Old Feb 04, 2013, 09:36 AM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I generally fly smaller stuff as it's easy to transport but do have some medium sized stuff (Ez*) so I will be using my 9xr for that.....
but what can I do with Telemetry??
kenstogie is offline Find More Posts by kenstogie
Old Feb 04, 2013, 09:46 AM
altas is offline
Find More Posts by altas
Schweiz, BE, Bern
Joined Aug 2011
Review PART1
Turnigy 9XR Review (part 1) (13 min 19 sec)
altas is offline Find More Posts by altas
Old Feb 04, 2013, 10:10 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
now part 1
great to see part 1.
thanks again, great guy.
and my 9xr is black, but my 9x is gray.
i like better it black, but it depends on each 1's taste.
phil alvirez is offline Find More Posts by phil alvirez
Old Feb 04, 2013, 10:22 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by xxxcellarator View Post
Wow, first line = most pointless comment of the year. 2nd line = how are you even gonna do that, as soon as you line them up by putting the module over the bay, you cant see anything!!
The easiest way to get a sense of how much the pins need to be bent and in what direction, is by looking at where the pins are located in relation to the cutout in the case that allows the pins to protrude through it from inside the radio.
See attached.
Notice that the pins in my case are located ever so slightly up, but a lot to the right side of the cutout. This means I had to bend all the pins slightly down and quite a bit to the left. Goes in smooth as butter now.
First line=I guess some people don't have a sense of humor
2nd line=also no common sense
nebstress is offline Find More Posts by nebstress
Old Feb 04, 2013, 10:47 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
Flysky th9x is black, turnigy 9x is gray.
B12 is offline Find More Posts by B12
Old Feb 04, 2013, 11:46 AM
LowThudd is offline
Find More Posts by LowThudd
Joined Jan 2013
Anything from batt voltage, wattage, altitude, RPM, GPS location, speed etc. There are lot's of sensors you can buy and use. There are even fuel level sensors available.
LowThudd is offline Find More Posts by LowThudd
Old Feb 04, 2013, 12:05 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
Originally Posted by Killab View Post
Couldn't get it to work, it will not power the radio, so ordered the one from hk
if its not powering up youmayhave it plugged in bckwards.......these programmers come apart the plug can get turned over on the end.if i plug in backwards doesnt power up but turned overworks fine
abletowinginc is offline Find More Posts by abletowinginc
Old Feb 04, 2013, 12:07 PM
Joined Jun 2009
Originally Posted by pmackenzie View Post
I usually use er9x. I just installed Companion9X to experiment with Open9x and the heli stuff did not work correctly at all in there. Either the collective would not work at all, or the cyclic invert functions had no effect. (I don't have my radio on the road with me, so I can't experiment in it to confirm)
So I suggest you try er9x instead, and the swash mix page will actually work.
Pat MacKenzie
ok i loaded er9x still same problem. i must need to change some values in the mixer screen but i dont know where to begin, the swash moves down on throttle up but the directions are correct when i invert but the swash wont invert in the heli menu or menu 6 of er9x
Old Feb 04, 2013, 12:11 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You should not have to do anything on the mixer screen, that is what the Swash menu is for.
Can you post your eePe file?
Save it and change the extension to .zip for posting it on here.
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 04, 2013, 12:16 PM
dsmithwc04 is offline
Find More Posts by dsmithwc04
The Dude Abides
dsmithwc04's Avatar
United States, IN, Fortville
Joined Jan 2012
So, just did a bunch of searching on flying v911 with the 9XR. I am using stock firmware on the 9XR until my new programmer arrives. I used the heli template that was preloaded on the 9XR and was able to bind the WL v911 to the tx. However, I get no movement of the blades. The servos will react to input though. The mixing seams to be off. Throttle controls movement of the swash plate instead of spinning the rotors. I googled for about 20 minutes and could not find an answer. Any ideas?
dsmithwc04 is offline Find More Posts by dsmithwc04
Joined Jun 2009
will try never have tried it but let me see....
Old Feb 04, 2013, 12:22 PM
Joined Jun 2009
here is eepe filezipped
i am using number 7 for the 500 its the only one that somewhat works
Old Feb 04, 2013, 12:24 PM
dvogonen is offline
Find More Posts by dvogonen
dvogonen's Avatar
Joined Jul 2005
When I set up my v911 I did not use any copter template. I think the setup is elevator on channel1, aileron on channel 2, throttle on channel 3 and rudder on channel 4.
Just choose a basic template for airplanes and set the channel order as described and it should work.
I know that other terms are used for helicopters, but the transmitter uses aeroplane terms everywhere.
dvogonen is offline Find More Posts by dvogonen
Old Feb 04, 2013, 12:38 PM
Joined Jun 2009
i would agree since thev911 is a fixed pitch you wont need mixes
Old Feb 04, 2013, 12:58 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Great video, thanks. That's the first thing I thought about it when I first saw it. Those rear switches looked way too far back.
Originally Posted by altas View Post
efx is offline Find More Posts by efx
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
