Old Feb 07, 2013, 05:18 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Originally Posted by SimonChambers View Post
Some may be interested in here to see the newest FrSky modules out:
http://www.rcgroups.com/forums/showp...ostcount=10031
I don't think they are out yet. Press announcement says to be released soon ! (But I understand the enthusiasm )
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Feb 07, 2013, 05:33 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Oops, I didn't proof read my comment enough before hitting submit!
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Feb 07, 2013, 05:38 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Oh yeah, that looks really nice!
I gotta get that module for my 9XR. My intention is to turn it into my main TX, my current 9X will be used for less important things.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 07, 2013, 07:00 AM
mpjf01 is offline
Find More Posts by mpjf01
mpjf01's Avatar
Australia, SA, Adelaide
Joined Aug 2012
X8R FRSKY rx? No other name choices?
mpjf01 is offline Find More Posts by mpjf01
Old Feb 07, 2013, 07:49 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
9XR Report: I got my TX from HK a week ago. I finally had time to test it out with my Frsky Module. I loaded my er9x firmware and model settings without a hitch. Re calibrated my gimbals and tested it out. It work perfectly. Not sure what all the fuss is. Not a bad TX for the price. I'm excited because I just got some head tracking goggles from fatshark and this TX just happen to have the futaba plug, worked out great.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 07, 2013, 08:32 AM
martinlmtl is offline
Find More Posts by martinlmtl
Canada, QC, Saint-CÚsaire
Joined Jan 2013
May I suggest you open your radio! The wires going from throttle and elevator gimbals to motherboard are too short. The connectors on motherboard are moving while you move gimbals vertically. It's a potential disaster to happen. Better to fix them with a tie wrap or hot glue.
martinlmtl is offline Find More Posts by martinlmtl
Old Feb 07, 2013, 09:04 AM
Video Juggernaut
Joined Nov 2003
that's been done, read that a while ago. No biggy but mine didn't really need it, they must have addressed this on the newer ones. it wasn't so tight.
My only beef is the balance connecter, pretty tight to the battery cover. Otherwise this thing is really nice compared to my TH9X, and more than half the price because of the smartieparts board/led.
Old Feb 07, 2013, 10:20 AM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
My 9Xr
is on the way. Is there a tutorial or pic to show what exactly your talking about so I can avoid any crashes (that aren't my fault I mean )
kenstogie is offline Find More Posts by kenstogie
Old Feb 07, 2013, 10:32 AM
xxxcellarator is online now
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
Originally Posted by kenstogie View Post
My 9Xr
See Post #3877 for pics on what he's talking about.
There's also a video of how the connector moves, somewhere earlier in the thread. If you search you will find it.
By the way, to all who find the cable on the throttle pot slightly too short. You can just separate the 3 colored wires (Red, White and Black) from each other to allow them to move more freely. This is all that my radio needed to prevent the throttle stick from pulling back down from the top of it's movement due to the wires pulling on it.
xxxcellarator is online now Find More Posts by xxxcellarator
Video Juggernaut
Joined Nov 2003
My 9Xr
yes there is, just look through here. I got one of the newer batches and mine had plenty of slack. all I did was tie a quick tie near the connecters at the bottom of the gimbal so it didn't wiggle at all but mine didn't have the tension you will see in the video, I'm assuming yours will not either.
Old Feb 07, 2013, 10:35 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Thanks I checked out the post/pics but hope it makes more sense when I crack open my 9xr to fix.
Old Feb 07, 2013, 10:53 AM
Toronto, Canada
Joined Nov 2009
It's not rocket science lol
It's just the hot glue that you see on the connectors.
When you move the sticks up and down, you'll see that the wire attached to the pot that is used for the left/right stick movement (the pots at the top/bottom of the gimbals, not the ones on the sides) will pull on the connectors attached to the PCBs, causing them to wiggle.
Adding glue to the connectors will ensure that they won't ever come loose (like in the pic I linked to above). But the wire on the left stick (looking from front of radio) might also be too short. You can either make it longer somehow, or just do what I did and loosen the 3 wires from each other and that should fix it.
Old Feb 07, 2013, 11:25 AM
BlakeL is offline
Find More Posts by BlakeL
United States, FL, Orlando
Joined Feb 2013
My father in law wants to buy a radio that will last a long time and I was looking at this one. It looks like it will cost around $120 shipped with the special battery and module to FL. Is it worth it or should I just go with the 9x since it comes with everything I need for $79 shipped? Also, if the 9xr is worth it which module would be best? I'm thinking of pairing it with the Super Cub that requires a trasmitter.
BlakeL is offline Find More Posts by BlakeL
Old Feb 07, 2013, 11:42 AM
pmullen503 is online now
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
If that's a Hobbyzone Supercub you'll need a DSM2/X module or TX.
pmullen503 is online now Find More Posts by pmullen503
Old Feb 07, 2013, 11:53 AM
BlakeL is offline
Joined Feb 2013
Don't the sell one of this Orange RX modules that are DSM2/X? My father in law just wants a radio that will last without spending $300+ on a Spektrum or Futaba.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
