Old Dec 27, 2012, 05:17 AM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
Originally Posted by pmackenzie View Post
FWIW, DSM2/DSMX support in ER9X is through using the module from a DX4e, which does not use PPM as the input. It uses serial data.
This has several advantages over using PPM:
-No PPM conversion delay
- Serial data is presented at the correct speed, so RF output is in sync. Non synchronized can produce 1 to 2 frame delays.
- Model match capability
- True 11msec frame rate ( not implemented in the release code, but it does work )
If the HK module only uses PPM it will never have as low a latency as is possible using the DX4e module. If they were clever they will have made their module auto detect the type of signal. Time will tell if this is the case.
Pat MacKenzie
Ok, this makes a bit more sence, I just thought it worked like a standard module.
molond is offline Find More Posts by molond
Old Dec 27, 2012, 05:33 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I did leave out one limitation of the DX4e approach - we are limited to the 6 channels it supports.
But again if HK has been clever the firmware could easily support sending more channels.
And if they used the serial data lines instead of a regular I/O to drive the "PPM" pin and included a return data line from the module using the unused "6 volt" pin in the JR pinout then they could add DSMX telemetry support down the road.
This is the sort of thing that "the developers and hard core users" would have suggested had we been consulted at all
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 27, 2012, 06:50 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
for those interested, i did some scaling on the picture with the 9xr lipo, knowing the center of sticks to sticks is 105mm it was easy.
bakchos is offline Find More Posts by bakchos
Old Dec 27, 2012, 06:57 AM
pilotavery is offline
Find More Posts by pilotavery
United States, CA, San Marcos
Joined Jul 2012
Or look at the size of the JST connector, or JST-XH
pilotavery is offline Find More Posts by pilotavery
Old Dec 27, 2012, 06:59 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
it's a standard 2 pin JST red connector, like the one you get on the 1000mah lipo
Old Dec 27, 2012, 07:09 AM
Joined Jul 2012
I know that. I said to the guy above me to look at the JST connector in the picture instead of the width of the sticks. They might have changed the width. The JST connector is always the same. The JST-XH balancing connector is always the same too!
So I was saying compare it to the JST connector instead because the 9XR might have changed the stick width.
Old Dec 27, 2012, 07:15 AM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Originally Posted by dsmithwc04 View Post
Anybody have a Flysky module with ant. for cheap? Just got my v911 in with no way to fly it...
Figured this might be an area where people have extra 9X stuff laying around since most just got the 9XR...
I have a flysky module I want to get rid of when the 9XR arrives.
gooby is offline Find More Posts by gooby
Old Dec 27, 2012, 07:18 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Programmer would add $5, scroll wheel perhaps about the same again.
At least then it would have something to differentiate it from the 9X.
They probably could have saved that $5 by forgetting the interchangeable different coloured fascias.
aesmith is offline Find More Posts by aesmith
Old Dec 27, 2012, 07:22 AM
molond is offline
molond's Avatar
Joined Oct 2011
This was the one mentioned a few pages back, I have already ordered mine since it is only $20 with free shipping (to Aus at least).
Old Dec 27, 2012, 07:24 AM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
My 9XR shipped!
Old Dec 27, 2012, 07:30 AM
aesmith is offline
Joined Apr 2010
For indoor or short range use you can use a Turnigy module, so long as when it was removed there was enough coax left on the board to strip back 31mm and make an antenna like you'd see on a receiver. That's what I use for my indoor heli, and it gives me around a 90m range..
Old Dec 27, 2012, 07:40 AM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
Take your module out of your 9X, put it in the 9XR, as an upgrade, and donate it to me!
Or sell it...
Ill give ya $30 for the module less 9X,
I was reading the 9x module wont fit/work with the 9XR
RoboSerg is offline Find More Posts by RoboSerg
Old Dec 27, 2012, 07:42 AM
Joined Jul 2012
If you can solder and are good with tools you can!
Old Dec 27, 2012, 07:44 AM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Where?
Fentonflyers is offline Find More Posts by Fentonflyers
Old Dec 27, 2012, 08:08 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
Will 9XR work with 3s LiFe battery? Someone mentioned, that there may be problem with UHF modules, as long as they are using 12v, I have not found menu item to choose battery type, so wondering if LiFe battery will be ok.
dziedrius is offline Find More Posts by dziedrius
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
