Old Apr 07, 2012, 11:03 AM
Cmac678 is offline
Find More Posts by Cmac678
Joined Apr 2012
Help!
Bmcx shifts left when flying
Hello,
When I am flying my bmcx it seems to always want to go left and will tip over (to the left) if starting from the ground slowly. It will also sometimes just drop when I am flying it (although it could be a low battery).
This only started happening after I replaced the blades and got a bigger battery...
What can I do to fix the problem?
Cmac678 is offline Find More Posts by Cmac678
Old Apr 07, 2012, 02:25 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Starting from the ground slowly always makes it tip left. It gets caught in it's own air current. The air under the blades has to go somewhere. A heavier battery just makes the condition worse, because you have less lift. The heavier battery will also make "coax death dive" more noticable. Turning at any kind of speed requires a certain amount of banking. But a coax can't bank very much. You get the death dive when the heli needs to bank more than it is able to. When that happens it loses the air under the rotors. More weight down low just makes this happen easier.
Balr14 is offline Find More Posts by Balr14
Old Apr 07, 2012, 02:35 PM
dasBlade300X is offline
Find More Posts by dasBlade300X
Joined Feb 2012
Cmac......
Do you mean the mCPx??
Most CP helis tend to drift LEFT at lift-off, due to the tail countering torque...so it's normal to GENTLY apply a BIT of RIGHT CYCLIC right at lift-off.....It's also best to get out of ground effect as fast as possible --- don't "walk" the heli along the ground....lift off at least 12-18", then apply QUICK, SHORT cyclic corrections as necessary....
RE: dropping in flight.....if you DO have a mCPx, check to be SURE the main gear is pushed up SNUG on the main shaft, and that the "flat" on the gear is lined with the "flat" on the shaft....if you move the head up and down, there should be NO PLAY!
Of course, if the battery is approaching LVC (low-voltage cutoff) the heli will lose headspeed and shut down to avoid over-discharge (NOTE: Constantly flying to LVC WILL shorten battery life....time how long it takes a :normal" flight to bring on LVC....then shorten flights by ~:30 to 1:00.....
Did you replace the blades with stock or another brand/type??
Good Luck!
dasBlade300X is offline Find More Posts by dasBlade300X
Old Apr 07, 2012, 04:06 PM
Cmac678 is offline
Joined Apr 2012
Originally Posted by dasBlade300X View Post
Cmac......
Good Luck!
Thanks for everyone's help...
The box says blade mcx not mcpx. I replaced the blades with stock.
The thing is that now my heli flys to the left and does not hover without much movement anymore... Is there anything I an do?
Nice to know that it is normal that it tips left on take off....
Old Apr 07, 2012, 05:14 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Put a lighter battery back in, make sure your swashplate is level with the mainshaft, your servos have free movement in both directions and your anti-rotation pin is within the anti-rotation bracket.
Old Apr 08, 2012, 11:44 AM
Joined Feb 2012
Cmac......
Sorry.......I couldn't delete my post after I saw Balr14's response...
Mia culpa!!
Help! Xieada 9958 spins to left when throttle is increased danagelh Mini Helis 9 Aug 15, 2013 11:17 AM
Discussion Great Wall Xieda 9958 spins rapidly to the left when I give it throttle the desolate one Micro Helis 4 May 09, 2012 12:44 AM
Discussion mcp x2 keeps turning to left when pitching up? Legendary_Agent Electric Heli Talk 5 Mar 22, 2012 04:19 AM
Careful! MultiWii disarms when right stick moved to upper left??? Tres Wright Multirotor Talk 8 Mar 17, 2012 01:42 AM
Discussion When done; BmCX charging? jrb Micro Helis 0 Jan 08, 2009 08:58 AM
