Old Dec 13, 2012, 03:57 PM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
Originally Posted by aeajr View Post
Someone up top said it was going to have the same SW as the 9X which would be the FlySky SW. If it is not the FlySky SW then it is not the same SW as the 9X. And since we don't believe it is being made by FlySky that makes sense.
The purpose of my question was to overcome the loose use of terms and the ease of confusion that some people cause with their unclear statements. The 9X comes with FlySky SW. So this radio will have different SW than the 9X FlySky software.
Now you tell me it will be er9X, or something similar to er9X. So, by your own statement, you don't know what the SW will look like or what functions it will have. But you believe it will be something similar to er9X or something like that or some derivitive ... probably. OK but a far cry from KNOWING.
And we believe it will be able to be flashed with Open source software which may or may not need to be ported, if the open source community chooses to port to the 9XR. So there is no gurantee that there will be SW options, but it seems likely, probably, I guess. OK but a far cry from KNOWING.
I am on board. We don't know what SW it will have. And we don't know what optional SW there will be ... but we suspect.
Search is everyone's friend, but not always necessary. Sometimes we just have to distinguish between facts and opinions.
Until it is released, this is all opinion. When it hits the street, we will have the facts.
Actually we do have fact.
Anthony Hand, owner of Turnigy, OrangeRX, HobbyKing and various others, said himself "The 9XR will have the same chip as the 9X and will be able to be directly flashed with the same software as the 9X" He actually said this! In this case search IS your friend but since you are incapable of using go to pages 40-59 and it is stated somewhere in there.
Actually most of the facts are stated between pages 30-69 with useles dribble after that (except for picture of the case).
molond is offline Find More Posts by molond
Old Dec 13, 2012, 04:01 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Originally Posted by molond View Post
Do you realise what you have said? Let me paraphrase:
A operating sysytem of a couple billion lines of code with over 500 additional drivers made for it works on different hardware therefore a SPECIALISED TX operating system of a few thousand line max with NO additional drivers must run on multiple hardware.
The reason Windows can run on different hardware is because the hardware is hidden behind another program, called a BIOS.
The OS on the 9X, 9XR and any other radio communicates directly to the hardware, no middle man. This means it can only work on one type of chip or it will have serious bloat.
Think before you post!
So, if it has the same chip, does that make it the same radio? I think not.
Just as my HP Windows 7 PC and my friend's Windows 7 PC are not the same because they both have Intel chips in them. And even if they have the same BIOS in them the are still not the same. But they may be similar. Just as a 9X and a 9XR may be similar in some respects, that does not make them the same.
You missed the quote that I was responding to. It is absurd to say it is the same radio just because it can run similar SW. Just as it is absurd to say the two PCs are the same just because they can run similar SW.
But your smileage will vary I guess.
aeajr is offline Find More Posts by aeajr
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
I very nice comment aeajr!
Your comment can be extended through to this whole site.
evltoy is offline Find More Posts by evltoy
Old Dec 13, 2012, 04:06 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
He also said it would be released by now .. .but it is not.
And my friend, a few posts back said that the SW will/may have to be ported. So who am I to believe. The guy who promises a release date and doesn't deliver or the guy who is sure what the software will be ... sorta.
No need to convince me. As I said earlier, until it is actually released, all we have are opinions and speculations. When it is released, then we will have facts.
Believe what you like. I will wait for the facts to come out.
Old Dec 13, 2012, 04:12 PM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
So if you took 2 PCs with exactly the same hardware components but a different case, they'd be 2 different PCs?
Probably yes.
It doesn't change a thing though. People saying the 9XR will be "like the 9x" means that as it will have the same hardware, it will have the same capabilities. That's what matters in the end.
Totally sounds like HK. Which is why they'll jut slap er9x on it - that way they don't have to care about that aspect
Kilrah is offline Find More Posts by Kilrah
Old Dec 13, 2012, 04:31 PM
Thwock is offline
Find More Posts by Thwock
United Kingdom
Joined Nov 2012
Clearly I was mistaken in posting at all. My apologies.
Thwock is offline Find More Posts by Thwock
Old Dec 13, 2012, 04:57 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Not at all. All we are doing is debating opinions and half facts. Nothing malicious here. It is mostly what we do on the forums. We take what we know, what we think we know and we form opinions, then we discuss them.
