Old Jan 07, 2013, 05:06 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by Julez View Post
Hi guys.
I took the liberty to take some images of the knit marks from the Hobbyking forum of the link above.
Knit marks (or knit lines) occur, when the flow fronts of the liquid plastic during the injection molding process meet each other in an unfavorable way.
They look like fine cracks on the finished product.
I just spoke with an injection molding specialist who happens to work in my department, and she confirmed that the reasons for this can be either excess moisture in the raw material, or some tweaking needs to be done concerning the injection temperature and speed.
I would call them weld lines, but that sounds about right.
Generally (particularly if you made the tool )you hope that processing tweaks would improve them, but sometimes you need to make tooling changes as well. In this case they would mainly be a cosmetic concern.
Often they are simply hidden behind paint or a surface texture and can only be seen if you look at the back side of a part.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 07, 2013, 05:22 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I agree that on a transmitter case, they are indeed not a big problem.
There was a case that a specific size of folding propellers of the otherwise perfect brand "Aeronaut" kept desintegrating. This could be traced back to a "knit line" at the base near the hinge.
But a TX case will most likely never experience this kind of stress.
Julez is offline Find More Posts by Julez
Old Jan 07, 2013, 05:54 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Speak for yourself
My Tx case bears the brunt of my frustration caused by my mediocre flying.
H2SO4 is online now Find More Posts by H2SO4
Old Jan 07, 2013, 07:00 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Wow, seeing lots of knit picky complaints about a 50 dollar 9ch tx. Anyway, the wire seems like you can hot glue and or add a molex extension? The case molding issue, is it really an issue? Seems superficial to me. What other "issues" did people find? Anyone have a list yet? I've been reading through here but that's about all I managed to find besides someone stating their frsky module doesn't fit right. Speaking of frsky, will the djt module send telemetry to the onboard LCD or will you still need to use an external?
Wingbreaker is offline Find More Posts by Wingbreaker
Old Jan 07, 2013, 07:08 AM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Also very ordinary buttons, unusual battery configuration with 'dangerous' charge port.
TBH I think the real bitch is about lost opportunities.
cold wombat is offline Find More Posts by cold wombat
Old Jan 07, 2013, 07:10 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Problems with PPM at trainer ports not working correctly??
http://forum.turnigy9xr.com/9xr-problem-t342.html
jhsa is online now Find More Posts by jhsa
Old Jan 07, 2013, 07:12 AM
HeliHaven is offline
Find More Posts by HeliHaven
chicken nuggets
Joined Aug 2011
Knit lines and weld lines are the same thing. Painting over them can often make the look worse, as was found with a new paint processing unit was being commissioned where I worked.
Silver paint over a knit line ended up looking like the grand canyon! Heh heh!!
Never did have a moulding that could not have them rectified with adjustments in temps, speeds, packing and pressures.
HeliHaven is offline Find More Posts by HeliHaven
Old Jan 07, 2013, 08:01 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
So the general opinion is these are not cracks but cosmetic imperfections in the molding process. No need to drop some thin CA into them to reinforce them?
As long as they appear to be cosmetic and not structural breaks that will eventually open up, not a big deal. But this is why I would not buy the first batch of almost any product. There are usually "birthing issues" and bugs that come out in the first run. Later runs have these fixed.
aeajr is offline Find More Posts by aeajr
Old Jan 07, 2013, 08:22 AM
chicken nuggets
Joined Aug 2011
Without checking one and seeing the lines, impossible to say. Technically they could be as bad as 'cracks' or just cosmetic and limited to the surface. If they are 'cracks' run some thin CA on the inside. That will help.
Old Jan 07, 2013, 08:44 AM
Video Juggernaut
Joined Nov 2003
dangerous charge port?
Old Jan 07, 2013, 08:57 AM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
From reading those posts it looks like this may only effect those that want to use head trackers.
igorp is offline Find More Posts by igorp
Old Jan 07, 2013, 09:06 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
The radio uses LiPoly batteries but the charger port is for a NiCd/NiMh charger. Hopefully it is not actually connected internally or there could be some radio fires.
Old Jan 07, 2013, 09:09 AM
HSV_Noob is offline
Find More Posts by HSV_Noob
HSV_Noob's Avatar
United States, AL, Owens Cross Roads
Joined Jan 2012
I have a 9X at the moment. Should I look at replacing it with the 9XR? I have set mine up so I can use the module bay so not sure that is a big selling point for me. Buy the 9XR or just stick with the 9X for now?
HSV_Noob is offline Find More Posts by HSV_Noob
Old Jan 07, 2013, 09:11 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
at least one member measured battery voltage there so it is connected. another actually suggested plugging in a wall wart to charge. "dangerous" may be understatement. but i suspect hk will profit from repeat sales of puffed lipos and fried radios so maybe not really bad engineering from their viewpoint.
reasons i passed:
1. with no module or rx extremely bad deal compared to original 9x.
2. incredibly stupid (for consumer) battery design.
3. menus buttons designed to fail within a year or two.
4. bulky "transformers (tm)" case
good for hk. not for me.
dave1993 is offline Find More Posts by dave1993
Old Jan 07, 2013, 09:21 AM
SKIPPER2384 is offline
Find More Posts by SKIPPER2384
Penguins can´t fly?
SKIPPER2384's Avatar
Germany, SH, Glückstadt
Joined Jan 2011
Why should it be so hard to change from mode 1 to 2?
That plastic pin must have gotten in there somehow, so it must probably come out somehow!
My 9XR is unfortunately still on the Way but I ordered a Mode 2 because they were in stock the time I ordered and I fly Mode 3 so the Spring will change it´s Place even if I have to drill it out and replace it on the other side!
SKIPPER2384 is offline Find More Posts by SKIPPER2384
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
