Perhaps the satellite, but in a case instead of just heat shrink?
Looks like the antenna and the connector are in the right places. |
Latest blog entry: er9x heli 450 heli set up (flybar)
Windsor, Canada, near Detroit
Joined Jul 2007
input
then, could you provide data on how you connected the module to the antenna in the tx? seems an interesting alternative. thanks |
To use an HK 9X module that has been removed from a 9X you will have to add a connector that plugs into the one inside the module bay of the 9XR. It will have to be correctly wired to the module as well. Not something you should be attempting without understanding how this all works ![]() If you want to use the cheap FlySky receivers then buy the Flysky module that has the antenna on it. |
Sorry, still jetlagged...
What I meant to say was that it would be better and safer to mount the antenna that was soldered to the module on the back of its case instead of trying to connect the module to the 9XR's internal antenna. Like this for example: http://9xforums.com/forum/viewtopic.php?f=25&t=1430 |
Joined Jul 2007
Cheap 9XR Stand
Noting really special just my solution to HK not having a stand yet. It is made up of small screws with nylon spacers and two nuts. Screwed in and used shrink wrap and then epoxied the feet on it. All parts bought from the local HW store.
Just thought I would share as another idea on keeping the 9XR off of the module. It doesn't add much weight is sturdy and looks decent IMHO. TechJunkieRC |
Austin TEXAS area
Joined Apr 2008
Thank you Daedalus66 I'll go looking there.
Thank you. The bar would be easy enough if you could use flat stock. They sell aluminum flat stock at the HW store. a couple of holes and a couple more nuts and you are good to go. I really wish HK would step up with a good stand. This at least will suffice for now. |
Australia, VIC
Joined Dec 2011
Gimbal Play
Well , I was playing with my 9xr and noticed some in and out play ( slop ) when pulling and pushing gently on the gimbal ( stick ) ...
Wow , well knowing it was there just drove me nuts ... So pulled of the bearing retainer ... and yep , bearing play , or simply the bearing was not held correctly ... Cure = a slice of printer paper used as a gasket , super glued into the bearing retainer to increase down force ( take out the play ) .. Well it worked ...
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
