Old Feb 08, 2013, 02:56 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Wow, that really sucks.
efx is offline Find More Posts by efx
Imageek2 is offline
Find More Posts by Imageek2
Bad command or file name
Imageek2's Avatar
United States, CA, Riverside
Joined Jan 2013
Originally Posted by Fastmetal View Post
Have read where others have had a similar issue. Just got my 9XR in with a FrSKY DJT RF Module.I can't get the darn module to plug in and I am afraid to force the module in. I am including some picks and hopefully someone can help. I am reluctant to bend pins as I am not sure which of the 5 pins are not connecting.
Fastmetal
It took me about an hour to get mine in. Whoever designed this needs to be kicked where it hurts the most.
Imageek2 is offline Find More Posts by Imageek2
Old Feb 08, 2013, 03:04 PM
sihinch is offline
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
Wow, there must be some serious variation in the manufacture process. My DJT fitted like a glove, first attempt.
sihinch is offline Find More Posts by sihinch
Old Feb 08, 2013, 03:17 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Originally Posted by barok View Post
yes it does work.. see post # 4540..
I'm might work but not for fat shark head tracking
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 08, 2013, 03:25 PM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
tbh the skills to fit a module differ from person to person. no disrespect to the guys that have some troubles but to be honest I don't see the problem alligning 5 pins... the only perhaps"issue" was some excess plastic at the end of the two locking clips for the module, but this can be easily cleaned with a hobby knife...
sometimes I wonder how many 9xr owners have actually made an rc scratch build...
ckleanth is offline Find More Posts by ckleanth
Old Feb 08, 2013, 03:26 PM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
Folks,
Be aware that Frsky is bringing out a new JR module and a line of receivers with three times the range.
http://www.rcgroups.com/forums/showp...ostcount=10031
http://www.frsky-rc.com/ShowNews.asp?id=91
Naturally, I just upgraded all my equipment..... If you haven't ordered your module, you may want to wait.
Details are a bit sketchy, but we should hear more after Chinese New Year.
robschonk is offline Find More Posts by robschonk
Old Feb 08, 2013, 03:27 PM
sihinch is offline
Canada, ON, Toronto
Joined Jun 2007
That's a bit harsh. When I say "mine fit like a glove" I mean I had to do no trimming of plastic, no bending of pins, and no realigning of anything.
I think it sounds like variation rather than skill.
Just my opinion.
Old Feb 08, 2013, 03:41 PM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
What a knob
nebstress is offline Find More Posts by nebstress
Old Feb 08, 2013, 03:42 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
well if its any consolation I can't program amtel cpu's and I'm useless in soldering, which for most of the youngsters these days seem natural...
its just a "tongue on the cheek" comment, don't take it personally
just remember before you complain..
9x costs $50 + post + usbasp +soldering skills to get the most of it
9xr costs $50 + post + usbasp to get the most of it
both might require some minor tlc.. and fitting an additional 3 point switch
for both you need a module an rx, lets say $50
if you want onboard telemetry you can with some soldering
spektrum dx8 ~$300 etc
hmmm....
Old Feb 08, 2013, 03:46 PM
Fastmetal is offline
Find More Posts by Fastmetal
Fastmetal's Avatar
United States, MO
Joined Dec 2012
FrSKY mod fitting 9XR
"no disrespect to the guys that have some troubles but to be honest I don't see the problem alligning 5 pins"
When you buy a pair of shoes and wait 4 weeks for them to arrive, you don't expect to have to stretch the leather to make them fit.
It is not the norm to have to jerryrig electronics to make them fit, either. At the very least, I could have damaged my new XR by bending the pins to the breaking point and voiding any possibility of a return.
I am reluctant to even suggest bending pins, which could motivate someone else to end up damaging their gear.
Fastmetal is offline Find More Posts by Fastmetal
Old Feb 08, 2013, 03:48 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
Originally Posted by nebstress View Post
What a knob
relax mate... guess who doesent have a sense of humor now...
Old Feb 08, 2013, 03:54 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
same here.
but same module, when trying on the 9x, it was very hard to fit, and didn't go all the way.
phil alvirez is offline Find More Posts by phil alvirez
Old Feb 08, 2013, 03:57 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Old Feb 08, 2013, 04:01 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
these pins are 35-40 mm long and is very easy to have some missallignment. even if you bend them 2mm on the top it would take thousand of cycles to break the pins by fatigue on the base.
2 ways to fix missallignment is a) slowly using your module try and see where the need to be bend or b) open the thing up, unscrew the base with the pins and use your module as a template to allign them pins. since you have it opened also put some hot gun glue to the grimball wire connectors on the main board pcb.
there job done
dinislam1395 is offline
Find More Posts by dinislam1395
Joined Oct 2012
My module fitted first time with no problem but when I took the case apart and refitted it would not plug in again. I just reopened and refitted and it was fine again so probably best try that before bending the pins as it might just be aligned incorrectly when assembled.
dinislam1395 is offline Find More Posts by dinislam1395
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
