USA, CA, Piedmont
Joined Jun 2010
I note that he just spent $500 on this Tx/Rx setup at an LHS! He's got a 9xr on back order. :-) |
United States, IN, Indianapolis
Joined Oct 2010
http://www.amainhobbies.com/product_...l-Red-8-JR-12X |
Joined Oct 2010
The stylus for the Futaba 14MZ has one built in to it, but they are $20. |
About the 9XR case having all those lines or cracks or whatever they are called..
Is it not normal practice to make a few prototypes to check for imperfections? and correct if needed? they might have had some samples, right?? I think they could have done a good job and it would have costed them the same to do it.. I just got the feeling that it was just lazyness and lack of care and nothing else P.S. or rushing to have the product out.. |
http://www.raneystruckparts.com/togg...n-kit-2-piece/ But, I couldn't figure out if it would work, so I just made one up. KC |
Joined Aug 2011
Then you are one of these guys that get every month 100 bonus points from HK, to com over here and attack people that are not pro HK ! THEN YES I SMELL A TROLL TO !
Joined Aug 2011
jhsa you are absolutely right on what you say. Any injection moulding plant worth a toss would produce test shots - and sometimes that can run into dozens of them to get things right. Even more so when it involves cosmetic issues as that is what you see! There is nothing on that case moulding the cannot be corrected by adjusting the moulding cycle parameters or minor tool modifications. What I think has happened is they have produced a bad first batch of several hundred maybe and rather than regrind, have outed them to stop the moaning about delayed releases! It costs just as much to make a bad one as it does a good one, so that will have saved Anthony Hand a few quid. |
Joined Aug 2011
I have a crack in than dam 9X-R and that's what it is . I not call that a minor cosmetic issue !
Joined Aug 2011
TheTimeTraveller ... No matter the facts, some simply will not allow anyone to diss HK.
If light shows through, yours is worse than a knit line as those become something else if they are less than 20% of wall thickness, simplisticly as in if the wall is 1mm and there is only 0.2mm plastic. Yours is a short shot. Rubbish moulding. Full stop. |
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
