Old Jan 06, 2013, 06:42 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Originally Posted by phil alvirez View Post
i learned to fly full size (you call them 'real') airplanes way before radio controlled model airplanes,
In some languages the term "full size" doesn't translate very well. In my mother language we say "Real Size" maybe that's why i called it real aircraft. I stand corrected though.
jhsa is online now Find More Posts by jhsa
Old Jan 06, 2013, 06:46 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
i learned to fly full size (you call them 'real') airplanes way before radio controlled model airplanes, and with them the throttle is on the left (and aile/elev on the right) , so it was just a logical thing to me to go mode 2.
On my "big" plane, and all other side-by-side seating ones I can recall, the pilot used his/her left hand to control elevator/aileron and right hand for the throttle. The person in the right seat did the opposite.
So the logical thing would be mode 3?
The reason I went mode 1 in the mid-60s was that everyone did. At the time we were making the transition from audio reed radios, where there were switches on the right for rudder and aileron, and on the left for elevator, elevator trim and throttle. So the basic idea of separating elevator and aileron was ingrained. So proportional radios with two sticks were normally mode 1. I don't recall even seeing a mode 2 radio till some time in the 70s.
The other mode that was used was single stick but that was definitely in the minority.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 06, 2013, 07:24 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by WimH View Post
Then explain why this has 1 , while there are 2 posts. Seen several others showing number of posts is NOT it.
http://www.hobbyking.com/hobbyking/s..._Heatsink.html
I thought it was the number of reply's to the discussions & the discussion starter isn't counted
nebstress is offline Find More Posts by nebstress
Old Jan 06, 2013, 07:29 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Originally Posted by Yihaaa View Post
Sorry....I've found your link:
I will going to order the same.
Did you perhaps got reply regarding a shorter version?
You don't get a reply, if you don't want the default size you just leave a message telling them the size you want:
Code:
Optional Length
4"(10cm)
6"(15cm) default
8"(20cm)
12"(30cm)
Old Jan 06, 2013, 07:51 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
So does anyone have one working with the $20 Flysky module that is available? Was any modification required?
shahram72 is offline Find More Posts by shahram72
Old Jan 06, 2013, 08:10 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
For that plane, yes
All the planes I flew have the throttle on the left side, that is the case of the plane in my avatar (chipmunk). exceptions are the cessna(s), throttle on the right hand, and the jabiru, that has the throttle between the pilot's legs
Old Jan 06, 2013, 08:14 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
You skin the modes too much
Two years ago, at my first trip in UK, I was able to drive reversed in 5 minutes after getting car from rental center.
First some taxi in the yard, then followed a bus who helped me to become familiar to get roundabouts in the clockwise direction, but the most important... forgot to specify it was 5AM, and zero traffic
renatoa is online now Find More Posts by renatoa
Old Jan 06, 2013, 08:26 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
looool
Old Jan 06, 2013, 08:35 AM
caseih is offline
Find More Posts by caseih
Joined May 2005
That'd be worse for me with no traffic. If my mind wandered as I went over hill and dale and intersections I might switch to the right-hand pattern without thinking about it. Especially on a country road where here you always go to the right coming up unmarked roads in North America.
caseih is offline Find More Posts by caseih
Old Jan 06, 2013, 10:02 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I plugged in my V2 flysky module and it worked just fine.
crucial is offline Find More Posts by crucial
Old Jan 06, 2013, 10:34 AM
TechJunkieRC is offline
Find More Posts by TechJunkieRC
Gone Flying
TechJunkieRC's Avatar
United States, IN, Covington
Joined Dec 2012
Good news. I had read on turnigy9xr.com forum that at least one person said he found it necessary to make slight adjustments to the module for proper contact with the pins in the 9XR. He said it went in fine and woud bind but then had trouble connecting again. I was hoping I was not going to have to mod out of the box since I purchased the FlySky module as well to work with my V911 and the FlySky modules I already have.
TechJunkieRC is offline Find More Posts by TechJunkieRC
Old Jan 06, 2013, 10:48 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
correct! If I count only the replies it matches every time. OK, that problem is solved(even if it was only me... hehe), on to the rest...
WimH is offline Find More Posts by WimH
Old Jan 06, 2013, 10:50 AM
Joined Sep 2011
Thanks for the updates both you guys. I was concerned about this as I like the Flysky protocol and want both DSM2/X and Flysky. I like to be able to use the Flysky module that has a back where the radio does not rest on the antenna but on the module. Now I am tempted to buy, if I did not already have 2 9x radios. But I am waiting for the DSM2 module that uses the in built antenna. No way I'm using that Orange one with the breakaway antenna "feature".
Old Jan 06, 2013, 11:18 AM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I did have to fiddle with the pins quite a bit to get it to go in but once they lined up it went in and locked ok. They don't instill much confidence in me so I hope they hold up with repeated insertions.
Old Jan 06, 2013, 11:19 AM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
Saves me $$$$$
Glad to hear confirmation that it works. I have several planes with assorted RX's from Turnigy, FlySky, and Hobby King all working off my FlySky TH9X TX, and it would have been an expensive proposition to put a new RX in them all. So this will save me big time. I'm glad HK kept it backwards compatible, as they could probably have sold a ton of RX's for the new 9XR. Of course they will anyway, but perhaps not as many.
The "Vanilla 6ch plane" Template-----is that for a 4 ch plane that has gear and flaps as well? That would be a big plus for me.
jchtr3a is offline Find More Posts by jchtr3a
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
