My guess would be $200 - $250, but it will actually be a complete radio with a module ,battery and USB port.
Latest blog entry: er9x heli 450 heli set up (flybar)
I don't recall seeing anything specific about the price from Chase or Rotozuk. Anyone else would just be speculating. ![]() If the sticks and switches are of good quality then I would not hesitate to pay $250 for a complete radio, including battery and charger. |
M$ Security
Joined Jun 2010
even if it's $180 it will ALWAYS be better radio and YES they have to be worried unless they come out a 12XR
9XR has ball bearings,my X9303 doesn't. Pretty sure I know which one has the better gimbals
Did you use the heli template? The mixes for Collective are usually on ch11. In the heli setup page you tell it you are using that channel. CH11 will look something like: CH11 +100% THR Switch(ID0) No Trim Curve(C4) +100% THR Switch(ID1) no trim Curve(C5) +100% THR Switch(ID2) no trim Curve(C6) C4 is the normal pitch curve, C5 idle up 1 and C6 idle up 2. Only one line in the mix is active based on the position of the 3 position switch. Ch11 in this case is a "virtual" channel. It is not sent out to the model but used as a place to do the mixes. The heli setup page tells the transmitter where to find it and the result is added into CYC1,CYC2 and CYC3 which are used to generate the three cyclic channels. What heli is it? Things would be different if it is something like something like an MCPx. |
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
