http://www.hacksmods.com/2012/07/hp6...dule-wired-up/ |
http://www.alofthobbies.com/5db-module-antenna.html |
But the plane is unlikely to fly to the side of the radio as you should be facing the plane while flying it. |
So the rectangle space where you insert the module on the 9XR has a plug for the antenna. I am not aware of any modules that have a compatible plug for 9XR to use with the internal antenna. Two questions:
1. Will there be compatible 9XR modules for 9XR such as FrSky etc? 2. AFAIK you cant use any other module with 9XR right now because the plug in the 9XR will not allow the module to fit in. I am right ? So the only option is to wait for 9XR compatible modules? |
2: No you are wrong, any "JR" type module will fit. |
Downside is that there is no handle on the back to protect the modules antenna when you put the radio down flat. |
Latest blog entry: er9x heli 450 heli set up (flybar)
You will get some loss but not enough to worry about, remember the old 9X had a hunk of metal right next to the module antennas (the handle). |
I would make sure they are not parallel to each other. If they are it could possibly affect the radiation pattern, like a yagi.
And keeping it more than a wavelength away would be good. http://en.wikipedia.org/wiki/Yagi-Uda_antenna If possible, do a range check with the internal antenna removed and compare it to results with it in place. |
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
