Old Dec 27, 2012, 12:04 AM
dsmithwc04 is offline
Find More Posts by dsmithwc04
The Dude Abides
dsmithwc04's Avatar
United States, IN, Fortville
Joined Jan 2012
Anybody have a Flysky module with ant. for cheap? Just got my v911 in with no way to fly it...
Figured this might be an area where people have extra 9X stuff laying around since most just got the 9XR...
dsmithwc04 is offline Find More Posts by dsmithwc04
Old Dec 27, 2012, 12:11 AM
The Dude Abides
dsmithwc04's Avatar
Joined Jan 2012
Originally Posted by igorp View Post
That's the one I use in my Futaba 7C, and its great. I guess I'll have to solder on a JST connector.
Originally Posted by pda4you View Post
This looks to have the correct JST plug for the 9XR correct?
Old Dec 27, 2012, 12:20 AM
ChrisJ800 is online now
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
No it does not have a JST plug so you will need to solder one on. Dont confuse it with the balance connector which you probably dont want to change as usually is needed for charging.
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Dec 27, 2012, 12:23 AM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
You need a JST plug B3 per http://www.eflightwiki.com/eflightwi..._Balance_Plugs
Old Dec 27, 2012, 12:42 AM
The Dude Abides
dsmithwc04's Avatar
Joined Jan 2012
It looks to have two discharge plugs. One looks like the balance type plug (which I thought is what is needed)
Old Dec 27, 2012, 01:05 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
This is plug it will likely have.
I have many if you need one when you get your stuff.
KKUSA is offline Find More Posts by KKUSA
Old Dec 27, 2012, 01:38 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by KC View Post
The above quote from the 9xr site doesn't mean that the 9xr requires 3s to operate. It means the 9xr supports 3s lipo's and the 'Required' means the Tx is not supplied with it.
I do however, agree with gruntboy for most part. The 9xr is a pre modded 9x. It'll be interesting to see if telemetry on screen is an included feature.
KC
That's pretty much my take. I've got a 9x with backlight and er9x, and it's really nice. Add in some improved sticks(?) and it will be a pretty nice unit.
I wouldn't be surprised if they plan on moving forward with their own er9x software if they add telemetry.
marhar is offline Find More Posts by marhar
Old Dec 27, 2012, 01:47 AM
pilotavery is offline
Find More Posts by pilotavery
United States, CA, San Marcos
Joined Jul 2012
Hahaha hobbyking doesnt program...
pilotavery is offline Find More Posts by pilotavery
Old Dec 27, 2012, 02:13 AM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
I asked this over in the telemetrez thread but will ask here too. Would Telemetrez work with the 9XR to get telemetry from a Frsky DJT appearing on the screen? Any firmware issues?
Old Dec 27, 2012, 02:19 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
Telemetrez relies on the connections between the board and switches/accessories. So far nobody knows if they've kept the same wiring as the 9x.
Stock 9xr firmware seems too old to include telemetrez support, so upgrading would likely be needed.
Kilrah is offline Find More Posts by Kilrah
Old Dec 27, 2012, 02:44 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
they could have use the unused pins of the module to make them ready to be used with frsky telemetry units,
working with frsky yo make personalized units in order to pass the data to those pins
lot of cheap improvements lacks in 9xr,
remove the handle radio is a big mistake, how to use a radio stand now ? or how to attach an LRS box...
without the handle how you attach a Frsky LCD ?
you also can't protect the antena of a external module,
wallaguest1 is offline Find More Posts by wallaguest1
Old Dec 27, 2012, 03:50 AM
KKUSA is offline
Joined Oct 2010
Yea, they should have at least put a typical handle on the back, or integrated a stand.
There are many things they got wrong in the design, and none of it is forward thinking. Actually a step back in some aspects.
The exclusion of the telemetry port was a conscious one. They knew what they were doing. Unless, it happens to be on the unused module pins, and the module they are supposedly working on with FrSky will interface to the module pins so no external cable or crazy wiring is needed. From their point, that would be the ideal method of telemetry connection for the 9XR FrSky module.
Old Dec 27, 2012, 03:53 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
They must have done some to get the different menu.
aesmith is offline Find More Posts by aesmith
Old Dec 27, 2012, 04:05 AM
KKUSA is offline
Joined Oct 2010
Just FYI , the second batch was just in, and at -12 now. My order first day was a back order and now its updated in my account as in stock. So back orders for the last few days should be shipping.
Old Dec 27, 2012, 05:08 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by molond View Post
There is no need for the software to have specific protocol support since the module acts as a middle man, changing PPM into the protocol used by said module and then send it out.
FWIW, DSM2/DSMX support in ER9X is through using the module from a DX4e, which does not use PPM as the input. It uses serial data.
This has several advantages over using PPM:
-No PPM conversion delay
- Serial data is presented at the correct speed, so RF output is in sync. Non synchronized can produce 1 to 2 frame delays.
- Model match capability
- True 11msec frame rate ( not implemented in the release code, but it does work )
If the HK module only uses PPM it will never have as low a latency as is possible using the DX4e module. If they were clever they will have made their module auto detect the type of signal. Time will tell if this is the case.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 10:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
