Old Dec 29, 2012, 08:05 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by speedy01 View Post
I hope all you Negative Nancys are proven wrong, wrong, wrong.
Gene K
I was not being negative, about this at least.
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 29, 2012, 08:41 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
Originally Posted by pmackenzie View Post
Almost makes me wish I had bought one so i could see for myself. But I was at work when they came and went from stock
Pat MacKenzie
I missed it too and add to basket bk and here what I got this morning:Your parcel has been sent from the HobbyKing.com warehouse!
flye is offline Find More Posts by flye
Old Dec 29, 2012, 09:53 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I hope all you speculative Negative Nancys are proven wrong, wrong, wrong.
Gene K
If you read the discussion you will find that it is simply an attempt to understand the confusing information about batteries that HK has provided. It's an important issue as people are trying to figure out what will work and what won't.
I too find some of the speculation and HK-bashing silly, but in the discussion is some genuinely useful information from reliable regulars like Pat.
I'm wondering how all you non-speculative "positive" types plan to power your nice new 9XR when it arrives. Or will you just wait till the "official" 9XR battery is available?
Daedalus66 is online now Find More Posts by Daedalus66
Old Dec 29, 2012, 10:30 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
As said before I think it would be logical to use the balance plug to deliver the full pack voltage whether is a LiPo or a LiFe. That also makes it easier to find a suitable battery.
But I've seen, and actually I own batteries that have reversed polarity on the balance plug. it seems that some chargers might use a reversed polarity pinout. So, we better don't just assume that because it is a balance plug, it will fit. we must ALWAYS check the polarity..
If we get the batteries at HK , perhaps the risk of that happening is minimal..
jhsa is online now Find More Posts by jhsa
Old Dec 29, 2012, 10:31 AM
bkahuna is offline
Find More Posts by bkahuna
The Big Kahuna of Foam.
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
Since I don't plan on using any external equipment such as FPV or telemetry modules utilizing the 12v port, I'm probably just going to use my LiFe battery. I'm also not waiting the modules. I've already have few mods in mind. I still need to place a digikey order (unless of course some offers me an exuberant amount my 9XR). lol
bkahuna is offline Find More Posts by bkahuna
Old Dec 29, 2012, 10:47 AM
bkahuna is offline
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
From the turnigy9x forums...
"I did build of the 9XR software version and loaded it into a 9x. I'm surprised at the number of changes in menu.cpp. Pretty extensive with most of it well thought out."
It would be cool if someone could take a look at this that know what they're looking at and post their findings. I would prefer use er9x code due to the bug numerous bug fixes but maybe HK has added some neat stuff to the menus, but somehow I doubt it.
Old Dec 29, 2012, 11:03 AM
npre is offline
Find More Posts by npre
Joined Jan 2011
well the microprocessor can be found in the manual posted a few pages back, it is atmega64. also the firmware sources+binaries are on the 9xr forums.
npre is offline Find More Posts by npre
kha is online now
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
I compared the soyrxe with diff and thereis two major changes.
Addition of the reverse screen and the channel order in templates
It would be trivial to import those to er9x.
kha is online now Find More Posts by kha
Old Dec 29, 2012, 11:14 AM
jlremr is offline
Find More Posts by jlremr
Johninarky
Rogers,Arkansas
Joined Jul 2005
Originally Posted by marhar View Post
Yep, if this thing is going to be documented it's going to be community-documented.
Fortunately the pics on the product page make it pretty clear... A 3S balance plug is all that's necessary, so any HK 3S will suffice. I'm going to break down and get another LiFe... probably this one, since it's a bit under $7.
http://www.hobbyking.com/hobbyking/s...ter_pack_.html
If this picture shows the way it is actually used, then I have a problem with it. To properly charge the lipo, it should be removed and charged with a good balance
charger. This means plugging and unplugging each time. Bad for the connector.
If there is enough room in the compartment, I would use a short 3s balance extension and unplug it from the battery end, thus saving the Tx connector.
John
jlremr is offline Find More Posts by jlremr
Old Dec 29, 2012, 11:19 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Or one can splice in second balance connector with just two wires an leave that in. I'm pretty sure only the edge pins are needed.
Old Dec 29, 2012, 11:26 AM
bkahuna is offline
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
While I do understand the resentment for the way HK went about things, maybe if we ask the developers of er9x nicely they might provide us (the rcgroups community) with a build incorporating the HK changes. Or if someone could post a how to, I would be willing to give it a go myself and test in my 9XR when it arrives, or flash my current 9x radio.
Old Dec 29, 2012, 11:28 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
what means soyrxe ?
wallaguest1 is offline Find More Posts by wallaguest1
Old Dec 29, 2012, 11:41 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
If you are qualified to do this kind of development I suggest you go to the 9X development forum and download the appropriate information so you can start your software development.
http://9xforums.com/forum/
That is the benefit of the open source community. Anyone can contribute and everyone will benefit from your work. You are no longer at the mercy of Futaba or Spektrum or the other majors. You want a feature, go develope it and submit it for inclusion.
All the info is on the forum.
aeajr is offline Find More Posts by aeajr
Old Dec 29, 2012, 12:15 PM
mnemennth is online now
Find More Posts by mnemennth
AMA 1033652
mnemennth's Avatar
United States, TX, Houston
Joined Jul 2012
Originally Posted by Daedalus66 View Post
The 9x reference has been there since 2007, when the radio really was a 9-channel and operated with PCM coding on the FM bands (35 or 72). Even then, if you operated on PPM to allow you to use a regular FM receiver, you only got 8 channels.
When 2.4 modules came along about 2008, they too only worked with the 8 channels of PPM.
Some people would have had FlySky and HK change the name of the transmitter along the way. But while it might be slightly confusing to have a radio called 9x that only has 8 channels, it would be at least as confusing to change the 9x name to 8x while it remains essentially the same radio.
Like you, the thing I would seriously criticize HK for is not making clear in the specifications that this radio delivers 8 channels in its 2.4 configuration. This is particularly objectionable in the new 9XR specs, where the PCM reference is totally irrelevant.
It's not irrelevant anyways; any time you mix a channel you have to use a logical channel. The radio does deliver 9 logical channels, so it is still a 9 channel radio in that respect. It's annoying that you can't use every channel at the RX, sure, but you DO get 9 channels, after a fashion. Most users are mixing SOMETHING, so in practice it becomes a non-issue.
mnem
*Poorly programmed*
mnemennth is online now Find More Posts by mnemennth
Old Dec 29, 2012, 12:17 PM
bkahuna is offline
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
I'm willing to take a look at it, but what is trivial for some would not be for me as I'm not familiar with the code. I was hoping someone who has proficiency with the code would be willing to help out. I've done some programming, mostly C# and PowerShell but honestly I'm more of a hardware guy.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 11:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 12:05 PM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 10:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 09:48 AM
