Old May 20, 2012, 03:33 AM
beaverbuddy is offline
Find More Posts by beaverbuddy
New Zealand, Canterbury, Christchurch
Joined Sep 2011
I had always been a confirmed Futaba user,but could not stomach the cost of their 2.4ghz systems.Hence I bought two 9x's from HK.Total cost around $110 freight inclusive.That's less than the cost of 1 Futaba rx locally.
I have no hesitation in using my Frsky converted 9x with ER9x on any aircraft I own.
I use mostly 7ch.rx's,and they cost less than $20.
I wonder exactly how many users actually know how to operate all the features incorporated into their all singing,all dancing $1200 transmitters.A fellow I know has a newish Futaba 12 ch,and all it's done for him,is make his crashes more expensive.
I can't see how I would need anything more than the current (ER)9X.
beaverbuddy is offline Find More Posts by beaverbuddy
Old May 20, 2012, 04:53 AM
StewieRC is offline
Find More Posts by StewieRC
This Calls for a Sexy Party
StewieRC's Avatar
Minneapolis
Joined Sep 2010
they need to come out with the new TX within a month or two, i need a new tx bad.
StewieRC is offline Find More Posts by StewieRC
Old May 20, 2012, 06:05 AM
simo71 is offline
Find More Posts by simo71
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
& you are all harping on about the 9X, regardless of how good a software you put into it's still poor quality hardware.
Even if the new 9XR uses the ER9x software, if the radio it self is anything like the current hardware I would not bother....But I'm not expecting it to be & only time will tell.
simo71 is offline Find More Posts by simo71
Old May 20, 2012, 08:29 AM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
When you say hardware...
The electronic circuit board quality is pretty much just as good as any mainstream board - Surface mount components, etc and built using automated equipment.
The weak points are the point to point wiring - but guess what - other suppliers have the potential issue of wires breaking at solder joints as well (likely with lower frequency of occurrence). If you are a pilot that is constantly moving sticks to the extremes while flying - regardless of transmitter make, I would check the wires attached to the gimbal potentiometers every year as a pre-season check. They could break sooner or later.
The switches don't feel great - lot of slop - but they work and are very functional. Unlike other radios, you have a choice - change to another switch if it breaks (using ER9X) or replace it.
The transmitter case is toy'ish but it works and some people (myself) appreciate the size. The gimbals are smooth but not $1200 like (no quad bearings) and I was considering moving to a new case with Hitec A9 gimbals until I saw this thread.
This is the not the transmitter for the masses - but for those willing to try and learn, it provides great rewards and makes it near impossible to want to go to any other solution (except new FlySky or FrSky transmitter with ER9X).
PS - there is a learning curve for ER9X - it is not the aurora touchscreen input. But once you learn, it is hard to go to any other approach as it is so direct.
I also keep my transmitter in a protective case (aluminum hardshell) as I don't want it to be the reason that I lose a plane. Shock, vibration are not friends to anyone's transmitter - regardless of make.
ScottSails is offline Find More Posts by ScottSails
Old May 20, 2012, 10:00 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Originally Posted by caseih View Post
With stock firmware yes I agree with you. With Er9x, the 9X exceeds the Aurora 9 in capabilities.
By far not true my friend. The Aurora 9 easily reigns supreme in a direct comparison, even with the custom firmwares.
I own both the Turnigy 9x (three actually, one of them is flashed with Er9x) and the Aurora 9 and it's easily and with great distance the better radio of the two.
It's not just the firmware, it's also the build, feel, touchscreen interface and so on.
Just about the only thing the Aurora 9 truly lacks is basically the same level of customizability the 9x has, but with the A9 stock firmware there's really no need to have any of that.
I don't see how any of you can compare the 9x to a radio like the A9 and act as if it's on par lol.
Regardless, it's perhaps the radio with best value currently available.
PHMX is offline Find More Posts by PHMX
Old May 20, 2012, 11:42 PM
wingz is offline
Find More Posts by wingz
Joined Feb 2012
As I mentioned earlier, I'm a satisfied A9 owner, but the ER9X firmware easily does things that I can't get my A9 to do. Here's an example: My gws slow stick pulls upward under throttle, so I mixed in some down elevator onto the throttle. The problem is that I wasn't sure how much to add. I added a P. Mix for throttle -> elevator, but there's no way to assign an adjustment button to the programmable mixes. I had to bring the plane back down and adjust three different values to change the amount mixed (the plus side of the throttle, the minus, and the offset). This is incredibly clumsy.
