Old Nov 16, 2012, 11:56 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
not now and maybe never. not unusual for retail to double or triple by the time it gets to market. or shortly after. like some frsky rx and the flysky 9x radio did. almost certainly 9xr will too.
dave1993 is offline Find More Posts by dave1993
Old Nov 16, 2012, 12:30 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Originally Posted by dave1993 View Post
no sd. surprising how many insist on $1000 feature for $50 radio.
SD card support would be pretty cheap to add. I don't think I would bundle it with an SD card to keep costs down though. But then again just what do you expect for $50?
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 16, 2012, 12:40 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
SD cards are just a couple I/O lines into the SPI peripheral of the microcontroller. Just requires the cost of the SD holder and a cut out in the case, which is peanuts to add.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Nov 16, 2012, 01:02 PM
albx is offline
Find More Posts by albx
albx's Avatar
Italy
Joined Jun 2007
a card reader is just a couple of dollars
albx is offline Find More Posts by albx
Old Nov 16, 2012, 01:16 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Rather cents... is not a "reader" with electronics inside, just a connector, this is the search term you must input to find them online. 10 for $3.
renatoa is offline Find More Posts by renatoa
Old Nov 16, 2012, 01:26 PM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
and if you want it with the board http://www.ebay.it/itm/Perfect-SD-Ca...item4cfcc47f2f
Old Nov 16, 2012, 03:22 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
again the real issue is software resources. the avr chip simply dont have capacity for the required file system. even basic fat32 routines would overflow memory let alone ntfs or the new xhc format. now if this were arm based.... anyway sd is another one of those things like 3rd joystick that some minority demand but little real benefit. nice to show off at the field but few practical advantages for model memory storage over internal flash.
btw note the board in that link is little more than a connector attached to the socket. "smart" sd interfaces cost a lot more. go to sparkfun for a reality check on that.
Old Nov 16, 2012, 04:52 PM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
But that requires the microcontroller to have a free SPI port. As one of the requirements of the 9xr was to be directly compatible with existing 3rd party firmwares for the 9x, the microcontroller and connections had to be the same. Which means no free SPI port, just like on the 9x. Its pins are used for trim keys if I remember well.
Again it's a $50 radio. If you want SD card and actually make use of it with voice prompts and telemetry logging, go see the frsky radios
Kilrah is online now Find More Posts by Kilrah
Old Nov 16, 2012, 05:27 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
It would be interesting to see if, after the 9XR was released, there was a demand for a high end version with stuff that people are discussing for around the $100 mark.
BrettAltea is offline Find More Posts by BrettAltea
Old Nov 16, 2012, 07:52 PM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Yes. There is such demand. See the X12D thread. That family of radios is the upgrade path from the 9XR.
cold wombat is offline Find More Posts by cold wombat
Old Nov 17, 2012, 12:20 AM
Joined Aug 2011
Not really an upgrade path. One uses DSMX and the other uses FrSky. Yes you could use the 9XR with a FrSky module however you'd be better going for the FrSky X9D as it has telemetry.
Old Nov 17, 2012, 04:23 AM
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
The 9XR uses DSMX through a module, which you could replace by an frsky one. The X9D has integrated frsky with telemetry, but you can also put a DSMX module in the back slot if you feel like it
Old Nov 17, 2012, 04:43 AM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
I get the impression that the X12D was a result of the impending 9XR. Hopefully some smartypants will figure out how to Hack the 9XR to add some ot the other things that Frsky put into theirs.
tignmeg is offline Find More Posts by tignmeg
Old Nov 17, 2012, 06:37 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
I didn't think there were standalone DSMX modules available yet? Could be wrong tho...
MattyB is offline Find More Posts by MattyB
Old Nov 17, 2012, 07:00 AM
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
HK released one about 2 weeks ago:
http://www.hobbyking.com/hobbyking/s...mpatible_.html
It's buggy, but they'll likely solve that. There wasn't a confirmation yet whether the 9XR would have an integrated or module-based DSM transmitter, but one of HK's answers saying they "tested it thoroughly on 9XR which is what it was originally designed for" seems to point towards the module solution... even if probably a slightly different version to use the internal antenna connection.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