This is especially true when it relates to unreleased products. It's fun!
You should come over to the glider forums and read the discussions on setting the CG of a glider. Now those can get really exciting with equations and wind tunnel reports and graphs and charts and stuff. I can see guys at the keyboards with their slide rules out checking facts .... opinions.
In the end you learn stuff and it helps you ... maybe. But it is definitely fun.
Old Dec 13, 2012, 05:09 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by jhsa View Post
With the custom firmware on a 9x you can do stuff you couldn't even imagine with an expensive radio..
I find a bit hard to believe that the 9XR would come with one of the known custom firmwares because it doesn't even have the same number of switches..
Unless the firmware was modified..
i think we can assume it will not come with an exact copy of any existing distribution for a variety of reasons. for one thing erez or one of the other developers would have been contacted and we might have heard something by now. kinda like what happened with rolfe bakke when hk adopted his code for their kk controller.
also as has been mentioned the current firmwares are not really ready for the average user. a few more of the sharp edges need to be sanded down. finally they are all being constantly updated so hard to aquire a moving target.
i suspect it will be some conglomeration of existing versions with rough edges removed and geared more for the majority of hobbyists instead of geeky "core group". at least i hope so. at the very least im sure they will come up with a cutsey hobbyking splash screen.
ps number of switches has little to do with whether the code will run or not. ive built functional 9x clones with NO switches, buttons, or display at all yet still able to fly a plane. in fact even the joysticks are not necessary for firmware to execute as i recently saw by hooking up nothing but an lcd. of course there was no practical use except to verify my display wiring prior to final hookup.
dave1993 is offline Find More Posts by dave1993
Old Dec 13, 2012, 05:11 PM
Thwock is offline
United Kingdom
Joined Nov 2012
You play a little rough for my taste, sir.
If we can only use deductive logic and unambiguous documented facts, there's really nothing to talk about, you're quite right. But I already clarified my inexact language for your benefit once. I lack the energy to meet your standards and it's late here.
I'll comment when I've got one in my hands. Hopefully it won't be too unlike a 9X or I will surely be wasting my money.
Old Dec 13, 2012, 05:22 PM
pilotavery is offline
Find More Posts by pilotavery
United States, CA, San Marcos
Joined Jul 2012
Probably yes.
My asus and dell BOTH have a core i5 460m, and they are IDENTICAL chips. Now the chips run the same software, but must receive it via different means.
The bios is set up so that is pretty much the hardware abstraction layer.
pilotavery is offline Find More Posts by pilotavery
Old Dec 13, 2012, 05:25 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I don't think I was talking about you. I think I quoted Dave for that one.
Have I quoted you anywhere?
But I accept your assessment. Sometimes I can get a bit rough around the edges. Assessment accepted and appology offered if I offended you.
Old Dec 13, 2012, 05:27 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
hey thwock, take it easy...
one thing aeajr and i do agree on is LIVE FROM NEW YORK... errr... i mean.... rcgroups is fun and in rare cases educational. dont take these chats so seriously dude. lol!
Old Dec 13, 2012, 06:30 PM
fantomphish is offline
Find More Posts by fantomphish
gold coast
Joined Jan 2010
I herd the 9xr will get any rabbit pregnant if they are in a 2km radius of it being used and that it turns ex wives into unicorns and makes clowns wigs melt into pure gold, at least that's what I was told by a friend who herd it from the voice in his head who said it was on a blog somewhere, so once all those serious issues are solved I wouldn't expect to see it any time soon..
fantomphish is offline Find More Posts by fantomphish
Old Dec 13, 2012, 06:41 PM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
That's the first comment that makes any sense whatsoever for the last 24 hours
tignmeg is offline Find More Posts by tignmeg
Old Dec 13, 2012, 06:49 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
I think there are a couple of HK haters on the thread that aren't trying to contribute much but just stir the pot.
If they want to buy a $200 radio with telemetry then go ahead and buy it when FrSky releases it (and don't forget their date was going to be this year, but won't).
Those that say the 9XR is just a 9X are obviously just stirring as well.
It is a $50 (possibly later $80) radio that gives us unprecedented kit for the $. Also is coming with a modified open source firmware but can still be reflashed with ease!
BrettAltea is offline Find More Posts by BrettAltea
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
