Old Feb 04, 2013, 06:34 PM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
wait a second? are you opening the file in eepe or companion? are you using er9x or open9x? this is an eepe file for er9x, please use eepe.. sometimes eepe and companion are not 100% compatible
jhsa is online now Find More Posts by jhsa
Old Feb 04, 2013, 06:42 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
ahhhh let me download eepe ive been using companion 9x for both er9x and open.currently running er9x
abletowinginc is offline Find More Posts by abletowinginc
Old Feb 04, 2013, 06:49 PM
Joined Jun 2009
ok mixes working in simulator now.....will burn to tx tommorrow and test it thanks guys
Old Feb 04, 2013, 07:42 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
HK DSM2 Module.....when?
Any ETA for the HK DSM2 module......?
....and if it's been released...sorry for the question.
-mike-
boiko is offline Find More Posts by boiko
Old Feb 04, 2013, 08:09 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
-mike-
So far, nothing... it seems that with all of their other DSM products this would be an easy one to crank out.
marhar is offline Find More Posts by marhar
Old Feb 04, 2013, 08:33 PM
boiko is offline
boiko's Avatar
Joined Dec 2006
Yeah it's hard to believe we're still waiting on this....
-mike-
Old Feb 04, 2013, 09:47 PM
wb4gok is offline
Find More Posts by wb4gok
Old Registered User
Gaffney, SC
Joined May 2004
If you haven't seen it, Part 2 of the Review in on Youtube.....
Turnigy 9XR Review (part 2) (14 min 22 sec)
wb4gok is offline Find More Posts by wb4gok
Old Feb 04, 2013, 10:28 PM
marhar is offline
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by dvogonen View Post
There is a site called 9xrprogrammer.com that has exactly what you are looking for with improved software and the correct connector. USA based, so probably your quickest option.
And the same price as HK with registered shipping. Not a bad deal!
Old Feb 05, 2013, 04:21 AM
planex is offline
Find More Posts by planex
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
I got my 9xr today in the mail with my FrSky DJT module
Ordered on the 23rd December and received 5th Feb
Pretty happy with the transmitter, only complaint is the cross pad
The down and up button are really hard to push in
Sometimes I have to push it for a second time and much harder for it to select
Minor issue, not to fussed just a little annoying at times
You will never find a better transmitter for $50!
I also got the USBasp AVR Programming Device for ATMEL processors
Very easy to install and get working
Upgraded to er9x straight away as I've used it before!
I like the little software upgrades that have been made to the er9x since I last used it
Makes it more user friendly and more clear
I've got a question regarding er9x and 9xr;
I am trying to program the AUX3 switch for flaps
Have setup the mixing but I can't seem to find what number the switch is?
All the other switches such as TRN, AIL, ELV, THR show up on the main screen and ANA screen when selected
But the 3 position AUX3 doesn't
Thanks in advance!
planex is offline Find More Posts by planex
Old Feb 05, 2013, 04:25 AM
iskess is online now
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
"ID0, ID1, ID2 Three position switch. These 3 define the 3-position switch. ID0 is the top position, ID1 mid position and ID2 bottom position."
Straight out of the users guide.
iskess is online now Find More Posts by iskess
Old Feb 05, 2013, 04:27 AM
planex is offline
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Originally Posted by iskess View Post
It is listed as its 3 positions. ID0, ID1, ID2
ah thank you
Now I remember from when I had my 9x
It was actually labeled ID0 ID1 ID2 on the 9x
Old Feb 05, 2013, 06:45 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
It's the same software, so I guess it would be
Old Feb 05, 2013, 08:15 AM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
3 pos switch
I've been using the Template for a 6 channel plane. The program puts the flaps on the 3 position switch.
jchtr3a is offline Find More Posts by jchtr3a
Old Feb 05, 2013, 02:04 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Can someone explain what flight phases are? I read the manual but that still doesn't explain what these do or are these to be used with airplanes which I don't have? I'm just curious as to what these settings are for or how they are used. Thanks.
efx is offline Find More Posts by efx
Old Feb 05, 2013, 02:27 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Flight phases are another term for flight modes. You can set up the radio so that a whole bunch of things change with the flip of one switch.
An example would be in sailplanes where you want different throws depending on if you are launching, cruising, thermalling or landing. With the flaps down in landing mode/phase you might want ailerons mixed into rudder and/or extra aileron differential.
pmackenzie is offline Find More Posts by pmackenzie
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
