Old Oct 25, 2003, 12:10 AM
TEM is offline
TEM
Find More Posts by TEM
TEM
Joined Aug 2003
Powering the receiver without the ESC
I've personally have yet to burn up an ESC in flight, but I noticed reading some threads that when it happens a plane loses control and dives into the ground?
Now in that case, wouldn't it be logical to run a 5V regulator directly from the battery and then powering the receiver/servos with that and running the signal and black(I think) into the ESC. So if the ESC burns up, you still got some control? It'll be a few gram weight penalty but would be a worthwhile "insurance policy"?
TEM is offline Find More Posts by TEM
Old Oct 25, 2003, 09:32 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
You can use and external BEC. The UBEC from koolfightsystems.com works well. The other option is to use a battery. 4 or 5 nicad or NiMH cells work fine. Loosing an aircraft due to BEC failure is pretty rare, and almost never happens as long as you stay withing ESC maximum servo recommendations.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
[UK FS] Hitec micro servos, receiver, Jeti ESC Ben C Aircraft - Electric - Airplanes (FS/W) 1 Jul 01, 2003 03:05 PM
Powering Receiver without BEC? ewhahn Electric Plane Talk 15 Jan 06, 2003 10:37 AM
Can I test Rx without ESC? JamesD Beginner Training Area (Aircraft-Electric) 3 Dec 13, 2001 04:26 PM
Voyager being sold without esc+motor from jr? johnpmartins Electric Heli Talk 10 Jul 28, 2001 12:40 AM
Using BEC without ESC Anks Power Systems 3 Jul 25, 2001 04:04 PM
