Old Jan 31, 2013, 09:58 AM
LowThudd is offline
Find More Posts by LowThudd
Joined Jan 2013
Originally Posted by kerwin50 View Post
I noticed that on the 9XR the pins for the module are on the side. On my futaba 9C they are on the top.
I'm really leary on ordering a module for futaba for the 9XR if it is not going to fit.
I mainly fly large scale planes so I need a module that can live up to gassers.
I like the Frsky set up. Can anyone post a link for a module that will fit the 9XR?
This telemetry system will work for both Futaba and 9xR(Jr): http://www.alofthobbies.com/telemetr...d-display.html
LowThudd is offline Find More Posts by LowThudd
Old Jan 31, 2013, 10:19 AM
LowThudd is offline
Joined Jan 2013
For those looking for FrSky stuff, aloft is out of stock. Here is another alternative: http://www.leaderhobby.com/list.asp?...55&brand=FrSky
Edit: also http://www.valuehobby.com/radio-syst...telemetry.html
Old Jan 31, 2013, 10:24 AM
Charliechan is offline
Find More Posts by Charliechan
United States, FL, Ocala
Joined Dec 2012
9101901000753000026181
The one with the antenna attached to back. Also modified my old one to unsolder and mount to back. It too works fine on the 9x, nothing works on the 9XR.
Charliechan is offline Find More Posts by Charliechan
Old Jan 31, 2013, 11:04 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
calibrating the sticks
thanks for all the advice. my radio tells me that even if i don't touch nothing. just by turning it on.
anyway, seems that i need to calibrate the sticks.
now, where i read about how to do it?
link? post #?
thanks
phil alvirez is offline Find More Posts by phil alvirez
Old Jan 31, 2013, 11:20 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Originally Posted by phil alvirez View Post
link? post #?
search?
KKUSA is offline Find More Posts by KKUSA
Old Jan 31, 2013, 11:21 AM
LowThudd is offline
Joined Jan 2013
link? post #?
thanks
The search engine helps those who help them selves. lol
http://www.rcgroups.com/forums/searc...brate%20sticks
It has been covered several times recently. There is even a vid or two.
Old Jan 31, 2013, 11:44 AM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
YouTube Videos
link? post #?
thanks
Watch This.
Turnigy 9XR: Radio Setup (2 min 31 sec)
jchtr3a is offline Find More Posts by jchtr3a
Old Jan 31, 2013, 11:45 AM
Joined Dec 2012
9XR and modules
Back at the binding process again on the 9XR. Using two different modules FS-TM002's, the receiver is a FS-R8B. The old 9 will bind with both modules, the 9XR will not bind with either one. Same process. Running OpenX in the old radio, stock firmware in the 9XR. A photo was requested of the module and I will attempt to attach that.
Old Jan 31, 2013, 11:46 AM
Joined Jul 2007
this is the answer
the answer i needed was this: see post 4850 by marhar.
Old Jan 31, 2013, 11:53 AM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
I want to have onscreen telementry on a 9x with smartparts and telemetryEZ but no wires on the back and s_mack has pretty much told me how to do this using the module pins and referencing mikes guide. I'm not an electonics guy so there bound to be followup questions but thats anothere issue..
now to do this on the 9xr I've read mikes guide and to be honest I'm baffeled.
theres the MAX232 IC with board, no idea what that does but i guess its the same function as the telemetryEZ (I think/know telemetryEZ can do a lot more but lets leave that for now)
Originally Posted by KKUSA said View Post
You can flash a telemetry version of ER9X, or Open9X and have it right on the TX screen with a few minor internal mods.
thats the bit that I'm usure... its not a few minor internal mods to me unless there is another way to do it????
ckleanth is offline Find More Posts by ckleanth
Old Jan 31, 2013, 11:56 AM
Joined Jul 2007
thanks
Originally Posted by jchtr3a View Post
thank you. this is the kind of help that i needed.
by the way, our messages overlapped. when i sent mine yours was on its way so i didn't see it.
thanks again.
Old Jan 31, 2013, 12:40 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
SO I am on the mad learning curve before my 9xr gets here and of the many questions I understand like so many things in life I have a choice........
er9x vs Open9x ??
Pros/Cons and Personal experience? Easiest for relative newbies?
kenstogie is offline Find More Posts by kenstogie
Old Jan 31, 2013, 12:56 PM
jkishan16 is offline
Find More Posts by jkishan16
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
er9x vs Open9x ??
This is what I was linked to...
http://www.rcgroups.com/forums/showthread.php?t=1650012
Hope it helps,if there is a more detailed/better thread,I would appreciate it too
jkishan16 is offline Find More Posts by jkishan16
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
On the 9x you can use the telemetryEZ as a solderless option.
This is still not available for the 9XR. Only S_Mack can tell if will ever be.
A user from this thread already modded his 9XR to have on screen telemetry. He did the mod without the level converter (MAX232 thingy )
I personaly did it on both my 9x radios using the level converter. The level converter is needed because the frsky module talks RS232 and the 9XR processor talks TTL. I also prefer the mod with the level converter as we don't have to be messing about with the RF module's PCB and hence not violating the FCC and CE certificates.
I used this one:
http://www.hobbyking.com/hobbyking/s...interface.html
Here explains how to do the mod on the 9x. It should be similar on the 9XR. Please note that going this route involves fine soldering to 2 of the processor pins. Also the pins needed for the telemetry mod, on the 9XR, are connected to the multiplexer IC on the right side of the processor. I don't know if it can cause any problems. But I think in case it does would be possible to just cut the connections between the pins ans this IC. I'm not sure if this could bring any other problems though..
http://9xforums.com/wiki/index.php/H...mmunity_Guides
The best option for the 9XR IMO, also due to the lack of space inside the radio, would be the TelemetryEZ board as it would allow more features to be added. A rotary encoder, and a little eeprom (in the future) to store more models for example. The board is small and could probably be easily installed inside the radio..
They could have really left a bit more space inside that damn thing
Anyway, this is all I can remember at the moment. I hope it helps
jhsa is online now Find More Posts by jhsa
Old Jan 31, 2013, 01:22 PM
jchtr3a is offline
Warbird Fanatic
jchtr3a's Avatar
Joined Jun 2012
Fly Sky module
I have the FlySky B module on my 9XR and it binds with all my old Turnigy 9X 8 ch, FlySky TH9X 6 and 8ch, and HK turnigy 6 ch V2 receivers.
I had to modify the module to move the pins closer to the case wall to make it fit, but after that there was no problem. Do you have any other rx's to try? Perhaps the rx is bad. Also, I ran into problems trying to bind my Orange module and recievers when I was too close to my home wifi router. Other than that I don't know anything else to suggest.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
