Old Apr 07, 2012, 11:19 AM
bigfoot216 is offline
Find More Posts by bigfoot216
United States, MI, Davison
Joined Feb 2012
Help!
Wrong battery sent to me, Can i still use it?
I ordered a 2200mah 11.1v 20c battery and they sent me a 2200mah 14.8v 25c battery. I am running this motor on 2 of my planes:
http://www.hobbyking.com/hobbyking/s...idProduct=2104
I have tried to find and understand info on these lipo batteries and could not come up with anything that I could understand. So I turn to the experts here in hope that someone could explain this to me.
I have 1- 11.1v 2200mah 20c and now 1- 2200mah 14.8v 25c battery. Will both work with this motor and witch one is better?
Thanks...
BTW I am running a 50A ESC
bigfoot216 is offline Find More Posts by bigfoot216
Last edited by bigfoot216; Apr 07, 2012 at 01:14 PM. Reason: Providing More information
Old Apr 07, 2012, 11:40 AM
mobird is offline
Find More Posts by mobird
Canada, NS, Truro
Joined Aug 2004
Battery
The new battery you got is a 4 cell pack (4S). The motor spec calls for a 3 cell (3S). That means that you would be exceeding the spec voltage by almost 30%. Probably not a good idea. You may burn out motor and ESC and could possibly lose your plane as well.
Charles.
mobird is offline Find More Posts by mobird
Old Apr 07, 2012, 11:51 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Provided that your ESC is up to it you could technically use the 4S pack with the motor and it would be fine, but it would require you to run a significantly smaller prop and that's probably not the best option. Stick to using 3S packs.
You can probably find someone around here who'd be willing to trade you a good 2200mAh 3S lipo for the 4S one you got by mistake, or you could sell it in the classifieds. Since you only ordered a 3S 2200mAh 20C pack, the 4S is most likely worth more than you paid for it. You could actually come out ahead.
Piece is offline Find More Posts by Piece
Old Apr 07, 2012, 01:13 PM
Joined Feb 2012
Well I actually went big on the ESC. I bought a 50A ESC for both planes. I should have put that on my original post. Edited now^^.....
So with the large Esc will I be ok?
Old Apr 07, 2012, 01:30 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It's not just the ESC's current rating. Check it is still suitable for a 4s battery, as the BEC may be limited to only a 3s if it has one fitted.
Another point. The 4s will weigh more, so the planes CG will not be correct if fitted where a 3s should go.
You would need to specify all the bits and pieces involved, otherwise it's just guesswork on whether it would work or be an expensive failure.
eflightray is online now Find More Posts by eflightray
Old Apr 07, 2012, 01:32 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
I wanted to avoid the semi-technical explanation... Might as well lay it out here
The motor's Kv value tells you how fast it wants to turn per volt of input. In your case, this is 1200 RPM per volt. Increasing voltage, of course, will increase the RPMs the motor wants to spin at. Anytime you put a prop or other load on the motor, you're forcing it to spin slower than it wants to, which means it'll draw some amount of current. Generally, the motor will be drawing its maximum safe current when its RPMs are pushed down to about 75% of the no-load RPM.
Electric RC pilot's number one law: Current makes heat. Too much heat means stuff fries.
When the motor has a good prop for 3S operation (meaning it's being used at or close to its full potential with around 11.5-12V input), everything works well. However, increasing the voltage to the motor will make it try to spin faster, but it won't be able to get going as fast as it wants. The result is that it draws quite a bit more current (it's not a linear relationship) and the heat produced by the motor increases accordingly. The motor can't dissipate this extra heat quickly enough, so it gets too hot and smokes or de-magnetizes.
Using a smaller prop allows the motor to spin up to those higher RPMs, which keeps the current and heat down. Whether or not a smaller prop is a good option will depend on the plane itself, but not many planes will still fly comfortably if you just add a cell and then prop down like this.
That's the motor side. The ESC is a whole different can of worms, mostly because of the built-in BEC which I assume you're using to power your receiver and servos. Generally, the voltage ratings on an ESC are not to be messed with. If it's rated for the extra voltage (current is sort of irrelevant here) and the BEC can still supply enough current for your radio and servos work with, then you'd be fine with the 4S pack. However, the motor itself is still a limiting factor here.
The 4S pack would also be at least 33% heavier and substantially thicker, which could pose other non-electrical problems.
Old Apr 07, 2012, 01:59 PM
Joined Feb 2012
Usually I don't understand "the semi-technical explanation" but you did a great job of explaining this, so thank you very much.
Old Apr 07, 2012, 05:47 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
In another thread, you posted photos of the pack.
It has 4 balance leads.
That makes it a mislabeled 3S pack
rick.benjamin is offline Find More Posts by rick.benjamin
Old Apr 07, 2012, 05:57 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Ahhh, the post about the Transmetic pack from Leaders Hobby. They sell 5C packs if you need one.
Good catch Rick
hoppy is offline Find More Posts by hoppy
Old Apr 07, 2012, 06:04 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
I have a 3C 3S 2500mAh Zippy pack in my transmitter. Love that thing
I saw the mislabeled-pack post a few minutes ago... My advice would be to forget that thing altogether and go find some Sky Lipo or GensAce packs from HobbyPartz. They're good stuff and they come with the right labels
Old Apr 08, 2012, 12:20 PM
Joined Feb 2012
Yeah, I thought maybe I should put this in the battery area of this forum. I checked it on my HobbyKing 200w charger and it is not only marked wrong but has a dead cell. Another peace of crap from Leaders Hobby!
Rant Order# yhst-62196343123315-256565 You sent me a used product AGAIN! Arkansas Travelr HobbyPartz.com 3 Apr 04, 2012 11:05 PM
Rant Order# yhst-62196343123315-256565 You sent me a used product Arkansas Travelr HobbyPartz.com 4 Mar 21, 2012 02:25 PM
Help! you sent the wrong lipo's papabatman Nitro Planes 1 Feb 22, 2012 09:01 PM
Discussion Somebody can tell me what wrong with this motor? nexxa Electric Motor Design and Construction 4 Oct 14, 2011 11:49 AM
Discussion Wrong Power Supply, Can I still Use It? jlcamp7 Batteries and Chargers 11 Sep 03, 2010 11:31 AM
