Dec 07, 2012, 04:27 PM
Switzerland
Joined Sep 2006
Originally Posted by stevea3342
I suppose all of your receivers could be bound to all the models on your transmitter
Yep, that's standard operation for radios without model match.
but if they can be bound to 'just' your transmitter then you are just a few lines of code away from having model match.
It's a bit more complicated in a module-based setup, as you bind the receiver with the module, not the radio. To add model match, the radio would need a way to tell the module which model memory is selected, which isn't possible with the simple PPM signal that's used between the radio and module.
