Old Feb 17, 2013, 01:38 PM
juraj.jurej is offline
Find More Posts by juraj.jurej
Joined Jan 2013
How to revamp gas ratchet?
juraj.jurej is offline Find More Posts by juraj.jurej
Old Feb 17, 2013, 03:35 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Paint it red?
gooby is offline Find More Posts by gooby
Old Feb 17, 2013, 03:41 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by kovs View Post
Paint it red?
I think he meant how to get the ratchet action on the throttle to be better
Open it up and bend/adjust the metal tensioner.
pmackenzie is online now Find More Posts by pmackenzie
Old Feb 17, 2013, 04:04 PM
Joined Jan 2013
Yes I think so. Sorry I'm from Slovakia
lvclimber is online now
Find More Posts by lvclimber
United States, TX, Austin
Joined Jan 2013
Originally Posted by LowThudd View Post
As stated, this is a known issue. Some have separated the wires, and some have simply glued the connector. You'll have to open it up and see what is going wrong with the gimbals.
Thanks for the info LowThudd, however the gimbal appears to be working fine...no binding and it's centered. It's the actual shaft that looks like if was assembled incorrectly. I'm not sure if they are pressed in but it looks like it was pushed in crooked. So can see in the picture that the gimbal is actually centered but the shaft looks bent.
Any idea if the threaded shaft comes out easily?
lvclimber is online now Find More Posts by lvclimber
Old Feb 17, 2013, 05:13 PM
airheli1201 is offline
Find More Posts by airheli1201
United Kingdom, England, Milton Keynes
Joined May 2007
I wonder if there will be a back stand available for the 9XR soon? it's really awkward that you can't lie the 9xr on it's back without putting stress on the tx module.
airheli1201 is offline Find More Posts by airheli1201
Old Feb 17, 2013, 05:22 PM
thekesh is offline
Find More Posts by thekesh
United States, IL, Chicago
Joined Dec 2011
Quick question, when I try to unscrew the screws in the back some of the screws come off but the rest just spin but dont come off. Is anyone else experiencing similar problems?
thekesh is offline Find More Posts by thekesh
Old Feb 17, 2013, 05:24 PM
kenstogie is online now
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I finally installed the USBasp drivers, eepe(?) and flashed the 9xr with the latest er9x firmware. Piece of cake thank to the utube video. Its on the tutorial thread if you need it. At this point I am just playing around trying to figure out the menus and buttons and so forth. Some time very soon I will glue down my gimbal connectors. The lead (as others have noticed) seem to "see saw" on the connector. Probably would be fine but I can crash without any help from a tx, thank you very much. LOL
kenstogie is online now Find More Posts by kenstogie
Old Feb 17, 2013, 05:25 PM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I just did that too mine seem to be fine, except they didn't want to come out of the back of the tx even though they did back out completely from the front part. If that makes any sense. Once the back came off I could poke something in the screw hole to remove them.
Old Feb 17, 2013, 05:35 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
Originally Posted by barok View Post
jus a heads up.. not sure if it has been mention..
got the HT to work via aka. futaba square plug.. it seems that pin 6 (signal in) is not connected..bad HK.... work around is to solder pin6 to pin3, a jumper...
this will fix also your uhf module to work on this square plug..
btw.. i hacked the jr plug (not to be use as a trainer) to power my 2.4ghz amp/booster.. looks neater..
so will this work to power the fatsharkgoggles?will voltage be safe that comes out?
abletowinginc is offline Find More Posts by abletowinginc
Old Feb 17, 2013, 06:03 PM
LowThudd is offline
Find More Posts by LowThudd
Joined Jan 2013
This might work http://www.helipal.com/airy-transmitter-holder.html
LowThudd is offline Find More Posts by LowThudd
Old Feb 17, 2013, 06:14 PM
iggy809 is offline
Find More Posts by iggy809
Joined Aug 2005
started looking for a TX. Turnigy 9X ebay around $100. Flysky 9x ebay $100. Hobby king 9x $78. Are these the same and is HK the way to go.
iggy809 is offline Find More Posts by iggy809
Old Feb 17, 2013, 06:19 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Never buy hobbyking products from ebay or amazon, you will get ripped off each time. The 9X is also a different radio than the 9XR which this thread is about.
Old Feb 17, 2013, 09:13 PM
Mikarro is offline
Find More Posts by Mikarro
M$ Security
Joined Jun 2010
A9 gimbals still available.... http://www.robotshop.com/axis-joystick-gim.html
Mikarro is offline Find More Posts by Mikarro
Reply With Quote  (Disabled)
Old Feb 17, 2013, 09:25 PM
mpjf01 is offline
Find More Posts by mpjf01
mpjf01's Avatar
Australia, SA, Adelaide
Joined Aug 2012
After April 8
mpjf01 is offline Find More Posts by mpjf01
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
