Old Jan 18, 2013, 04:32 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
Originally Posted by aesmith View Post
Hard to believe there's such a thing as fake Flysky. How could they make it cheaper than the real thing?
flysky is totally different from frsky.....flysky is common on art tech
abletowinginc is offline Find More Posts by abletowinginc
Old Jan 18, 2013, 05:43 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Art tech don't sell FlySky. What are you getting at?
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 18, 2013, 06:01 PM
Krash n Burn is offline
Find More Posts by Krash n Burn
United States, AZ, Gilbert
Joined Mar 2012
Well took the 9XR for first flight, a little worried after first flight. After a landing I had the prop spin up full throttle with no one on the sticks, controller was on the ground, thankfully I was testing on a indestructible SuperCub, it went into a curb and motor stopped on its own, no damage. I also have an annoying hum coming from the Module. I am using Turnigy 9xr (flashed to ER9X) + OrangeRX R610 + Orange RX Module (Set at DSM2 1024/22ms) .... Otherwise it went okay. I am new to the custom firmware and module, so hoping I just missed a setting.
Any ideas why it's acting up? Any idea on the hum, it's obnoxious?
Krash n Burn is offline Find More Posts by Krash n Burn
Old Jan 18, 2013, 06:38 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
One thing you should do is a mix for a throttle cut switch.
BrettAltea is offline Find More Posts by BrettAltea
Old Jan 18, 2013, 06:41 PM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
FlySky
Art Tech doesn't make Fly Sky, but if you buy an Art Tech plane from some places as a RTF they come with Fly Sky TX and RX. My Spitfire from ParkFlyers did. Fly Sky produces the TH9X which is the rebranded Turnigy 9X, Imax, and Eurgle TX's. If a post I read on another forum is correct, they are making the 9XR exclusively for HK.
jchtr3a is offline Find More Posts by jchtr3a
Joined Mar 2012
I have the T-Cut programmed, I didn't flip it when the spin up occurred.
I am more concerned with the obnoxious hum in the module. It makes me crazy!
Old Jan 18, 2013, 07:01 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
This might keep you from going off the deep end
http://www.rcgroups.com/forums/showp...&postcount=546
pmackenzie is online now Find More Posts by pmackenzie
Old Jan 18, 2013, 07:09 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Check your programming again and make sure you dont have a mix or something set up that would cause the throttle to go full. Check your T-Cut mix and make sure you dont have it set up to be full throttle when off.
If there is a hum coming from the module, that is likely the issue, and nothing to do with the 9XR itself or your programming. Stop using the module.
Im not sure what kind of regulator it uses, but if its a switching regulator, the hum could come from a bad cap or inductor on the output side, or a bad connection to a component etc. on the output side of the regulator.
KKUSA is offline Find More Posts by KKUSA
Old Jan 18, 2013, 07:27 PM
Var. is offline
Find More Posts by Var.
United States, CA, Burlingame
Joined Jul 2012
Originally Posted by ChrisJ800 View Post
Im still liking my 9XR after several days use. Have it flying my Blade MQX indoors on Open9X as a test model. Has anyone done a nice antenna guard yet for the OrangeRx module? My plastic punnet protector (pics posted earlier) is doing its job but doesnt look cool!
If you fit a metal handle on the back like most transmitters have you can put a transmitter stand on it. Has anyone tried to fit one yet?
I would think you'd have to buy one with the cross supports on the bottom or a single leg stand to clear the module antenna
Var. is offline Find More Posts by Var.
Old Jan 18, 2013, 07:46 PM
KKUSA is offline
Joined Oct 2010
I bought one off Amazon to try something like that.
Old Jan 19, 2013, 12:02 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
You can't use protocol DSM2 with the OrangeRx module. The OrangeRx module uses the PPM signal from the 9xr, so the protocal PPM has to be used.
The DSM2 setting ( which is serial, not PPM) is used when an DSM2/x module from a Spektrum Tx is hacked in to the Tx.
KC
KC is offline Find More Posts by KC
Old Jan 19, 2013, 12:20 AM
pmackenzie's Avatar
Joined Dec 2002
KC
I think he means that he set the module to DSM2/1024/22msec, not the modulation in the 9XR.
There is a button on the module to choose its operating mode.
Old Jan 19, 2013, 12:29 AM
Joined Mar 2012
I am using PPM. I did a little more hunting and found this guy with the same problem, I am going to pull the module apart tomorrow and see if mine is buzzing from the same spot.
Old Jan 19, 2013, 12:58 AM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
Oh, I see. Well then that is one very badly misbehaving orange module!
Old Jan 19, 2013, 04:14 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
9XR Battery
Anyone getting the stock battery? Can you charge it inside the TX? What is the advantage of it as Im happy using my 3S older packs and charging externally. May get a LiFe pack next.
ChrisJ800 is offline Find More Posts by ChrisJ800
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
