Old Feb 03, 2013, 01:06 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
ok still having issue with heli setup flybarred heli 500 trex clone. could someone post how they setup menu 3 and 7 in the transmitter for open9x.i was able to change settingsin menu 7 to correct swash movement for roll and pitch but now my collective is backwards,and when i change directions in menu 3 no changes happen on the inv. so if someone could show me there settings maybe i could correct my issues thanks
abletowinginc is offline Find More Posts by abletowinginc
Old Feb 03, 2013, 02:51 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Try reversing all the cyclic servos, then put the elevator and aileron cyclic mixes back to normal.
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 03, 2013, 03:17 PM
Joined Jun 2009
sorry but explain to me how to do that on the radio im still learning this radio
Old Feb 03, 2013, 04:33 PM
pmackenzie's Avatar
Joined Dec 2002
Servos are reversed in the "Limits" page.The setting for each channel is on the right of the screen.
Old Feb 03, 2013, 05:42 PM
Joined Jun 2009
thats page 7 and thats how i reversed the swash.page 3 wouldnt change anything i tried it if i did it right so i used limits and reversed those.when i did that the swash now goes down on throttle up.and if i return them to notinverted the swash moves up on throttle but then the pitch and roll is backwards
Old Feb 03, 2013, 06:31 PM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Originally Posted by phil alvirez View Post
regarding the extensions for the throttle, i got this from Glenn at rc connectors:
Phil,
There are several connectors with 2mm spacing. They all have different geometry on the plastic connector, the pins are different shapes, etc.
The only way to do this properly is to find the exact connector they're using.
I can't make any guesses without better pictures. Ideally good close-up shots of the male connector end-on and the back side (where the little tangs are that hold the metal inside) and end-shots of the female.
Glenn
so here we are.
is anybody around that could help with this?
perhaps fellows like KKUSA or marhar, who had shown great close-ups?
The gimbal wire connectors seem sloppy anyway. Mine moved on both sides but I just cable tied wires on the sloppy moving connectors to the better secured wires and thats removed almost all movement!
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Feb 03, 2013, 07:41 PM
LowThudd is offline
Find More Posts by LowThudd
Joined Jan 2013
More in stock!
LowThudd is offline Find More Posts by LowThudd
Old Feb 03, 2013, 10:18 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Originally Posted by abletowinginc View Post
it sure will
Couldn't get it to work, it will not power the radio, so ordered the one from hk
Killab is offline Find More Posts by Killab
Old Feb 03, 2013, 10:31 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
new er9x tutorial...
er9x: uploading/updating the firmware
http://eastbay-rc.blogspot.com/2013/...-firmware.html
I'm collecting them here as well:
http://www.rcgroups.com/forums/showthread.php?t=1820823
marhar is offline Find More Posts by marhar
Old Feb 03, 2013, 11:06 PM
bitchin86 is offline
Find More Posts by bitchin86
bitchin86's Avatar
United States, UT, West Jordan
Joined Jan 2013
They are back in stock! Seems like they are getting the back in stock pretty quick now
http://www.hobbyking.com/hobbyking/s...544&aff=628554
bitchin86 is offline Find More Posts by bitchin86
Old Feb 04, 2013, 12:32 AM
pmackenzie's Avatar
Joined Dec 2002
I usually use er9x. I just installed Companion9X to experiment with Open9x and the heli stuff did not work correctly at all in there. Either the collective would not work at all, or the cyclic invert functions had no effect. (I don't have my radio on the road with me, so I can't experiment in it to confirm)
So I suggest you try er9x instead, and the swash mix page will actually work.
Pat MacKenzie
Old Feb 04, 2013, 08:01 AM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
Bruce Simpson at RCMODELREVIEW has just done Part 2 on the 9XR available on You tube. He was quite impressed with the radio, and praised it throughout the review. He will do some further How-to's on it--setting up a model, and putting in FrSky modules with telemetry.
All in all a very complimentary review of the radio.
jchtr3a is offline Find More Posts by jchtr3a
Old Feb 04, 2013, 08:52 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
A link to the review would be nice.
aeajr is offline Find More Posts by aeajr
Old Feb 04, 2013, 09:15 AM
altas is offline
Find More Posts by altas
Schweiz, BE, Bern
Joined Aug 2011
Review Link
Turnigy 9XR Review (part 2) (14 min 22 sec)
altas is offline Find More Posts by altas
Old Feb 04, 2013, 09:35 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
great link
thank you altas. i was wondering why i get a message in the screen after turning it on, but he gets the same, so i guess it is just routine. it says:
'alert; switch warning; please reset switches'; 'press any key to skip'. now i feel better. there is nothing like seeing these details on a video. and the guy has a clear voice and, although speaks very fast, is articulate and does not say any ahs, and his english is very easy to follow.
now, if this is part #2, what could be on part #1?
and can you bring the link?
thanks again.
phil alvirez is offline Find More Posts by phil alvirez
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
