Old Feb 06, 2013, 02:40 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
So about ER9x and Open9x. Is there any reason to pick one over the other? I currently use ER9x on two other transmitters, can I transfer all models from ER9x to Open9x?
I'm pretty happy with Er9x so far, but if Open9x works roughly the same but has more features I could give that a try.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 06, 2013, 03:45 PM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
I used Er9x before I switched to Open9x. Open 9x is better and has more features that you may or may not need. If you transfer over your models make sure and check everything because some labels changes in open9x.
For everyone getting frustrated with the ER9x firmware, just go and youtube and watch a couple video. I dont fly helis so I cant really help on that front, but once you get the jist of how the programming works you will see how easy it is.
I have a couple guys come to the field with stock 9x radios and going back to using the stock FW is a pain in the ass.
Also check out 9xforums for additional help
MrMention is offline Find More Posts by MrMention
Old Feb 06, 2013, 06:33 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Is it true that ER9X allows 12 channels, but Open9x only allows 8 (with 1 transmitter)?.
iskess is offline Find More Posts by iskess
Old Feb 06, 2013, 07:15 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Programmer
Just ordered the one from hobbyking, Here is the buddy code for it.
http://www.hobbyking.com/buddy.asp?c...5-C5017DCD8BBA
Killab is offline Find More Posts by Killab
Old Feb 07, 2013, 12:32 AM
juraj.jurej is offline
Find More Posts by juraj.jurej
Joined Jan 2013
No. Open 9X supports 16 channels!
juraj.jurej is offline Find More Posts by juraj.jurej
Old Feb 07, 2013, 12:38 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Thank you for the clarification. I had heard that it supports 8 channels per controller and you had to pair up 2 radios to get the full 16. That must have been bad intel.
Old Feb 07, 2013, 02:20 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
As far as I know you have to have 2 Rx to for to have 16 channels.
er9xuser is offline Find More Posts by er9xuser
Old Feb 07, 2013, 02:23 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
So you CAN'T get all the channels on 1 Rx?
I need 12 Channels on one DragonLink Rx.
Old Feb 07, 2013, 02:24 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
If you own Rx with 12 channels then it will work. But with 8 channels Rx you can't.
Old Feb 07, 2013, 02:25 AM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
No, there are certain module such as the OpenLRS (made by Orx and others) that can take 16+ in a single module.
molond is offline Find More Posts by molond
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
I didn't konw that. Thanks for info.
Old Feb 07, 2013, 02:54 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Originally Posted by HOBBY KING
9XR Standard Features:
8 Channel PPM/9 Channel PCM
Full Ball Bearing gimbals
Steady on, it's a bottom of the range 8 channel radio, and you're complaining that it doesn't do 12 channels one receiver?
aesmith is offline Find More Posts by aesmith
Old Feb 07, 2013, 03:03 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
I'm not complaining, I'm seeking knowledge and clarification from the informed members of this thread.
The 9XR supports 12 channels on one Rx using the ER9X software.
My question is whether Open9X does as well.
I am considering moving over to Open9X, but don't want to loose channel capacity.
I appreciate any constructive replies.
Old Feb 07, 2013, 04:22 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Some may be interested in here to see the newest FrSky modules out:
http://www.rcgroups.com/forums/showp...ostcount=10031
Originally Posted by Chase Wu View Post
XJT module (JR/Graupner type first, Futaba and DIY types later):
Attachment 5514876
• Two auto-detected modulations: PXX (mode selection, bind, model match, range check, failsafe, etc. on radio side) or CPPM.
• Three selectable modes: D8 (existing 8ch two-way), D16 (new 16ch two-way full duplex transmission) or LR12 (new 12ch one-way, approx. three times range of current V8 & D series when pairing with new LR series receivers, such as L9R).
Smart Port enabled, realizing two-way full duplex transmission.
• Detect the module antenna’s working status and give sound warnings if the module antenna is broken or does not have intact contact, etc.
• Super lower latency (approx. 1/3 of current systems) and higher precision (transmitter’s hardware and software support required, such as FrSky transmitters).
A special section for FrSky transmitters will be accessible after the China Spring Festival.
X8R receiver (8/16ch telemetry receiver):
Attachment 5514877
• More number of channels: 1~8ch from conventional channel outputs, 1~16ch from SBUS port.
• With RSSI output: analog voltage output (0~3.3V).
L9R receiver (9/12 non-telemetry long range receiver):
Attachment 5514878
• More number of channels: 1~9ch from conventional channel outputs, 1~12ch from SBUS port.
• Longer operating range: three times of the operating range for V8 or D series.
Attachment 5514944
New hub-less variometer sensor:
Attachment 5514879
• Capable of connecting directly to the telemetry receivers without the sensor hub.
• Backwardly compatible with existing sensor hub and sensors and forwardly compatible with new generation Smart Port enabled sensors.
SBUS & CPPM compatible servos:
Attachment 5514880
Auto-detect the firstly received signal after being powered on and act as conventional digital servo, SBUS compatible servo or CPPM compatible servos.
Attachment 5514892
SimonChambers is offline Find More Posts by SimonChambers
Old Feb 07, 2013, 04:24 AM
LowThudd is offline
Find More Posts by LowThudd
Joined Jan 2013
Thanks for that Simon. Cool stuff!
LowThudd is offline Find More Posts by LowThudd
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
