug and speed control connections, possibly the Aux connection as well. The signal wire will be diverted within the unit to allow the processing to happen. Always important to check the main power ground lines - I have had enough occasions where it should work but doesn't because motor current is having to find an alternative path, usually through the receiver wiring. |
| Thread Tools | |
| Question Who Makes The Most Realistic PT boat Sound Module? | RICH404 | Scale Boats | 40 | Dec 02, 2011 04:51 PM |
| Pinions 15 and 16 tooth modul 1 and ESC efficincy | nigel99 | Electric Heli Talk | 3 | Oct 06, 2004 02:16 PM |
