This thread is privately moderated by quadracer, who may elect to delete unwanted replies.
Old Apr 06, 2012, 06:50 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Build Log
Buck and Half Huck gear mod
Recently built a new 3DHS 48 Edge, and didn't think too highly of the wire gear. It would bend on even the softest of landings, so when I ordered the new airframe, I also ordered gear from their 47" Extra SHP, along with axles from the 46 Aspera/51 Slick.
When I started to assemble the gear, I used the included ply wedge, but didn't glue it in. Instead, I pushed it into the slot to where it sat flush with the bottom of the fuselage, and ran 3 screws through the formers to hold it all in.
I didn't glue it because I wanted to retain the option to use the wire gear if needed.
The SHP gear has two holes predrilled, and I used 1.5" wood screws up through the gear and into the former to secure it. If you use the predrilled holes and similar length screws, make sure you angle the screws toward the center of the fuselage slightly, so the screws do not hit the carbon stringers running along the gear former.
The axles have a 5/32" shaft, so you will need to bore the factory formed axle hole out a bit. I used a drill bit, and drilled it by hand to avoid snagging and destroying the pants.
As I started assembling the wheel pants, it appeared the axles were too long to allow me to get the wheels inside. I had to pry the pants open a good bit, but they had just enough flex to allow the axle into the hub. I thought sure they would split in half, but luckily, they held.
The little white plastic blocks barely fit around the SHP gear, and since there is an axle stud poking through, you will need to drill the blocks out to 5/32" as well.
The rest of the build was run-of-the-mill, so I'll not bore you with that. Now, go fly the wings off of it!!
quadracer is offline Find More Posts by quadracer
Old Apr 08, 2012, 01:43 PM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
Nice mod job!
gabrielisrael is offline Find More Posts by gabrielisrael
Old Apr 08, 2012, 02:58 PM
quadracer's Avatar
Joined Feb 2012
Thanks, although it proved not as strong as I thought it would be. There is an empty space right behind the gear bulkheads, so I built that area up with wood, and mounted the gear into that.
Discussion 3DHS 41" Edge "99 Buck Huck" Park_aviator 3D Flying 4046 Jun 18, 2016 03:09 PM
Sold $80 Buck Huck! flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 5 Mar 13, 2012 10:03 PM
