USA, CA, Piedmont
Joined Jun 2010
CH05 R -100%FULL Switch(ID0) R +0%FULL Switch(ID1) R +100%FULL Switch(ID2) Basic logic: if switch ID0 is active: replace the value sent to channel 5 with -100% likewise for ID1, ID2, replace with 0%, 100% Switches ID0, ID1, ID2, correspond to the three position switch in top, middle, bottom positions. |
Windsor, Canada, near Detroit
Joined Jul 2007
9X or 9XR?
i got this data from their ad: Turnigy 9X 2.4GHz 8Ch Receiver (V2) Reciever for TURNIGY 9X transmitter (V2). Spec. Dimensions: 52x35x15mm Weight: 18g Note: Only RX-9X8Cv2 receiver is comptible with TX-9X(v2) transmitter module. PRODUCT ID: RX-9X8Cv2 but the specs say it is for the 9X, not the 9XR. you say you are using it. have you been able to make it work? and i can't find the module you mention. can you provide the link? thanks |
Joined Nov 2012
I was out of town so I have no had the chance to play with the module much. here is the added information. A couple of times when powering up the radio the module made a long beep. It didnt stop until I powered the radio off. I never saw the LED flash. I tried to power on the radio and long hold the mode button to see if I could get it to react, nothing ever happened.
Anyone have any other ideas? Since very few people have been complaining of bad Orange RX modules I am guessing I have a setting wrong in the radio. I did try creating a totally new model to see if that would change it, no difference. |
United Kingdom
Joined Nov 2012
I had an unresponsive new orange module yesterday, the only thing the LED did was flicker slightly when the radio was turned on, Neither of the buttons did anything. My only recourse was to RMA it. If they check it and send it back to me as working I'll know it was the radio at fault; if not they'll send me a new module. Annoying to wait for the post again, but that's about all I could do.
It will fit the 9XR, but not make use of the internal antenna. http://www.ebay.com/itm/FS-TM002-Fly...item4d09694870 It will work with these receivers: http://www.hobbyking.com/hobbyking/s...eiver_V2_.html http://www.hobbyking.com/hobbyking/s...er_6Ch_V2.html Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
Joined Jul 2007
i have the FrSky DJT-JR module, and their D8R-II Plus rx, but, as i said, his message shows the other 1-that i can't find at hk. regards. |
That is the part number on the module that comes with the 9X,the one with the antenna soldered to the PCB and going through a hole in the transmitter to the antenna. Look at the pictures here: http://www.hobbyking.com/hobbyking/s...Firmware_.html Perhaps he did a DIY mod so it would plug into the 9XR? There was talk about what parts to buy earlier in this thread. (Search this thread for "MCX") From an RF point of view it is the same as the one I posted the link to on ebay. |
Mckinney,TX
Joined Oct 2010
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
