Old Nov 20, 2012, 05:59 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I just tried that as well, but the RSS also spams with forum posts, and so all posts with 9XR on the HK forums started popping up there as well. Sigh... I'm probably not going to be buying a 9xR anyway.
acetech09 is offline Find More Posts by acetech09
Old Nov 20, 2012, 07:58 PM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
So grep the new products page rather than the rss feed. Too easy.
cold wombat is offline Find More Posts by cold wombat
Old Nov 20, 2012, 08:30 PM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
LOL
I had to google "grep"
Now I've got hours of reading o do to figure out how this all works.
Any chance of a quick summary?
tignmeg is offline Find More Posts by tignmeg
Old Nov 20, 2012, 08:56 PM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Ive just done the old fashioned thing and put down in my diary to check the hk website on dec 15th!
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Nov 20, 2012, 08:58 PM
flyboy7531 is offline
Find More Posts by flyboy7531
Youtube: RCTestFlite
United States, NE, Lincoln
Joined Jul 2012
Nice! Or in my case, check the HK page every day! I can't wait!!!
flyboy7531 is offline Find More Posts by flyboy7531
Old Nov 20, 2012, 09:04 PM
tignmeg is offline
Registered Adict
tignmeg's Avatar
Joined Jun 2012
LMAO
OF COURSE !!! simplicity at its best
Old Nov 20, 2012, 11:18 PM
acetech09's Avatar
Joined Apr 2012
I just know that somebody else here will find it, and it'll show up since I'm subscribed to this thread
Old Nov 21, 2012, 03:18 AM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Originally Posted by tignmeg View Post
LOL
grep will filter out any lines NOT containing a PATTERN
So if you have a file "file" with many lines, usage would be
Code:
cat file | grep PATTERN
If you want to look for a line containing "megan", syntax would be:
Code:
cat file | grep megan
That simple
cmavr8 is offline Find More Posts by cmavr8
Last edited by cmavr8; Nov 21, 2012 at 11:02 AM. Reason: corrected ">" to "|" - silly me
Old Nov 21, 2012, 10:48 AM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
Code:
cat file > grep PATTERN
Code:
cat file > grep megan
That simple
so would it be something like
Code:
cat http://www.hobbyking.com/hobbyking/store/__309__190__Tx_Rx_Systems_Parts-2_4Ghz_Turnigy.html > grep 9XR
molond is offline Find More Posts by molond
Old Nov 21, 2012, 11:01 AM
ecreative is offline
Find More Posts by ecreative
It's all about Quadcopters
United Kingdom, England, Surrey
Joined Nov 2012
Hi just in case anyone is a geek like me and knows some PHP and wants to make a feed checker here is what I would do:
Create a file called "check.php"
Code:
Code Removed!
Then just make a blank file called "failsafe.txt" and put it in the same folder then just setup a cron job to check every few minutes...done!
EDIT: Actually I decided to remove the code because HobbyKing might be bombarded with cron requests and there site already seems to be running very slow, but if anyone wants to be added to my code then just PM me there email address
ecreative is offline Find More Posts by ecreative
Old Nov 21, 2012, 11:04 AM
cmavr8 is offline
Chris
Joined Sep 2010
Code:
No, it wouldn't work so easy, you need to download the file first (wget would work).
But ecreative posted a php script that is much better!
I'll try it now... :P
Old Nov 21, 2012, 11:12 AM
cmavr8 is offline
Chris
Joined Sep 2010
Thanks for the code!
What would work for the cron job? Just curl'ing the checker.php file?
EDIT: the email is sent (returns 1, TRUE) but I don't receive it in my inbox.. strange..
Old Nov 21, 2012, 12:43 PM
Joined Nov 2012
Is that through manually running the script or through the cron job?
If it is through the cron make sure you add php -f before the link to the code as some cron jobs stop emails being sent:
e.g.
Code:
php -f /home/USERNAME/public_html/HK/check.php
As a test I set the script to search for "Orange" as the three latest feeds have that word in them
Old Nov 22, 2012, 04:52 AM
Harri Pihl is offline
Find More Posts by Harri Pihl
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
Originally Posted by Harri Pihl View Post
Well, there is a potential problem that a non Spektrum built tx module shares the same tx id as a genuine Spektrum system. So that button might be for changing that.
And if that assumption is correct... figure out the rest
Looks like this will be the problem
From the Orange module manual:
Harri Pihl is offline Find More Posts by Harri Pihl
Old Nov 22, 2012, 06:30 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
if I understand correctly, they use GUID as id (http://www.spektrumrc.com/DSM/Technology/DSM2.aspx), if that is true, then according to wikipedia "the total number of unique such GUIDs is 2^122 or 5.3◊10^36. This number is so large that the probability of the same number being generated randomly twice is negligible".
Unless all orange tx modules have initial id equal or their id not truly GUID, possibility to have two people with same id's in single field is much smaller than possibility to win jack pot seven times in a row
dziedrius is offline Find More Posts by dziedrius
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
