Old Jan 05, 2013, 07:52 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Originally Posted by jhsa View Post
What about if they'd find out it wasn't reliable?? just speculating of course
No!
gooby is offline Find More Posts by gooby
Old Jan 05, 2013, 07:56 PM
bkahuna is offline
Find More Posts by bkahuna
The Big Kahuna of Foam.
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
Originally Posted by ChrisJ800 View Post
Has anyone properly identified the aerial connector yet so we can see if it is a common industrial connector, to reassure jhsa?
I'm pretty sure it is a MCX connector. I'll know soon as I order one and it should be here in couple of days.
bkahuna is offline Find More Posts by bkahuna
dinislam1395 is offline
Find More Posts by dinislam1395
Joined Oct 2012
Originally Posted by kovs View Post
I wonder if it's possible to power fatshark goggles using the futaba port.
Can confirm you can. Powered my Attitude SD from the Futaba trainer port.
dinislam1395 is offline Find More Posts by dinislam1395
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Originally Posted by Yihaaa View Post
After recieving my 9XR today I immediately flashed it with Open9X. Works perfect!
What are my options for getting the USB programming tool needed for installing ER9X? I see one at HK, it that the only option, or is there one that works from eBay. HK shipping takes too long.
iskess is offline Find More Posts by iskess
Old Jan 05, 2013, 07:57 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Where did you get the cable or did you make it yourself? I looked on readymaderc, but I didn't find anything.
Old Jan 05, 2013, 08:25 PM
Joined Oct 2012
The cable came with the Fatshark. One end futaba square and the other end I think a DIN type connector.
http://www.readymaderc.com/store/ind...roducts_id=724
Old Jan 05, 2013, 08:26 PM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Do you have a link for me where to buy such an antenna cable?
Already posted the link twice, if you can't find that then Google is your friend
nebstress is offline Find More Posts by nebstress
Old Jan 05, 2013, 08:47 PM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
Read in the HK discussion area on the Mode 2 9XR that "several" have been received with the plastic case cracked. Haven't heard anything like that on this thread. Perhaps just someone trying to cause a stir.
jchtr3a is offline Find More Posts by jchtr3a
Old Jan 05, 2013, 08:48 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I have the older fatsharks with a barrel type connector so this won't work.
Old Jan 05, 2013, 09:01 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Is it the head tracker cable?
Killab is offline Find More Posts by Killab
Old Jan 05, 2013, 09:21 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Did you get your f-ugly 9XR already? Got a lnk to the HK one? I may have cables to d/l already...if I can find out what cable is needed and if you're making it this way anytime soon.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 05, 2013, 09:23 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
charging the 3 cells lipo
so i can use any 3 cells lipo-as long as it fits and the plug matches-and remove to charge as i do with all my lipos, with my balance-charger?
phil alvirez is offline Find More Posts by phil alvirez
Old Jan 05, 2013, 09:25 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
There are lots on Ebay, but you will need one that has a 6 pin header and most of them have 10 pin.
I found this one that should work which includes a 10 to 6 converter.
http://www.ebay.com/itm/USBASP-USBIS...item2a2343fe9a
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 05, 2013, 09:27 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Yes.
Old Jan 05, 2013, 09:37 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Is there any way to use the 9x with original firmware with the 9XR as a trainer (or the other way round)?
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
