Old Apr 07, 2012, 02:52 PM
GuitsBoy is offline
Find More Posts by GuitsBoy
Joined Mar 2012
Flew for my first time
Flew my first three packs on my LH450 clone. Only casualty was a broken tail drive shaft, probably from too much belt tension. And a couple minor dings on the tail blade, but noting serious. I mostly just bounced around in a 12x12 area between some trees to try and shield from the wind, but it was great to finally take it outside. Charging my packs now, and hoping the wind dies down a little as the day goes on, so i can try and put another few packs through it. She flew pretty good as far as I can tell. No major trimming necessary, although even with the gain all the way up, the gyro was drifting quite a bit. I found myself giving it a lot of right rudder. I put an EXI metal head and tail on it last night, so I guess its installed correctly. Anyway, just had to post about my first flight.
GuitsBoy is offline Find More Posts by GuitsBoy
Old Apr 07, 2012, 04:28 PM
GuitsBoy is offline
Joined Mar 2012
I guess the belt was still too tight because i twisted the tail belt drive shaft in two again. Installed thy third and last spare, and flew my 5th and half of my 6th pack before the set screw of my outrunner backed out. I had put loctite on the pinion, but I didnt think to open up the motor and check there too. All fixed up, but calling it quits for today.
I was able to get a handfull of decent 30 to 60 second hovers despite the wind. Due to the tight space, I really had to keep it low (in ground effect) so that I could drop down whenever I lost it. I really need a bigger space, and a lot more practice. Hopefully things will get easier once the nerves die down, and I learn what translates well to the sim, and what does not.
Old Apr 07, 2012, 11:01 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Getting the belt tension just right can be tedious. Some pilots use a specific deflection of the belt, some go by feel, etc. But, with a belt you need to get used to adjusting it. After your first 20 flights or so, the belt will stretch and need adjusted again. After the break in period the belt will keep its tension for a good while.
Belts are nice to have for the inexperienced pilot. When you crash, the belt is almost never damaged, whereas with a torque tube setup, you are replacing the whole tail system guaranteed.
phoenixheli is offline Find More Posts by phoenixheli
First Post - Flew my Stryker for first time today Rob G Electric Plane Talk 11 Sep 01, 2004 03:01 PM
Flew my slowstick for the first time today!! thor4944 Parkflyers 22 Jan 30, 2003 02:17 PM
flew my slowstick for the first time WOW someone special Parkflyers 7 Nov 08, 2002 02:16 PM
Flew my Terry for the first time today! monkeyjam Electric Plane Talk 9 Nov 18, 2001 07:36 PM
Flew my micro for the first time today! johntbyrne Electric Heli Talk 4 Apr 23, 2001 10:44 AM
