No need for Horizon th release anything.
GUID is generated from the unique RF chip ID and the model slot number. How that is done was already known for DSM2 for a long time. DSMX made it more complicated because the hopping sequence is based on the GUID, and the exact algorithm was not known, or easy to figure out. It seems like they did in fact get GUIDs from some real DSMX transmitters and simply copied the hopping sequences applicable to those. Then a Russian guy figured it out some time after the initial release of the HK module and posted the information. So now HK can do a proper job of their module if they choose to. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
EDIT: I guess I'll retract this post. I just read pmakenzie's post. |
I was going to get a matching connector for the 9XR's internal antenna & then use the FrSky DHT DIY module & hack a connection to the internal antenna, keeping everything in the module bay as I have done previously with my 9x but apparently its not a good idea:
And you will have to worry about the connector and coax (not so much) issues with a module with a removable antenna anyway. You are already hacking one thing, why not make it a pair? |
.What do others think? I don't have the equipment & know how to test antennas, I would like to find the correct connector & use the internal antenna as I'd planned but obviously don't want to end up with a worse signal. & does anyone know for sure what connector I need? the closest I can find is a SSMB-Nano Plug. |
http://www.rcgroups.com/forums/showp...97&postcount=2 |
Frsky has a 5db replacement antenna.
http://www.frsky-rc.com/ShowProducts.asp?id=45 Stacked 1/4 waves? Possibly take the guts out of that antenna and put them in the handle.
| Thread Tools | |
| Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? | jlloyd1995 | Batteries and Chargers | 124 | Mar 12, 2013 10:05 AM |
| Sold 2 turnigy motors 2 turnigy esc's | crashnburn69 | Aircraft - Electric - Power Systems (FS/W) | 4 | Oct 13, 2012 11:05 AM |
| For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. | Falconpunch | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 18, 2012 09:47 PM |
| Discussion Turnigy or Turnigy Nanotech | lawguy14 | Batteries and Chargers | 4 | Mar 15, 2012 08:48 AM |
