Old Dec 28, 2012, 02:43 AM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by Var. View Post
Why do they require a 3S when a 2S battery has enough voltage to do the job? At least on the 9X it does. I wonder if they were so lazy to not want to change the battery alarm. Or if the new radio actually requires 12 volts.
The old 9x has 7805 regulators on it thus half empty 2S will not be able to give full 5V (7805 may drop near to 3V) out with that. Some have replaced those with LDO ones to make it safe.
kha is offline Find More Posts by kha
Old Dec 28, 2012, 02:45 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Because so was told by old men coming from NiMh caves
Also, the UHF reason... all LRS UHF systems I know works internally at 5V or 3.3V, all are happy when powered from 2s.
LE: Seen the above after posting, is wrong ! 7805 works ok even at 6.5V ! The 7V delivered by a 2s are more than enough. is the minimum voltage I would go on a 2s LiPo, to not break under 15% remaining charge.
renatoa is online now Find More Posts by renatoa
Old Dec 28, 2012, 02:47 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
What's an LDO?
marhar is offline Find More Posts by marhar
Old Dec 28, 2012, 02:48 AM
dvogonen is offline
Find More Posts by dvogonen
dvogonen's Avatar
Joined Jul 2005
Originally Posted by pmackenzie View Post
It wouldn't cost them much to make it capable of supporting FrSky Telemetry - just move a couple of the push buttons to different pins on the micro and add a connector to the ones you freed up.
The connector alone would make the task easier, almost plug and play. They could sell the MAX232 level shifter on a board with the matching plugs for $5, just like they do the programmer.
Pat MacKenzie
Yes, that would have been doable.
But it would have broken compatibility with all existing open source firmware. I don't think they saw that as an option.
It is a pity that they didn't communicate with the core open source developers during development. There are actually only about 4 active at the moment. They could have gotten support for whatever change they wanted if they just asked for it. Another version of the processor with more memory being the most important one...
dvogonen is offline Find More Posts by dvogonen
Old Dec 28, 2012, 03:01 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Thats the Tru-Tru (just watched Cloud Atlas). Also running off 3S makes it much less efficient and wastes a lot of power.
KKUSA is offline Find More Posts by KKUSA
Old Dec 28, 2012, 03:08 AM
emreozcakmak is offline
Find More Posts by emreozcakmak
suffering pilot
emreozcakmak's Avatar
İSTANBUL-TÜRKİYE
Joined Apr 2006
Choosing a module ?
I plan to purchase a 9XR but need advice on choosing a module.
I dont have enough knowledge on modules.Which is the best module for a 9XR in thiis picture ????
emreozcakmak is offline Find More Posts by emreozcakmak
Old Dec 28, 2012, 03:13 AM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
And don't forget that wasted power = heat.
BrettAltea is offline Find More Posts by BrettAltea
Old Dec 28, 2012, 03:24 AM
KKUSA is offline
Joined Oct 2010
Upper left, or lower right (same module) FrSky!!
Old Dec 28, 2012, 03:36 AM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Hmh, should not write anything from memory... the 7805 datasheet states 2V drop at 1A so it is fine.
Old Dec 28, 2012, 03:54 AM
dvogonen is offline
dvogonen's Avatar
Joined Jul 2005
To BrettAltea:
If you have the luxury of not having to be compatible with anything , you should definitely go with a FrSky module. That is a top grade system.
I don't know why their stuff works so well, but it does. If you want bells and whistles, they have got it. A well proven telemetry system . If you just want simple, inexpensive and lightweight receivers, they have got that to. And it all works together.
Old Dec 28, 2012, 03:57 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
Originally Posted by dvogonen View Post
To BrettAltea:
I was just wondering, why they don't have bluetooth add-on ready for their module, now you still need do hacks if you wish to make anything useful with telemetry.
dziedrius is offline Find More Posts by dziedrius
Old Dec 28, 2012, 04:29 AM
michel49 is online now
Find More Posts by michel49
Joined Jul 2011
3S LiFe is the best choice= 9,9 volts
michel49 is online now Find More Posts by michel49
Old Dec 28, 2012, 04:37 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
looks like the Firmware has now been made available at http://turnigy9xr.com/source/tgy-9XRv1-1.rar
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Dec 28, 2012, 04:40 AM
Joined Sep 2007
I know the 9X power schematic based on 7805, but... why are we so sure they didn't switched to a lossless solution in 9XR ?
There are today available hybrid 7805 replacements same layout same size, but switched version.
If true, then the 2-3s debate is without meaning.
Old Dec 28, 2012, 04:58 AM
Joined Aug 2011
To BrettAltea:
That's one I'm considering but want to see a tutorial on how to install it in the 9XR first. Also don't want an external aerial either. Will have to wait and see I guess. Really, really wish HK would expound on their module plans. Crap that they haven't as currently people have a useless radio if they don't want an antenna sticking out the back.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