ER9X? Mix the throttle onto a spare channel (CH4, for example). Offset it by 100 and give it 15% weight. Now add another mix on CH4 using one of the knobs as a multiplier for the mix above. Now add CH4 onto the elevator. Once in flight, I can use the knob to change the throttle to elevator mix anywhere between -15% to +15%.
The ER9X approach is very straight forward and could easily be even more flexible with only a very small additional effort (using a customized mixing curve, for example). If doing something like this is possible with the A9, please let me know. I'd be very happy to be wrong.
wingz is offline Find More Posts by wingz
Old May 21, 2012, 12:11 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Wow an actual example. I'm amazed
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old May 21, 2012, 02:32 AM
mongo56 is offline
Find More Posts by mongo56
about:blank
mongo56's Avatar
Slovenia
Joined Aug 2007
IIRC you can use trims (LT, RT,..) to adjust the mix in flight. I'm almost sure I've used this while eliminating knife edge coupling (RUD->ELEV mix).
mongo56 is offline Find More Posts by mongo56
Old May 21, 2012, 04:49 AM
PHMX is offline
Joined Feb 2011
Yes, in fact, you can program such a mix in many ways on the A9. You can even use those nice gradual trim knobs on the side to make such a mix adjustable if you set it up properly.
I'm starting to wonder where you are coming from with the argument as the A9 is one of the most programmable radios out there.
Old May 21, 2012, 06:02 AM
jcervantes11 is offline
Find More Posts by jcervantes11
jcervantes11's Avatar
Joined Sep 2003
Frsky Transmitter it will be out in few month comes with telemetry built in.
jcervantes11 is offline Find More Posts by jcervantes11
Old May 21, 2012, 06:41 AM
caseih is offline
Find More Posts by caseih
Joined May 2005
Umm, yeah, well that is directly related to what this thread is all about, so I would expect people to harp on about the 9X.
I doubt you'd bother either way, so I'm a bit confused as to why you are posting on this thread. Obviously the 9X or 9XR isn't for you, so it doesn't matter what the hardware or software looks like.
caseih is offline Find More Posts by caseih
Old May 21, 2012, 08:26 AM
wingz is offline
Joined Feb 2012
Yes, you are correct, but RUD->ELEV is one of the built-in mixes. I mentioned that I was referring to the P. Mixes. I don't see any way to add the trims (LT, RT, ...) to a P. Mix.
PHMX: You indicated there are many ways to implement an easily adjustable mix. Can you clarify using my P. Mix example of throttle to elevator? I haven't been able to get this to work on my A9.
Old May 21, 2012, 02:20 PM
prefabu is offline
Find More Posts by prefabu
Kansas City
Joined Dec 2009
I think both sides are making a valid points. The ER9X software is impressive in many ways, but it doesn't improve the physical characteristics of the various 9X radios. My old DX5e and even my friend's DX7 feel kind of cheap compared to my Aurora. I can imagine the 9X feels even more so based on some of the comments I've read. That's why I think Turnigy (or FlySky, whatever) should put their efforts into producing a better radio in the physical sense and make it so others can easily add their own code. Software development is expensive and time consuming, so it seems like a good move to encourage open source efforts where people are willing to donate their own time and ultimately give other users more reasons to buy the hardware.
prefabu is offline Find More Posts by prefabu
Old May 21, 2012, 05:04 PM
npre is offline
Find More Posts by npre
Joined Jan 2011
Originally Posted by PHMX View Post
I don't see how any of you can compare the 9x to a radio like the A9 and act as if it's on par lol. .
I agree. A9 is 4-6 times the price of a 9x. There is no comparison to make, they are for different people, the only similarity is they both control model planes.
npre is offline Find More Posts by npre
Old May 21, 2012, 10:36 PM
ryanotown22 is offline
Find More Posts by ryanotown22
Currently flyin Crack Yak
United States, AZ, Gilbert
Joined Jul 2006
The also have plastic and metal
ryanotown22 is offline Find More Posts by ryanotown22
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 11:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 12:05 PM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 10:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 09:48 AM
